Question about Kitchen Appliances - Others
Main craft pe - Kitchen Appliances - Others
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
How do I get to the nether on Mine craft pocket edition?
You can get to the nether on Pocket Edition by building a portal.This website has all the steps to making a nether portal to get to the nether world.
http://m.instructables.com/id/How-To-Build-Nether-Portal-For-Minecraft-PE/?ALLSTEPS
Jul 17, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Mine craft PE is not that great because u can not play to people at the same time because the person that join gets all the problems
Please do not attempt to play mine craft PE on your sewing machine as it is not rated for that platform and may result in serious death or dismemberment.
Jul 10, 2014 | Sewing Machines
Nu vreau sa mai apara pe ecran aceasta reclama
nu doresc pentru nimic in lume sa mai apara pe ecran:MUNU SETUP, OSD MAIN CONTROLS LOCKED, BRIGH.... SUNTETI LIPSITI DE BUN SIMT . ON OM SINGUR SI BOLNAV NU SE POATE FOLOSI DE DESKTOP . AJUTATI-MA SA AM ECRAN CURAT CA SI BANII PLATITI PENTRU ABONAMENT
MULTUMESC
Aug 11, 2013 | Philips 190B6CB/27 19" LCD
I just purchased a viewsonic e771 17" crt monitor, but don't have a manual. How can I get a manual for this monitor?
He is a link to the main support page for this monitor.. The maunal is located on the right side, but instead of maunal it is called user guide.
http://www.viewsonic.com.pe/support/desktopdisplays/crtmonitors/e2series/e771/
Mar 07, 2011 | Computers & Internet
Hi my name mohit manchanda. actually i wanna instal win xp in my [pen drive but after copying files 100% than sytem show fetal error
All that's needed is a bootable USB Flash drive with at least 256 MB of storage capacity and a Windows Setup CD. Using the program Bart PE Builder (Freeware), you can install Windows XP on the flash drive, along with other software as needed (and as available space permits).
Here is the link of Bart PE Builder
http://69.90.47.6/mybootdisks.com/mybootdisks_com/nu2/pebuilder3110a.exe
Here is the procedure
This will help you create your very first BartPE CD. It assumes that you are using Windows XP.
Make sure that your system has about 500MB of free disk space!
Download the latest PE Builder version (self-installing package) and install it.
Start PE Builder (pebuilder.exe). When you start PE Builder for the first time it will ask if you agree with the license agreement.
Now PE Builder will ask to search for windows installation files. If you don't have your windows XP setup/installation files on your system you must insert the original Microsoft Windows XP installation/setup CD at this point.
The files you have at c:\windows are not installation files. They are your already installed files!
Click "yes" to start searching. PE Builder will now search all fixed- and CD-Rom drives for Windows installation files. This will take some time. When more than one valid location is found, a dialog will appear where you can select which location you want to use.
At the main PE Builder dialog, select the "Burn to CD/DVD" option. When you are using an erasable medium, make sure that the "AutoErase RW" option is enabled. The "burn using" option should be set to "StarBurn". Select your CD writer device from the Device list.
Hit the "build" button. PE Builder will now ask you to create a BartPE directory, answer with "yes".
The license for your Microsoft Windows XP product is shown. Read it and agree to it to continue.
PE Builder will now start building BartPE. This will take a few minutes.
You will see a lot of files getting copied and/or decompressed, the ISO image build and the data recorded to your CD/DVD writer.
If the data verify was correct and there where no errors reported you can boot the CD/DVD!
After that set your PC BIOS to boot from USB,then restart.
That's it.
Dec 11, 2009 | Dell Dimension 4600 PC Desktop
Where can I get another motherboard for my Memory Craft 8000
most janome dealers wont sell you a main pcb but you can try one locall to you, if your machine is under 5 years old it should be under warranty so i would recommend taking it to a dealer
Jun 23, 2009 | Janome Memory Craft 9000 Computerized...
Can i install xp on pendrive ?
  1. Put the cd with xp on it in the cd rom
  2. plug your pen drive into your computer
  3. open "my computer"
  4. drag and drop the cd to the pen drive and it should copy the files to it.
Let me know how it goes.
Jan 05, 2009 | Microsoft Windows XP Professional
Kitchen Appliances - Others Logo
26 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
