Question about Lite On (SOHW-832S-RETAIL) DVD±RW Burner
Upgrade pc from xp to windows 7
I need a driver for windows 7
  • 62 Answers
Can this model be upgraded from xp 32 bit to windows 7 64 bit with 2.5 gb of memory?
Yes you can however HP only supports Windows XP (32-Bit), Windows Vista (32 and 64 Bit) No official support for windows 7.
However Most modern PC's will run windows 7 and most drivers are available. Upgrade at your own risk.... There might be some drivers that you wont find and may cause problems with your PC.
But why upgrade to 64bit if you are not upgrading memory to 4GB+?
See Windows 7 system requirements Microsoft Windows
May 04, 2014 | HP Compaq Presario SR1910NX (EX310AA) PC...
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
Ethernet driver for windows 7
There does not seem to be a valid Windows 7 network driver:
http://ftp.dell.com/Pages/Drivers/dimension-3100.html#Network
You can try the driver for XP to see if that will work, otherwise you may need to buy a new NIC card.
Oct 14, 2013 | Dell Dimension 3100 PC Desktop
I am trying to upgrade from windows xp to windows 7
Windows XP will be supported to April 2014, if you have the early addition you will need to download service pack 2 and 3 to get the updates. The laptop does not have sufficient ram to support windows 7 and some device drivers may not be supported.
Sep 04, 2012 | Dell Latitude C640 Intel Pentium 4-M...
Upgraded windows 7 from windows xp pro on gateway profile 5.5, but cannot change resolution. All icons are huge.
First of all Un-installed/format it your system and re-installed windows 7 and see it happen again or not? May be, while upgrading your windows XP to windows 7 some file may be left over so while running your OS (operating system) file cannot read properly.
thanks for using FixYa Good luck
Aug 26, 2011 | Gateway Profile 5.5 PC Desktop
Why does if i upgrade my laptop to windows 7, it can't be activated? and why does my drivers where not compatible with windows 7?
Because the laptop is made before Windows 7 is made. If you try to look at the drivers website (Click Me). There is only Windows XP and Windows Vista drives that is available not Windows 7. refer to the figure
Jul 22, 2011 | Dell Latitude D630 PC Notebook
I installed windows xp on my toshiba tecra m4. How stylus pen works?
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen.
In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
Hope it helps! Good Luck!
CreativeTECH
Apr 23, 2011 | Toshiba Tecra M4-S435 Tablet PC
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
Jun 10, 2010 | Microsoft Windows XP Professional for PC
I recently Upgraded from Windows XP to windows 7 when Windows 7 was finished intalling internet connection did not work. Before upgrading everything worked fine.I did troubleshooting and it said ''No...
Hi
Win 7 is extremely touchy about network drivers. I didn't see your computer model listed but you'll need to log onto your computer manufacturers support page and download the Win 7 drivers for the network. Since your internet connection doesn't work right now I'd suggest another machine, if you have one or go to your local library with a Flash Drive and download the drivers to that. Good Luck
Mar 07, 2010 | Microsoft Windows XP Media Center Edition...
Lite On (SOHW-832S-RETAIL) DVD±RW Burner Logo
54 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Computer Links
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
