Question about Exercise & Fitness
Replace rocking arm of crazy fit machine - Exercise & Fitness
Rock-ola 448 jukebox skipping how to repair
The stylus might be worn or of the wrong type. A simple tone arm needs a round stylus and if an elliptical type (intended for a long S-shaped tone arm) has been fitted by mistake it could skip.
If nothing is wrong there, the remaining conclusion is either the mechanism is maladjusted or the tonearm bearing has a tight spot. In that case the tone arm should be removed and the shaft examined under strong magnification and any irregularities carefully removed, eased, blended in using a very fine abrasive (12,000 - 20,000 grit) and then ensuring the shaft and bearing is thoroughly clean apply a little very light machine oil and reassemble and readjust the playing weight...
Apr 07, 2017 | The Audio Players & Recorders
Put in viking machine embroidery arm, the machine went crazy then shut off? help?
More details needed. What model machine? What does "went crazy" mean? What happens when you turn the switch off, then on again (with the embroidery arm attached)? Does the machine function normally once the embroidery arm is removed?
Jan 04, 2013 | Husqvarna Sewing Machines
Fitness evolved game: i wave my arm off (right) nothing happens how do i fix this configs are all right the other kinect games all work
i think it has something to do with the way you wave. instead of just waving your whole arm like crazy try waving your hand and arm up and down in big motions for about 5 sec. my girlfriend had the same problem but i could do it fine if you need more help i could post a video just let me know.
hope this helps
Nov 22, 2010 | Ubi Soft Your Shape: Fitness Evolved for...
My Avalanche, when going appx 65-70 miles an hour rocks violently from side to side. If you go over a bumpy bridge at this speed, it will litterly hurt your neck and you have to hit the breaks immediatly...
you may have a bad or broken sway bar link, or the bushings. if the sway bar links break it will sway wildly especially on corners. on some vehicles they are hooked to " A " frame which is hooked to tire, this is why the tires go crazy. have a great day !!
Nov 10, 2010 | 2002 Chevrolet Avalanche
I was cleaning the dust out of the feed dog area and somehow disconnected the feed dog from the lever in the back that raises it and lowers it. How can I reattache them?
A feed system for a sewing machine having a frame, a horizontal arm shaft journalled in said frame, a vertical arm shaft extending downwardly from adjacent said horizontal arm shaft, means rotatably connecting said horizontal arm shaft to said vertical arm shaft, said feed system comprising a cam fixed to said horizontal arm shaft, a sheet metal feed fork having parallel bent over portions at one end thereof embracing said cam and in driving engagement therewith, a feed rock shaft supported in said frame and having an arm connected to the other end of said feed fork, feed regulating means carried by said frame and connected to said feed fork for converting motion induced by said feed cam to oscillations of said rock shaft, said rock shaft being formed with a pair of upright rock arms on the other end thereof, a horizontally disposed U-shaped sheet metal feed dog carrier having each end thereof connected to one of said upright rock arms, said feed dog carrier having a horizontal shelf extending from the base of the U between the ends thereof, said shelf supporting thereon a feed dog, means for attaching said feed dog to said shelf, a stud affixed to said base of said feed dog carrier beneath said shelf, a sheet metal lift lever pivotally supported on a horizontal axis in said frame substantially parallel to said rock shaft, said lift lever having a slotted end for engagement with said stud extending from said feed dog carrier, said lift lever having the other end thereof supporting a cam follower adjacent said vertical cam shaft, and a lift cam removably affixed to said vertical cam shaft and in engagement with said cam follower on said lift lever.
Take care.
Oct 20, 2010 | Kenmore 19110 Computerized Sewing Machine
Hi trying to re grease the pedal sprocket bearings on my Ross Rock Machine mountain bike. I got off the pedal arm on the right side but can't figure out how the left side comes off. The pedal arm looks...
Bottom brackets are sealed, removing the seal will have potential for damage. If it's making noise, replace it or better yet upgrade as a crankset. You'll have new crankarms, bottom bracket, chainrings with it. Unless you have the correct bicycle tools (not general automotive tools) you won't be able to pull your crank and even reach the seal for the bottom bracket. Click here for tools you need to do the job.
Jul 03, 2010 | Ross Rock Machine Aluminum Mountain Bike
Spin cycle on a Whirlpool washing machine does not work
underneath the 2 solenoids that rock when the motor is running are 2 vertical metal actuating arms. With the lid closed and in the spin cycle this arm is moved by the rocking soleniod actuator that is pulled up by the solenoid when the usnit is supposed to spin. This in turn pulls the actuation arm reaward allowing the spin tube to drop the clitch pads onto the drive plate. If the solenoid is bad or the gliding inverted U shaped solenoid actuator center pin has sheared it will not pull the actuation arm to the rear and the unit will not spin because the clutch pads never are moved onto the drive plate.
Jan 11, 2010 | Washing Machines
Maytag legacy squells like crazy, trouble gaining entry to check idler arm.
The noise you are hearing could be coming from the drum rollers needing lubricant.
If it is a front loading maching pull off the front of the machine, you can access the drum rollers to lube them or replace them and also get to the idle arm
Sep 26, 2009 | Maytag Dryers
New Bosch Front loader washer Maxx Classic WAE18060AU
Remove the 4 transit bolts from the back of the washing machine. These are supposed to be remove during installation. If they are not removed the machine jumps around like crazy on the spin cycle and the machine is almost unusable.
Jan 12, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Exercise & Fitness Logo
42 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
