Question about Casio MS-10VC 10-Digit Display Calculator, Pink
Why do I get 111.1111... when I calculate 100+10%?
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
Tip
Use ecalc.tk for all your online calculator needs!
<a href="http://www.ecalc.tk/">http://www.ecalc.tk/</a> has everything you need to calculate anything! It currently offers online Scientific Calculators, Credit Card Calculators, Annuity Calculators, Mortgage Calculators, Interest Calculators, Currency converters, Savings Calculators, Paycheck Calculators, and MUCH MUCH MORE!!! ALL ONLINE!!!
on May 27, 2011 | Computers & Internet
How do I calculate Present and future value with Casio fx-115ms?
The calculator does not have a TVM application, so you cannot perform these calculations.
Mar 18, 2014 | Casio FX-115MS Scientific Calculator
Where is the combination button on SHARP EL-501W calculator?
There is no such key on this calculator. You can calculate it using factorials. To calculate nCr you can calculate n! / (r! * (n-r)!).
Apr 30, 2012 | Sharp EL-501WBBL Calculator
How to use the log fucntion
To calculate the natural logarithm of a number, enter the number and press the LN key. To calculate the natural logarithm of a calculated result, simply press the LN key.
To calculate the natural logarithm of 3, press 3 LN
To calculate the logarithm to any other base, calculate the natural logarithm and then divide by the natural logarithm of the base.
To calculate the base-10 logarithm of 3, press 3 LN / 1 0 LN =
Apr 04, 2012 | Texas Instruments BA-II Plus Calculator
Online calculator that you don't have to buy
On Windows based computers you already have a calculator. Look for it under Start>All programs>Accessories>.
Also, with Windows based systems, you can download (free of charge) Microsoft Mathematics 4. Launch a Google search. Download the version compatible with your operationg system (32 bits or 34 bits)
Mar 13, 2012 | Casio Office Equipment & Supplies
How to calculate 17^23mod55 in casio scientific calculator fx-991MS?
Using the Windows calculator in scientific view, we get:
17^23 = 19,967,568,900,859,523,802,559,065,713
which is 29 digits long, ie much longer than the capacity of most calculators.
Because both 17 and 23 are prime numbers, it isn't possible to simplify this calculation, so you will need to use find a calculator that has sufficient capacity to be able to handle numbers of this length.
The xnumbers add-in for Microsoft Excel can also be useful for this sort of calculation (do an internet search for it).
Using the Windows calculator, MOD55 of the above number is 18.
Jun 30, 2010 | Casio FX-115MS Plus Calculator
MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Sep 08, 2009 | Casio MS-80TV Scientific Calculator
Who Repairs them?
calculators are repaired in watch works...they will give u a better service for calculators...if it s scientific calculators..then giv it to the computer service providers....but usually there s very few service providers can been seen for repairing the calculators...since it doesnt cost much!!!!
Dec 06, 2008 | HP 19BII Calculator
Casio MS-10VC 10-Digit Display Calculator, Pink Logo
78 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
