Question about Sony KDF-50E2000 50" HDTV
Kdf-50e2000: Shuts off by itself, lamp blinks 4
Kdf-50e2000: Shuts off by itself, lamp blinks 4 times, pause, repeats, etc. After a rest turns on normally, but does it again. The shorter the rest interval, the quicker it happens after turning on again. Overheating problem? If so, what are some of the causes?
I have taken the back cover off, blown it out, and verified the fan is running. Fan doesn't seem to be moving much air. Is there a filter somewhere?
  • temp4jtjones Jun 20, 2009
    Thanks. Any idea where I can find what voltage it should be getting, before I break out the fluke?
    Does anyone happen to know what voltage is supposed to go to the fan? (Or where I can find that info?)
I just had this issue. I think this solution worked for me. (We'll see after watching for a few more hours.) The TV was intermittently cutting off and then turning back on every 90 seconds or so. It was as though the power was barely breaking contact every once in a while. Kind of frustrating considering that it is a $1000 TV.
The fix I used is in this thread at the URL below. There is a photo of the problem source. I do not think you need a new $160 lamp. The problem is a little "switch" that makes contact between the lamp and the ballast (power regulator).
http://www.agoraquest.com/viewtopic.php?topic=34458&forum=34
The "switch" is not so much of a switch as much as a thin piece of metal that makes contact with the lamp. See the photo in the discussion thread. I bent it out about a quarter of an inch and then reinstalled the lamp. So far so good.
I will post again if the problem crops up again.
Posted on Jul 07, 2009
  • 139 Answers
Four blinks is a fan error, I don't think that set has a filter but may have more than one fan. If the fan blades have a lot of dust on them that can cause slow rotation, can just be a bad fan or improper voltage going to the fan.
Posted on Jun 19, 2009
Tv will not stay on
If tv shuts off and turns back On itself than lamp is weak and need to be replaced.
If tv shuts off but does not turns On itself than you will see red light blinking on tv front, let me know how many times it blinks, there would be pause of 3 seconds in blinks so count pause to pause and post here to provide you helpful info about problem.
Thanks.
May 24, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Red Light Flashes twice KDF-E50A10
Are you putting the lamp cover back in place before trying to turn the set on? The 2 blink error is a temperature error you might want to check the thermal sensor, is your lamp door warped?
Oct 30, 2009 | Sony KDF-50E2000 50" HDTV
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
Sony kdlf-50e2000 will only stay on for 5-1o min then the screen will go out?
If TV turns back on itself and repeat that on-off cycle then its time for new lamp in TV.
How old is this TV and when did you replace its lamp?
Sep 26, 2009 | Sony KDF-50E2000 50" HDTV
I have a Sony Wega KDF-50E2000 that doesn't turn on. The green light blinks for a minute or so and then the red "timed out" light blinks continuously. Yesterday, the TV turned itself off with the green...
Did you replaced lamp in TV recently?
I think TV needs new lamp as existing is either broken or dead.
Lamp replacement procedure would be mentioned in user manual or let me know to provide you more info.
Thanks.
Sep 16, 2009 | Sony KDF-50E2000 50" HDTV
Replaced lamp; now to doesn't work
I had the same problem and I didn't have the lamp housing all the way engaged. once I slid it all the way in it came on.
May 19, 2009 | Sony KDF-50E2000 50" HDTV
Red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
May 13, 2009 | Sony KDF-50E2000 50" HDTV
Sony kdf-50E2000
bad lamp driver, if you have already replaced the lamp. If not, try replacing the lamp WITH AN ORIGINAL SONY LAMP!. Don't waste time with cheap replacements, you get what you pay for.
Oct 18, 2008 | Sony KDF-50E2000 50" HDTV
Sony KDF-50E2000 50" HDTV Logo
894 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
