Question about Panasonic Kitchen Appliances - Others
Big end bearing change - Panasonic Kitchen Appliances - Others
2 Suggested Answers
  • 9 Answers
SOURCE: main bearings and big end bearings tension specs
This site has all the torque specs you should need make sure this is the correct engine.
http://www.davidfarmerstuff.com/C6Z06-Torque.pdf
Posted on Dec 27, 2010
Hi i have daewoo matiz 800cc can you help me by giving me the torque settings for the big end bearing caps please
You are looking for the torque settings for big end bearings and main bearings on a daewoo matiz?
Main bearings torques on a Daewoo Matiz 800cc (1999)
Stage 1: 25-30 Nm
Stage 2: 55-60 Nm
Big End Bearingsā€¦
Mar 09, 2016 | Daewoo Cars & Trucks
What is the torque setting for main bearing and big end bearing of a Toyota Yaris 1.0 1kr 3 cylinder?
Toyota Yaris Main and Big end Torques:
Tighten the main and big end bolts in sequential order and in steps two steps.
- Main bearings. Stage 1. 30 Nm.
Stage 2. 59 Nm.
- Big end bearings. Stage 1. 15 Nm.
Rotate further by 90 degrees.
Apr 09, 2015 | 2008 Toyota Yaris
Hey there 99 grand dam oil is full .but oil lamp flashes on and runs like champ starts easy has power but it sounds like a big big wheel toy rapping. as soon as i accellerate. Is it blown up or. if i...
I would say from your description that the low oil pressure is from a failed big end bearing or a main bearing. Changing the oil pump will not save it and if you continue to run the engine the end result will be a hole in the side of the block
Oct 16, 2013 | Cars & Trucks
Big end bearing
well if your going to change one you change them all, you more or less do a full overall of the crank
Mar 03, 2012 | Hyundai Motor 1993 Excel
Engine is making loud knocking noise what does this means
could be various things wrong, could be bottom end big end bearing. you need to establish where the knock is ( top end or bottom end ). if it is big end thats knocking then its an engine change ( saves messing about ) or top end ( camshaft ) then its a mornings job. hope this helps
Feb 18, 2012 | 1999 Ford Crown Victoria
2002 audi tt 225 bhp cranksharft torque settings
Crankshaft torque settings for 2002 Audi TT 225 BHP:
1. Main bearings: Renew bolts = Yes
2. Main bearings: Stage 1 = 65 Nm
3. Main bearings: Stage 2 = 90 degrees
4. Big end bearings: Renew bolts / nuts = Yes
5. Big end bearings: Stage 1 = 30 Nm
6. Big end bearings: Stage 2 = 90 degrees
7. Flywheel / driveplate = 60 Nm + 90 degrees (use new bolts / nuts)
8. Crankshaft pulley / damper centre bolt = 90 Nm + 90 degrees (use new bolts)
Nov 25, 2010 | Audi TT Cars & Trucks
How to change a front wheel bearing
start by undoing the big nut in the middle first before you do anything else ,then wheel off and remove the brake caliper so you dont strain the flexable hose ,then track rod end ,remove the caliper support bracket ,then the bottom ball joint and the suspension strut lower fixing ,put a piece of wood over the drive shaft end and just tap it so its free then remove the hub,now take it to an engineering shop and have the bearing changed with a press ,do not try to knock it out with a big hammer as its very dangerous and you could end up with a shard in your eye ,also you will need some serious circlip pliars to remove the inner circlip that hold the bearing in .
Aug 10, 2010 | 2004 Ford Freestar
I need the torque specs for the main and rod bolt for a 99 escort 2.0l engine
engine tightening torques
Main bearings Renew bolts/nuts No
Main bearings Stage 1 43 Nm
Main bearings Stage 2 85 Nm
Big end bearings Renew bolts/nuts Yes
Big end bearings Stage 1 15 Nm
Big end bearings Stage 2 90°
Jan 21, 2010 | 2004 Ford Focus
Another Big End Gone
Could you tell me exactly what you consider the big end. What is it doing or not doing.
Jul 19, 2009 | 2001 Subaru Forester
WOULD YOU KNOW THE TORQUE SETTINGS FOR MAIN BEARING AND BIG END BEARING CAPS FOR ISUZU 4JG2 ENGINE
Mains Stage 1 83nm
Mains Stage 2 167nm
Big ends Stage 1 29nm
Big ends Stage 2 45 - 60 degrees
Hope this helps
Jul 10, 2009 | 1994 Isuzu Trooper
Kitchen Appliances - Others Logo
29 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
