Av1 and av2 not working proerly
Onida tv
Shuttle83
  • 1139 Answers
SOURCE: blue screen-tv doesnt recognize dvd player
Hello crawf and Saffyrre,
I have seen this issue before, and I have good news and bad news. The good news is the problem is caused by an electronic bypass circuit, The circuit is between the AV derived from the RF input connector (for cable TV and off air TV) and the AV derived from the DVD player Audio Video input jacks. Hence the problem of being able to plug the DVD into other TVs and it works. Now my question to each of you is; Does the TV work on off air and or Cable TV.
This might range from a cold solder joint on the circuit board, to a component actually going bad. I would suggest taking the set to a qualified TV repair shop and getting an estimate. If the cost is right have it repaired, if the cost is not right replace the TV with a new one.
If you do decide to replace the TV could you both send the bad TVs, so as I could figure out what is causing this problem, design a fix for it and then provide an actual online solution to this problem because this is happening way to much for it not to be a systemic problem with all of these Hello Kitty TV sets.
Thank you both,
I hope this helps,
Shuttle83
Posted on Nov 25, 2007
welcomejee
  • 10594 Answers
SOURCE: My sony vega tv switches av settings
Will you specify Model number of Sony Wega TV to understand its circuitary.
Posted on May 31, 2008
welcomejee
  • 10594 Answers
SOURCE: Green symbol AV2 won't go away! Sony Trinitron KD-28DL11U
You need to have original Sony TV remote and press Display button on it, on-screen display will disappear.
Posted on Nov 25, 2008
bernardlunda
  • 318 Answers
SOURCE: Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Posted on Apr 24, 2009
  • 56 Answers
SOURCE: Problem of Audio in Philips TV, Model - 21RF VardanSL
check option bites find it on crt or back cover to enter serv mode coll following comands
062596 menu or display the data will appear select options and set by vol and ch keys
Posted on Jul 12, 2009
Onida ky surround not funtioning av2
Main IC fault. Replace it. Av selection section inside it is not working. Damaged. http://electronicshelponline.blogspot.com/
Jul 30, 2015 | Televison & Video
Sanyo tv change to av1 av2
Whenever your change from one video source to another, your tv automatically switches input modes (i.e. av1 to av2) to faciliate the source coming into your tv.
Aug 10, 2014 | Sanyo DS32920 32" TV
How do I hook up a dvd player
yellow, white and red wires usually connected to the same name same colors on both devices.
Does the tv need to be on a certain channel? YES, try change to all ex: VIDEO 1, VIDEO 2, DIGITAL, ANALOG, HDMI or any according to tv sysem
Oct 27, 2013 | Seiki Digita Seiki LC46G82 46 in. LCD HDTV...
Hi there, I am getting some problem in connecting my DVD player to LCD TV on AV2 port. If I connect the same to AV1 port,it works fine but that port is already in use for my set top box so if I want to...
I expect if you look at the menu you will find that AV2 is set up as S-Video or Component etc. etc. Set it up as composite or RGB. The same as AV1.
Jan 20, 2011 | Televison & Video
AV1 AV2 hook up
you should find them by seeing if you can find ports that are colored yellow, red and white
Apr 01, 2010 | LG 42LC2D 42 in. LCD HDTV
Srt 2219b im try to setup to watch dvd and vcr. is there a trick.
If you are connecting your DVD and VCR to the TV using Scart leads, simply go into TV input option on your tv remote and switch to AV1 or AV2. i.e AV1 for VCR or AV2 for DVD player.
Mar 17, 2010 | Sylvania SRT2232S 32" TV
I can't set it up!
The Wii will work on the TV. Just try plugging into the ports labeled AV1 or AV2. The red, yellow, and white holes should line in a row with AV1 and AV2. After you have them plugged in, press the INPUT button on the TV or the remote to get to the AV1 or AV2. It should work after that. :)
Jul 08, 2009 | Toshiba 37AV502U 37 in. LCD HDTV
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Mar 20, 2009 | Sanyo DS13204 TV
When i tried with TV AV buttons with DVD it is not working for AV1 and AV2 only audio is available no video
Did you unplug it from the wall. try unplugging if from the wall for two days and try it again.
Dec 22, 2007 | Polaroid TTM-2401 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
