Question about Yard Machines Garden
8 HP ride on rover mower torque settings for head bolts
8 HP colt8 rover, need to know torque settings for head bolts
  • 190 Answers
SOURCE: cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Posted on Mar 26, 2009
  • 10865 Answers
SOURCE: 2-stroke engine re-assembly bolt torque settings
http://p-car.com/torque/ here is a chart of common torque settings. Just clik on this link or type it into the browser line on your computer.
Posted on May 04, 2009
  • 93 Answers
SOURCE: Cylinder head bolt torque setting for a
Search Briggs on the Web, You can order Manuals there. The torque is in in. pounds. Need more info ! A just get them tight and all about the same will work, stagger the bolts in the Head when tightening ( one bolt, one side then the other until done.) Then check them all.
Posted on Sep 15, 2009
  • 252 Answers
SOURCE: NEED TORQUE SETTINGS FOR 18 HP MODEL
hi
con rod bolt torques are 150 in/lb or 12.4 ft/ lb
cyl head bolt torque is 220 in/lb or 18.5 ft/lb
here is website for parts and manual
http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=31h777-0297-e1
i would torque them in this sequence
start from bolt centre top , then bolt centre bottom, then bolt left upper , then bolt btm right, then bolt bottom left , then bolt upper right , then bolt centre left
should be 7 bolts 5/16 x unc
check out website its good so is www.partstree.com
cheers paul
Posted on Aug 17, 2010
  • 721 Answers
SOURCE: hi, I have an older Murray ride on mower, small
Sounds like you have some sort of seize up problem in your deck assembly. Have someone help you with this check, start your engine, engage the blade or blades, and have someone watch the shoot from a distance to see if blade or blades turn. if not then your problem is in the area of top pulley and blade or blades. You may need to replace or loosen the pulley to blade shaft. Sometimes this part is repairable where you can replace bearings or bushings and sometimes the whole unit needs to be replaced. Look to see if there are grease fittings on this unit. Try oil anywhere it will flow down in between areas that may be seized and work on loosening up the pulley blade assembly.
If this doesn't help, go to some of your local mower repair shops, they may be able to sell you a used part. Remember to bring mower information with you so they can help you with the correct part.
I hope this has been helpful to you. GOOD LUCK.
Posted on Jul 19, 2011
Torque on head bolts
Torque on head bolts Robert, Head bolt torque for what? RE POST make model # and your complete question, so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 31, 2016 | Garden
Need to know what is the pattern to snug bolts on head gasket
criss cross, corner to corner. More important is the torque settings.
Oct 02, 2015 | Craftsman 675 Torque 190cc 21" Briggs ...
How to access cylinder head on husqvarna rider?
?? Why do you need the head torque? Was this an overhaul? Consult the factory service manual. If not possible, torque setting depend on several factors, .. application, (cyl. head), engine mounts, etc.. this is mainly determined by bolt and nut size and relative to the application. There are charts that recommend toque values relative to bolt sizes. I can't tell you because I don't know what size the bolts are! Hope this helps!! Goolge it!
Aug 17, 2014 | Husqvarna Garden
What is the torque sequence on a 18 hp. v twin motor briggs and stratton motor
If your talking about the cylinder head bolts. I don't know the exact sequence but I was a truck mechanic for forty years and went by the rule of thumb to start in the center and work towards the ends. That way you avoid a buckling o9f the head.
Jun 16, 2014 | Craftsman 42" Briggs Stratton 20 hp Gas...
Torque specs...
The standard specs for grade 5 head bolts are:
5/16" bolt with 1/2" head is 26nm or 19 ft lbs.
3/8" bolt with 9/19 head is 45nm or 33 ft lbs.
junkl
Aug 23, 2013 | Murray Garden
Looking for cylinder head and connecting rod torque specs for a Kohler K582 engine
hi there
pauly 46 here
for your information required see the download of service manual from below
http://www.scribd.com/doc/3852484/K582-Service-manual
but i have the required settings for you in the mean time cyl hd bolts 35 ft /lbs
and con rod bolt torques 5/16 " use 200 in/lb torque
or if 3/8 bolts use 300 in/lb torques
service manual is 92 pages long but helpfull
cheers hope it hepls
pauly46
May 03, 2011 | Cub Cadet Garden
Need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Jul 10, 2009 | Garden
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
Garden Logo
15 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
