Question about Adobe Computers & Internet
Using Photoshop CS3 for Windows, many of my tools have stopped working (brushes, cloning, erasers, blur/sharpen etc). It behaves like it is responding (ex: what I try to do shows up in the history pane), but nothing actually happens. Even if I take a big red brush and try to paint all over the place, nothing shows up. The images themselves are fine - when I take them home to work on my Mac, I have no problems. So I am assuming there is a setting out of whack and I don't know what it is. It behaves like I am working on an invisible layer, but I have made sure in every case that there is truly only a single layer, that no areas of the image are selected, the settings are back to default (ex: in cloning, mode=normal, opacity=100%, flow=100%) etc etc. I re-installed Photoshop, and the dialogue suggested it was repairing some problems, so I was very hopeful, but no luck - same thing is still happening. I actually went through every one of the tools to test what works and what does not and kept a list (maybe that will make sense to someone who knows more about it). Thanks.
  • 3 Answers
Try a uninstall, then a clean reinstall. Perhaps install just PS and none of the other apps. I had a problem with Bridge not starting and our IT guy removed a ton of prefs and temp files, it seemed to help, maybe it would work for PS too. Don't ask em where they are all stored though. You might go through and remove any junk you are not using anymore either. You might also try creating a new user for the computer and opening PS in that user. If it works, something is gumming up the works in your other user.
Last measure: whipe the hard drive and start clean... very last step that is.
Posted on Jun 21, 2009
Pen pressure not working on adobe cs3
Download the latest driver of you tablet. Wacom updates the tablet drivers every now and then.
Jul 23, 2009 | Computers & Internet
Bamboo pen eraser works as a brush in photoshop
Try closing ps3 and then reinstall your Bamboo software. Then open ps3 and it should work.
Apr 03, 2009 | Computers & Internet
Pressure sensitivity problem in Photoshop CS3
Before you start Photoshop press and hold the shift key and wait until photoshop has loaded.
This should take care of the problem.
Feb 11, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
OK, I found the problem -- if you open photoshop with the mouse (whether it be through the quicklaunch bar, start menu, or desktop icon), the pressure sensitivity doesn't work. If you open it with the stylus or function button (I have a function button mapped for photoshop now because of this, since there's no icon on my tablet's display with how I have my display set up) the pressure sensitivity works fine.
A quick KIND of fix, but until Adobe actually does something about it, this is probably the easiest way to do it.
Jan 02, 2009 | Wacom Intuos3 Graphic Tablet
Cannot achieve accurate adjustment of Photoshop's cloning tool.
gillesp, I tried to replicate what you were saying and I couldn't 'make' it happen. I was thinking along the lines that you had some airbrush setting on, but even that would not reduce the clone amount by much.
something you can try is to go to your brush size drop-down pallete (in the top right corner) and across to the options arrow and down there there is "Reset Brushes" - this will remove all your custom brushes and reset it to installed defaults.
Another thing, I don't know how much you know about this, so forgive me if I'm telling what you know: When you have the rubber stamp tool or paint brush or pencil tool or eraser selected, there is a drop down option of brush sizes and types in the top left corner of the window under the menus - here you can select the size of brush, but also change the characteristics of the brush, whether the edges are soft or hard and its size and intensity. If you weren't aware of this, try adjusting these settings.
**.The best way to acknowledge contribution is to rate it's relevance.**
Dec 28, 2008 | Adobe Photoshop CS for PC
How to delete someone using Adobe Photoshop CS3?
It will depend on the background as to how easy or hard this will be.
Read the help files on using the Cloning Stamp.
First I would cut out the person(s) directly adjacent to the person you want to remove (take your time to get this done accurately - enlarge the view to say 300% - note that you can do sections at a time and ADD to the selections until you have all of the people you want - you only need to do this along the edges of the area that you want to erase the person from - COPY the selection, do not CUT the selection).
Paste this back as a new layer. Slide this to one side.
The reason for doing this is to make the next step easier without having to worry about working up to an edge.
Now working with the background layer:
If the background is easy - use 100%, then blend in by selecting another cloning area of a similar background and use it sparingly at say 25% to make the new area look different from the original cloning area. I would just remove "noticeable" objects - possibly by just selecting a spot and clicking once (doing this as many times as you need to.
If the bacground is difficult - you will need to "construct" the background using the Clone Stamp - for instance, if there is a tree branch that needs to be extended through the new area - you may have to carefully clone it bit by bit until it looks right - don't forget to clone from different areas if the background is trees as trees do not tend to have long straight branches.
When you have done all of this, go back to Layer 1 (the new one you created earlier) and slide this back into position.
Under Layers in the Menu Bar - defringe the image (layer 1) - this will blend it back in better (experiment with the number of pixels). Then flatten the image.
May 20, 2008 | Adobe Computers & Internet
Please help how to clear text in a photo in the photoshop Element 2.0
Look for a "clone" tool or brush. I'm not sure if Photoshop has one...but it's a handy way to "erase" text from the picture by filling in the text from the surrounding picture elements.
Jan 12, 2008 | Computers & Internet
Download problem
here you go:
Adobe Photoshop CS3 INFO:
Adobe Photoshop CS3 software, the professional image-editing standard and leader of the Photoshop digital imaging line
Adobe Photoshop software, the professional image-editing standard and leader of the Photoshop digital imaging line, delivers more of what you crave.
Groundbreaking creative tools help you achieve extraordinary results. Unprecedented adaptability will let you custom-fit Photoshop exactly to the way you work. And with more efficient editing, processing, and file handling, there’s no slowing you down.
Create with unmatched power
Timesaving file handling with Adobe Bridge (formerly the File Browser)
Multitasking.Take advantage of compact floating mode in Adobe Bridge to process images while simultaneously working in Photoshop.
Viewing options
Easily browse your Adobe Creative Suite and other graphics files in Adobe Bridge; present your images with features like Slideshow and Filmstrip mode; scale thumbnails to any size using a slider; and view and edit metadata.
Automated batch processing
Automatically process batches of images in Adobe Bridge to rename, convert format, adjust exposure, create a web gallery or Adobe PDF Presentation, and more.
Rating and labeling
Quickly rate and label photos in Adobe Bridge so you can instantly bring up your best shots.
Sophisticated search
Easily find any image using sophisticated search capabilities in Adobe Bridge that let you specify a variety of parameters. Save searches as Collections that you can recall anytime.
Professional color and tone control
Match Color command
Achieve a consistent look between package shots, fashion photos, and more by instantly matching the color scheme of one image to another.
Color Replacement tool
Easily change the color of any image area while retaining the original texture and shading.
32-bit High Dynamic Range (HDR) support
Create and edit 32-bit images, and combine multiple exposures into a single, 32-bit image with expanded range?from the deepest shadows to the brightest highlights.
Histogram palette
Monitor color changes to your image in the Histogram palette, which dynamically updates as you make adjustments.
Shadow/Highlight correction
Quickly improve the contrast of over- or underexposed areas of an image, including CMYK images, while preserving the overall balance of the photo.
Color management guidance
Get precise, consistent color from display to output with helpful color management guidance.
Intelligent image editing
Revolutionary Vanishing Point
Achieve amazing results in a fraction of the time with the groundbreaking Vanishing Point, which lets you clone, paint, and paste elements that automatically match the perspective of the surrounding image area.
Image Warp
Easily create packaging mock-ups or other dimensional effects by wrapping an image around any shape or stretching, curling, and bending an image using Image Warp.
Spot Healing Brush
Effortlessly retouch photos?including 16-bit images?in a single click with the advanced power of the new Photoshop Spot Healing Brush.
Healing Brush
Perform expert retouching to remove dust, scratches, blemishes, wrinkles, and other flaws with minimal effort using the Healing Brush
Essential photography tools
One-click red-eye correction
Instantly neutralize red eyes with the one-click red-eye correction tool, which supports 16-bit images and lets you set pupil size and darkening level.
Optical lens correction
Easily correct common lens distortions, such as barrel and pincushion, and fix chromatic aberrations and vignetting.
Smart Sharpen
Easily counteract common image blurring with fine correction control based on the specific blur types: motion, lens, and Gaussian.
Advanced
noise reduction
Polish digital photos with advanced noise correction in high-ISO shooting plus JPEG artifact reduction.
Camera raw workflow enhancements
Process an entire photo shoot in a fraction of the time by simultaneously adjusting color, curves, cropping, and more?and continue working in Photoshop! With support for a comprehensive range of digital cameras, Photoshop lets you automatically adjust settings, convert to Digital Negative (DNG) format, and apply nondestructive edits to batches of images.
Comprehensive 16-bit support
Perform precise editing and retouching with support for 16-bit images in core features, including layers, brushes, text, shapes, and more.
Crop and Straighten command
Scan multiple images at once and let Photoshop automatically straighten and save each image as an individual file.
Design freedom
Flexible layers
Composite images, text, and effects on hundreds of layers that you can organize with up to five levels of nesting and save in different combinations as Layer Comps.
Painting and drawing tools
Create or modify images with a wide assortment of professional, fully customizable paint settings, artistic brushes, and drawing tools.
Special effects filters
Achieve amazing results with more than 95 special effects filters. Easily preview and apply more than one filter at a time from the Filter Gallery.
Advanced type control
Add vector-based text that you can edit at any time, format, warp, place on a path, convert to outlines, and use for masks or other special effects.
Advanced web capabilities
Create sophisticated web page elements with rollovers, transparency, image slicing, and more.
Web animations
Quickly create dynamic GIF animations?using one or more images?directly within Photoshop by taking advantage of the new Animations palette and layer palette animation options
Customize with unprecedented adaptability
Adaptable workspace
Custom menus and keyboard shortcuts
Set up and save custom menus and keyboard shortcuts for quick access to the features you need.
Custom, task-based workspaces
Reduce onscreen clutter by choosing from task-based workspaces, or create your own with just the tools you need.
Adobe Help Center
Quickly get answers from the new, floating Adobe Help Center window with improved search features and convenient, task-based topics.
History Log
Automatically track all editing steps within your Photoshop files. Export steps to a text file or save them as part of image metadata for easier documentation of your work, file audits, and more.
Flexible measurement systems
Enter precise numeric values in inches, pixels, and other measurement systems. Even enter different measurements on-the-fly without changing global settings
Automated image processing
Links: http://rapidshare.com/files/74640212/photo_cs3.part01.rar
http://rapidshare.com/files/74669474/photo_cs3.part02.rar
http://rapidshare.com/files/75514140/photo_cs3.part03.rar
http://rapidshare.com/files/75542536/photo_cs3.part04.rar
http://rapidshare.com/files/75575871/photo_cs3.part05.rar
http://rapidshare.com/files/75712872/photo_cs3.part06.rar
http://rapidshare.com/files/75732517/photo_cs3.part07.rar
http://rapidshare.com/files/75751914/photo_cs3.part08.rar
http://rapidshare.com/files/75762829/photo_cs3.part09.rar Pass: freshdl.com Or http://rapidshare.com/files/66187460/AP.CS3.sxforum.org.part1.rar
http://rapidshare.com/files/66199878/AP.CS3.sxforum.org.part2.rar
http://rapidshare.com/files/66212869/AP.CS3.sxforum.org.part3.rar
http://rapidshare.com/files/66254078/AP.CS3.sxforum.org.part4.rar
http://rapidshare.com/files/66276200/AP.CS3.sxforum.org.part5.rar Pass: sxforum.org
Dec 13, 2007 | Ulead CD & DVD PictureShow 3 Deluxe for PC
Computers & Internet Logo
94 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
