Question about Tomtom Rider 2 Europe Motorbike GPS 3.5" screen Touch , Bluetooth GPS Receiver
Is there a fuse or some sort of electrical protection inside a Tomtom rider bike dock that the user can change?
It is my understanding that a fine layer of corrosion can form over the contacts on the mounting dock and/or the TomTom itself after a period of outdoor exposure. A white course rubber eraser is the perfect instrument to remove that corrosion without excessive wear to the contacts. This is an old computer repair trick that I used on various computer cards. This is just an inexpensive trick to try. Hope it helps.
Posted on Aug 09, 2009
    Brigadier General:
  • 4,090 Answers
No, if the dispay is missing then either the dispaly chip is cooked or the plug has disngaged from vibration. TomTom are not much good on a motor bike at anytime
Posted on Jun 20, 2009
My tomtom rider 2 will not turn on
My tomtom rider 2 will not charge on my bike and will not charge from mains electric, when i use my tomtom in the car it works.
Cheers Tim
Mar 23, 2011 | Tomtom RIDER GPS Devices
Rider 2 Bike Dock no longer charges, needs repairing or replacing?
call tomtom to get the dock replace, after you insure that the dock is getting power. check with ohm meter, should have abut 13.5 volts to the base.
Aug 21, 2009 | Tomtom RIDER 2nd Edition GPS Receiver
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Jul 14, 2009 | Tomtom RIDER GPS Devices
Hi I plugged my tom tom Rider into my computer maybe I should of turned the tomtom off first now it won't power up I was wondering if there is a fuse inside the tomtom to protect it from people like me ??
Hi, had the same problem, i disconnected the battery from inside, left it a min or so then it powered up ok. dont know if this will work for all but it did for mine.
Apr 02, 2009 | Tomtom RIDER GPS Devices
Need tomtom rider 2 2nd addition docking shoe
Forget TomTom. Go buy this one
http://www.wunderlichamerica.com/mm5/merchant.mvc?Screen=PROD&Store_Code=WA&Product_Code=8600880&Category_Code=
I talked to TomTom multiple times on the phone and had same problem but finally found this. It's better quality and it's available.
Mar 24, 2009 | Tomtom RIDER 2nd Edition GPS
Pls describe the size and type of security screw on tomtom RIDER
I have tomtom rider 1.
There are 3 sizes of Torx screws; 3 sets of 2 screws each.
The largest is at the top back. I watched a fellow on YouTube take the back off. That was very helpful.
Someone called that T6 screw. I found a little set of security torx drivers for this.
The 2 bottom corner screws are smaller and then inside that on each side of the door are 2 more (smaller size but longer) screws.
Then carefully take the back off. There are wires connecting the back to the main board.
Take the card out before you try to take the back off.
Hope it works ok for you.
Ron
Mar 07, 2009 | Tomtom RIDER GPS Devices
Tomtom rider1 connection problems
Put two pieces of tape on the bit of the unit that slides onto the bike mount thus bringing the unit closer to the pins. Worked for me.
Mike
Jan 01, 2009 | Tomtom RIDER 2nd Edition GPS
Tomtom rider 1 not charging when on bike
TOMTOM are VERY aware of this problem. but deny it is an issue!
I had the same problem, they sent me a new shoe after weeks of emails. I told them that the shoe is not the problem, it's the connector on the back of the TT1. Because of the springloaded pins fitted to the shoe and the poor quality connectors on the TT the normal vibration on a motorcycle causes the pins to wear holes in the connectors on the TT causing intermittant connection.
As the cost of repairing or replacing these connectors is very high and there are a large number of units that would require this repair TT are ignoring it.
I'm now looking at a way of bypassing the connector altogether.
A temporary solution appears to be to smear the contacts on the back of the rider with a little petroleum grease or WD40 - seems to work for a couple of weeks at a time.
Sep 01, 2008 | Tomtom RIDER GPS Devices
Tom tom rider version not charging via bike cradle either via direct connection to the bikes battery or when connected to an aux power socket. There is also no sound while attached to the car cradle /...
I recently had a bit of success with TomTom. My TomTom Rider 1 did not charge on the bike cradle, there is a known problem with the early cradles. TomTom have developed a TomTom Rider 1 replacement cradle (updated) and if you push hard they will wend you one in the post free of charge.
Jul 27, 2008 | GPS
Tomtom Rider 2 Europe Motorbike GPS 3.5" screen Touch , Bluetooth GPS Receiver Logo
296 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
