Question about Canon PIXMA MG8250 Inkjet Multifunction Printer - Colour - Photo/Disc
5C00 Error How to clear 5C00 error?
SOURCE: error 5C00 on Canon iP90
i took out both printer cartriges then put them back in. there was a window that asks if you replaced the cartriges; click yes then click on the black and color boxes indicating you replaced (re-inserted) both cartriges. for me the light stopped blinking (previously, it was blinking orange 4 times). next i tried to print but only yellow and black appeared. i then cleaned the head 2 times.
to clean:
-go to control panel
-click on printers
-click on printers and faxes
-find your printer, right click on it
-click properties
-find the maintenance tab
-click cleaning
(clean a couple of times if needed)
hopefully it works...
Posted on Jan 31, 2008
jeffdynamics
  • 18 Answers
SOURCE: Service error 5C00 or 5100
5100 Make sure nothing is blocking the cartridge movement, if not requires service.
Posted on Apr 16, 2008
SOURCE: canon printer ix4000 service error 5C00
bagai mana caranya menanggulangi eror 5c00 Printer ix4000, mohon petunjuknya
Posted on Jun 07, 2009
  • 155 Answers
SOURCE: error reding 5C00
Try the following procedure:
1)Turn off the printer.Press and hold the Resume/Cancel and Power buttons
at the same time.
2)Release the Resume/Cancel button.(continue to hold down the power button)
3)While continuing to hold down the power button press the Resume/Cancel button
3 times then release both buttons.
4)The LED should now be green.Press the Resume/Cancel button 4 times.The led
should be green.
Power it off and back on and you should be good to go!
Posted on Feb 01, 2010
PCTechOnline
  • 532 Answers
SOURCE: I get Service error 5C00 for my Cannon i80
Canon USA has a down loadable file for the manual.
Here is the link.
Here is what is being said of this error on the forums:
Fixing this error is much easier as it looks. Unplug the printer completely. Move the ink cartridge cradle gently to the left. Over to the right at it's usual resting place you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a microfibre cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now. But it's worth checking for any paper caught near the ink pad
Posted on Apr 28, 2010
Canon printer ip90V is showing Error 5C00
A 5c00 error relates to the sensor in the purge unit, which is where the carriage stops on the right hand side of the printer. You may find that the ink has built up in the purge unit and it will need to be washed out in warm water. The sensor in the purge unit will need to be removed before washing the unit. Problem is getting the purge unit out is quite tricky.
Rating the solution is highly appreciated.
May 25, 2010 | Canon PIXMA iP90v Printer
Service error 5c00 canon ix4000
Purge cam sensor error [5C00], PG position error [5C10]
Mar 23, 2010 | Canon PIXMA iX4000 InkJet Photo Printer
Canon ix4000 error 5c00
error [5C00] & Light Blinking 4 times = PURGE CAM SENSOR ERROR
you may need to replace :
- PURGE UNIT
- LOGIC BOARD ASSY
Oct 14, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Error Code 5c00 for Canon ix4000
5C00 is a purge assembly error, it happens when paper is caught stopping the cleaning blades from working properly, or when the purge unit is just worn out.
Aug 20, 2009 | Office Equipment & Supplies
Canon iP90 error 5C00
5C00 is a purge unit error, thats the cleaning unit on the right where the printhead parks. Look inside with a flashlight, if nothing is blocking it's operation, you willl need a new print engine, qm2-2020-000 around $150.00
Jul 21, 2009 | Canon PIXMA iP90 InkJet Printer
Error code 5C00
Error code 5C00 refers to a purge unit error. This is a service call error and requires that the printer be taken into a canon authorized service facility for diagnostic and proper repair.
May 15, 2009 | Canon I900D InkJet Photo Printer
Canon printer ix4000 service error 5C00
Apr 01, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Canon ip3000 shows service error 5c00
5C00 is Purge unit error.Check for object around the purge unit.
Feb 23, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Mar 27, 2008 | Canon BubbleJet i560 InkJet Printer
Service error 5C00
Service error 5C00 might indicate the purge system.
The "rattling sound " is probably coming from the (gears of-) socalled purge unit. May be one ( or both) of the ink tanks is not properly put back in again,or the printhead-lock is not locked. and the purge system is blocked.
Remove the ink tanks and remove the printhead, closw the printhead-lock, close the printhead cover, switch the printer of, switch the printer on again. If the rattling sound is still there, than you might have an expensive problem to be solved.
If the rattling sound is gone, there is probably something wrong with the printheadlock.
Mar 12, 2008 | Canon i80 InkJet Printer
Canon PIXMA MG8250 Inkjet Multifunction Printer - Colour - Photo/Disc Logo
old marine
old marine
