Question about Dishwashers
Aeg favorit 80850 dishwasher drain blocked. Water will not drain. Hose is ok can not see any dirt or blocking parts.
Our 8 years old Favorit shows drain block. I have disconnected the drain hose to see if the water come out through gravitation. it does only to a limited degree. I then try to blow in to the hose to see if air comes in and nothing. If I **** in the hose I can create pulling force to drain it completely.
4 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Dishwasher won't drain?
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Jul 15, 2009
  • 98 Answers
SOURCE: 4 year old dishwasher no longer draining water
check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
Posted on Jul 26, 2009
caroldon
  • 17130 Answers
SOURCE: The ribbed drain hose on
These drain hoses are universal types except that the connectors may differ. The different types of these hose - flexible ribbed- are found in almost all the stores that cater to pneumatic products.
Also you can source the original type from any dishwater/washing machine spares parts stores.
The hose can be removed after releasing the holding clamps and releasing the hose-- pull out .
Since these hoses are slightly flexible they are pushed into the drain ports and clamped.
you can get a good picture of this if the washer is moved forward.
Also take the hose along so that the store will recognize the product and make it easier.
In most cases the hoses are cheaper if they are sourced from the tubing shops than from the dishwasher spares store.
Posted on Mar 29, 2011
AEG FAVORIT DISHWASHER, PUMP KEEPS GOING WHEN TURNED OFF, UNLESS TURNED OFF AT MAINS
check the sum pump drian valve make sure it not cog up with tash because if it block can cause the drain pump to ruin ok
Nov 02, 2017 | AEG Dishwashers
I30 message on aeg favorit 50879 u
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Dado
Jun 17, 2014 | AEG 24 in. Favorit 40850 Free-standing...
Where is the sink spigot located ? I have a fault #20 showing on the dial
That will be the drain hose connection to the sink drain pipe probably under the sink. Google sink spigot in images and you can see what it looks like. I take it it is blocked..
Jun 15, 2014 | AEG 23 in. Favorit 50750Vi Built-in...
Hi my machine flashes up with ared light and says 'drain blocked' nothing happens and there is water in the bottom of the machine.
You need to pull out the machine, disconnect the drain hose running out the back of the machine from where it connects to..... (may be the sink trap or into the plastic waste pipe). Check the hose for a blockage and also where the hose connects to. Hope this helps. Alex.
May 24, 2011 | AEG 24 in. Favorit 80850 Free-Standing...
Message -spray arm blocked
Check water pump inside the machine for its full speed.If the speed is low check the capcitor and replace.
May 27, 2010 | AEG 24 in. Favorit 80860iW Built-in...
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
No water fill
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | AEG 24 in. Favorit 40850 Free-standing...
AEG Favorit 60820 sensorlogic .30 code water problem
You can unclick the top part which gives better access to the lower part with the blockage. Hot water, pipe-cleaners, cable ties, bits of wire can all be employed to get the grease out.
Jun 06, 2009 | AEG 24 in. Favorit 60820W Free-standing...
Remove bottom front panel AEG 6081
before you take the pump out, if drain hose goes into a spigot on the sink trap, take drain hose off and check hose and spigot are not blocked. this is very common.
can't remember anything special about the screws - used to be philips head but may have changed to multi-spline.the top ones are indeed obscured by the door panel but you can normally get to them with a stubby screwdriver or take the outer door panel off - just a few screws
Sep 06, 2008 | AEG 23 in. Favorit 50750Vi Built-in...
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
