Question about Whirlwind FH-778 Air Conditioner
HOW MUCH PSI NEEDED IN HOME AC - Whirlwind FH-778 Air Conditioner
    Problem Solver:
  • 6 Answers
What gas ? depends on operating temperatures as well. Can you still buy your own gas there ?
Posted on Jun 20, 2009
Drivers disco duro hp pd 500a
http://h20565.www2.hp.com/portal/site/hpsc/public/psi/home?sp4ts.oid=5179191&ac.admitted=1401035468572.876444892.492883150
Feb 09, 2013 | EliteGroup ECS H61H2M2 Intel H61 Sandy...
High low side pressures and sight glass contains lots of bubbles
The system has a lot of air in it. If u haven't had any AC wk done on it that mean there is a leak in the system. System must be evacuated, pressurized & find the leak. Repair the leak, vacuum air from system & charge w proper AC gas. SPECIALIZED EQUIPTMENT & GAUGES NEEDED. good luck
Jul 28, 2017 | Cars & Trucks
1999 Ford Ranger AC low side pressure reads 100 psi
Was the a/c compressor running when you got this reading?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 03, 2012 | Ford Ranger Cars & Trucks
2002 ford mustang air conditioner stopped working. How do I locate the problem?
FIRST I CHECK ALL FUSES AND RELAY.TO BLOWER MOTOR IF IT STOP BLOWING.AND CHECK FUSE TO HVAC SWITCH CONTROL.AND CHECK FUSE / RELAY TO AC COMPRESSOR.IF FUSE / RELAY GOOD POWER GETTING TO AC COMPRESOR CLUTCH COIL AND LOW PRESSURE SIDE 28 PSI AND HIGH SIDE 200 PSI. CLUTCH COIL IS OPEN.IF REFRIGERANT LEVEL LOW YOU MAY NEED MORE REFRIGERANT.YOU NEED AT LEAST 28 PSI ON LOW SIDE AND 200 - 220 PSI ON HIGH SIDE.IF ALL IS GOOD STILL NO AC PROBLEM COULD BE A FAULTY AC CLUTCH CYCLING PRESSURE SWITCH.
Aug 16, 2010 | 2002 Ford Mustang
A/c recharge what is thew psi for refrigerant
Below are normal car AC pressure readings with 134A.
Normal readings on high and low side with AC OFF (static pressure) – Depends on outside temperature, but normally is between 80-105 PSI
Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s – Ranges from 25-35 PSI
Normal high side reading ranges from 200-350 PSI
Don’t assume that if adding little Freon is good that adding a lot is better! Overcharging just a little can decrease the performance of the system and possibly damage the compressor.
With the AC on the coldest setting, use a thermometer in a middle vent. Normal vent temperature readings will vary depending on the (ambient) outside temp. The vent temperature should range from around 42-55 degrees in my experience.
If normal gauge readings are obtained and the vent air is cold – STOP don’t overcharge the system. The only proper way to remove refrigerant is with a AC recovery machine so if this is being done at home I can’t emphasize enough not to over charge the system.
Thank you for using fixya and be safe.
Jun 17, 2010 | 2002 Ford Expedition
Air conditioner compressor runs - freon is up to proper level....not cooling??
BOTH High and low readings should be checked to have a better idea of what is going on with an AC system but based on the limited information… the compressor is not engaged or is not pumping. Below are some things I would check;
1. Check the high and low gauge readings with the AC on & set on MAX/Recirculate, middle vents with the engine at 2,000 RPM’s, blower speed on high.
2. Check the vent temperatures with a thermometer from the middle vents, far right & far left vents?
3. What is the outside temperature at the time the readings were taken?
4. Check to see if the condenser fan blowing strong?
5. Notice if compressor clutch is cylcling excessively.
Could be overcharged, not enough air going across condenser fins, compressor not pumping sufficiently… BOTH gauge readings are really needed to get a better idea.
Thank you for using fixya and good luck, keep me posted. Be glad to help you get your A/C running again soon.
Jun 12, 2010 | 1999 Chevrolet Silverado 1500
How do I service my A/C 2000 Chevy Impala LS
To diagnose problems, an A/C manifold gauge set is needed to read high and low side pressure readings. Avoid adding refrigerant with a simple charging kit like the ones sold at parts stores. Don’t add any stop leak, this can cause problems in the compressor, expansion valve or condenser.
Keep in mind that using an A/C gauge set and seeing BOTH high and low side readings can help in diagnosing the problem when you know what to look for. First, on a 134A system the high and low side service ports are different sizes. AC gauge sets have color coded hoses, the blue color coded hose has a connection that fits on the low side service port and the red hose has a connection that will only fit onto the high side. The yellow hose won’t hook up to anything if just checking the readings; it can be used to connect to a vacuum pump or attached to a refrigerant can or tank.
Normal readings on high and low side with AC OFF (static pressure) - Depends on outside temperature, but normally is between 80-105 PSI Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s - Ranges from 25-35 PSI - Note that on many Chrysler products a normal reading on the low side may be 15-25 PSI Normal high side reading ranges from 200-350 PSI
Both low and high side readings are lower than normal, this indicates a cars AC system is low on refrigerant and is under-charged.
If both low and high side readings are too high, this indicates an overcharged system - too much refrigerant. This also can indicate that the condenser fan is not working, is too slow or the car is overheating and heat is transferring from the radiator to the condenser.
If you are going to by the recharge kit at an Auto Parts store, With the AC on the coldest setting, use a thermometer in a middle vent. Normal vent temperature readings will vary depending on the (ambient) outside temp. The vent temperature should range from around 42-55 degrees in my experience. If normal gauge readings are obtained and the vent air is cold - STOP don’t overcharge the system. The only proper way to remove refrigerant is with a AC recovery machine so if this is being done at home I can’t emphasize enough not to over charge the system. And actually the best way to insure the proper charge is in a system, is to use an AC machine to recover the freon and then evacuate and recharge the system with the correct amount. Most cars have the specified amount on a decal under the hood.
Good luck and keep me posted, be glad to answer more questions you may have.
Jul 02, 2009 | 2000 Chevrolet Impala
The a/c on my 2006 honda pilot is not owrking and appears to have a low refrigerant charge. I want to recharge it and find the leak with die. what is the amount of 134a to be fully charged
Adding freon or topping off a cars A/C system is the most common task performed to restore performance and get cold air blowing again. However, adding refrigerant isn’t always the solution for car air conditioning problems. There can be many other things wrong besides a system being low on refrigerant. To diagnose problems, an A/C manifold gauge set is needed to read high and low side pressure readings. Avoid adding refrigerant with a simple charging kit like the ones sold at parts stores. Don’t add any stop leak, this can cause problems in the compressor, expansion valve or condenser.
*Make sure the condenser fan comes on when the readings are being checked.
With the AC on the coldest setting, use a thermometer in a middle vent. Normal vent temperature readings will vary depending on the (ambient) outside temp. The vent temperature should range from around 42-55 degrees in my experience. If normal gauge readings are obtained and the vent air is cold - STOP don’t overcharge the system. The only proper way to remove refrigerant is with a AC recovery machine so if this is being done at home I can’t emphasize enough not to over charge the system. And actually the best way to insure the proper charge is in a system, is to use an AC machine to recover the R143a and then evacuate and recharge the system with the correct amount. Most cars have the specified amount on a decal under the hood.
Hope this helps. Keep me posted, be glad to help get you cooled again.
Jul 01, 2009 | 2004 Honda Pilot
Ac compressor took one can of freon will not take other also it still is not cool
You may have over charged the system, An over charged system will also give you poor A/C performance and worst can lead to expensive repair if the compressor get's damaged.
God luck and hope this helps.
Jun 30, 2009 | 1994 Ford Escort
AC not working
A38 psi if on the high side is not suffient. It should be from 90 to 130 psi. You must be using an auto parts store refill kit that has a guage attached to it. If so, you need to try another can. If not, you should refer the problem to a qualifed ac mechanic.Also, if you notice that the ac clutch is cycling on and off with in 10 seconds, this indicates that the systemis loww on freon.
Jun 26, 2009 | 1996 Dodge Neon
Heating & Cooling Logo
78 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
