Question about Cameras
Sunpak 20sr What is the sync voltage of this unit? I want to use it with an Olympus OM-D E-M1 which cannot accept more than 6.5V.
2 Suggested Answers
  • 919 Answers
SOURCE: olympus om-2 cvamera lenses
You are able to use your old OM lenses with a new Olympus digital SLR camera. You will need to purchase an MF-OM 1 lens adapter to be able to connect these lenses to the digital SLR camera. Also when using these lenses you will only be able to use the camera in manual focus mode as these lenses are not capable to shhot with an auto focus mode.
Posted on Apr 06, 2009
I have Sunpak 622 Super Pro Handle Mount TTL Flash. Would it be compatible with a Pentax K50?
Before you attach it to your camera you must check the trigger voltage first, never use an old flash unit until you check the trigger voltage with a multimeter, most old flash units have a huge trigger voltage that will damage your camera.
Very simple to check the voltage on that Sunpak 622, turn on your volt meter and set it to about 200 volts DC, turn on your Sunpak flash and apply the RED lead to the bottom contact, apply the Black lead to the side of the hot shoe and look for the ground, usually a small metal piece on the side. Now look at the meter, if it shows a voltage of 6 volts or less then it is safe to use on your camera, if voltage is higher, say 12 volts or more, don't use it. A high trigger voltage will certainly mess up your camera in the long run. Even if it has a safe voltage of 6 volts or less, you will only be able to use that flash in Manual Mode, the newer cameras will not sync or recognize an old flash unit.
I have an old Vivitar flash unit that I can safely use on my Canon XTI because the old vivitar has a trigger voltage of 5 volts, safe for all newer digital cameras.
Mar 04, 2015 | Pentax Cameras
I would like to use a sunpak 622 super with a sync connect to the hot shoe. Is the voltage too high for my nikon D 70 DSLR My e -mail is ml1089h@stx.rr.com
According to the list at http://www.botzilla.com/photo/strobeVolts.html , it's your call. The flash's trigger voltage is right on the border. Depending on the individual camera and flash, it may or may not be safe. Personally, I wouldn't risk it without something like the Wein Safe-Sync in between to buffer the current.
Mar 03, 2011 | Sunpak 622 Super Pro TTL Flash
This is for you camera experts!!! I have an Olympus camera that belonged to my father. The only numbers on it are OM-1n. it is pre digital. I would like to find out more about this camera and possibly...
You can download a manual for the OM-1 from
http://butkus.org/chinon/olympus/olympus_om-1/olympus_om-1.htm
The OM-1MD is the same camera as the OM-1 with the added provision for taking a motor drive to advance the film automatically.
The OM-1n is the same as the OM-1MD with a redesigned film advance lever, a flash ready/sufficient flash LED in the viewfinder, and automatic X-sync regardless of the position of the FP/X switch, when it is used with a T-series flash unit mounted on Flash Shoe 4.
Aug 25, 2010 | Olympus Photography
Sunpack Compatibilty
ifyour nikon has a hotshoe it should work quite well. I use sunpak flash on both canon and olympus without any problems. Just connect to hotshoe and shoot.
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Sunpak 383 Super Flash
How can i hook my sunpak 544 to my rebel xti without a slave unit reacting from my internal flash?i see no sync plugs to use on the unit. do they make an adapter or something?
All photo shops hold "hotshoe to PC" adapters for a few bucks. This solves your problem, supposed you have the hosehold-to-PC cable that comes with the 544 as accessory. If not, such cable can be obtained at better photo shops or from www.paramountcords.com. You must know that the flash can be used together with your camera only in Aperture Priority or Manual mode (flash set to auto), or as a fill flash (flash set to Power Ratio mode). The 544 has safe sync voltage.
Oct 12, 2009 | Sunpak Auto 544 Flash
Olympus OM-4 stuck shutter
This is very common on many OM SLRs and is caused by dirty shutter magnets. If you look on the web you can find details on how to do this yourself, but as the OM-4 is top of the line I'd highly recommend getting it done professionally as part of a CLA (clean lubricate adjust) service. Last time I had it done in the UK it cost about £80 and when I had it done to my OM-2SP in the USA last year it cost just under $100.
Jul 24, 2009 | Olympus Photography
Canon Macro Settings for 100mm lens and Sunpak 12R ring flash
Firstly, be sure to check flash voltage. Your 30D may accept max 6V so that your camera can be shot if the flash unit has higher voltage than 6V.
1. Use low ISO to keep low noise....around f/8 or more depends on your need and how much DOF you want.....Set the shutter speed around 1/125 to your max speed to stop any movement (your subject or camera itself shaking).
2. Above is set in Manual mode (iso100, f/8 1/125 or 1/250), then you just need to leave the flash to work in TTL mode.
3. It needs battery, the connection is for syncing to trigger and release a proper flash power (in TTL mode).
Hope this help!
Mar 26, 2009 | Sunpak DX-8R TTL Ring Light Flash
E-100 generic AC Adapter?
I doubt you can use 300 mA adapter,because Oly C2100 needs 2000 mA at 6,5V. E100RS construction seems to be very similar.
Sep 11, 2005 | Olympus Camedia E-100RS Digital Camera
Cameras Logo
52 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
