Maytag 4000 Doesn't spin
I have a series 4000 maytag front loading wash machine. The problem is that it makes a loud screeching sound during the spin cycle
You have bad bearings on the drum. This is typical for Maytag and some other machines. A very expensive repair.
Jul 30, 2015 | Maytag Washing Machines
Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Does sound like it's not balanced properly, or maybe it's set on drip dry instead of spin , basic solution i know but often the best lol ,
Nov 26, 2007 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag 4000 with no extra high spin out.
sounds like a transmission problem . gotta turn the old girl over and look for something loose or out of place
Feb 06, 2015 | Maytag Washing Machines
Maytag Neptune rotates but not in spin mode
see the causes:
t doesn't pump or spin
frozen puller or belt broken pump, lid switch defective
It pumps, but doesn't spin
lid switch defective+motor coupler defective+belt broken+clutch worn+drive motor faulty+transmision not shifting properly+basket worn.
It spins only with the lid closed
lid for security reason.
see the diagram
Jun 19, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
Maytag neptune model mah 4000 awq has clothes that are wet when done and a small pool of water in the tub (front loader), door locks, motor agitates and spins back and forth, pump hoses are clear, during...
check to see if the door locked is lit up and the door is locked. if it is not locking it won't spin full speed. the last one I had needed a wax motor to lock it and a new control board since the wax motor shorted out the control board
Nov 04, 2009 | Maytag Washing Machines
Solution is right ...its your MCU Easy repair.
~Baloo
May 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
