Question about Ainol Novo 10 Hero 10 Inch Tablet Pc IPS Dual Core 1.5GHz 16GB Bluetoo
Does not respond to turn-off function
How can I turn it off?
How do I get my Kindle to respond normally and stop talking to me as if I were blind?
I am not familiar with the Fire line but for any problems log onto amazon.com Just below the search bar you will see several topics. Click on the help and follow links to send your question to the help desk. If you use the call back option and leave you phone they will call back and talk you through the fix. They are fairly quick so you won't be waiting all day. It is free to all kindle owners.
May 26, 2016 | Amazon Kindle Fire HD 6 Tablet - 16GB
Tablet is not responding ,to any comands
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - How can I reboot my tablet, the touchscreen is not working. ....Sometimes when I turn on the screen it doesn't respond to my fingers. Then I ...
Android Tablet Touch Screen Problem Solution - YouTube
? 21:36
https://www.youtube.com/watch?v=h7_aqvkfKL4
Jun 16, 2014 - Uploaded by SOLOMON BOTCHWAY
I CANT Believe it, i Actually fixed my tablet.. all i did disconnect the ... my touch is working how to fix the screen not showing? ....2 WAYS TO FIX IPAD TOUCHSCREEN NOT RESPONDING - WORKING - Duration: 5:17.
Samsung galaxy Tab S 10.5 not responding by touch ...
? 2:54
https://www.youtube.com/watch?v=XkK9zCx46gs
Jul 7, 2014 - Uploaded by Linkhunter
i just the new tablet by samsung i recharge the tablet after that isnot responding by touch and so Sim card do ...
Touch Screen Not Responding ' DaniWeb - DaniWeb IT Discussion ...
www.daniweb.com > ... > Hardware > Mobile and Wearables
Jan 11, 2016 | Tablets & eReaders
Apps not responding an running very slow
Everything is suddenly slow or is not responding. - Windows 8 Forums
www.eightforums.com > ... > Performance & Maintenance
Jun 24, 2014 - 10 posts - ‎2 authors
... year old and it started to load everything really slowly or is not responding for ... of memory to run Windows 8 efficiently so that isn't the problem. ... (It's not always showing, that the application is not responding, when it froze).
Solved: system is extremely slow and everything is "not responding ...
forums.techguy.org > Forums > Operating Systems > Windows 7
Sep 13, 2013 - Solved: system is extremely slow and everything is "not responding" ... Only after several minutes do the programs become responsive again, but once I try ... If using Vista or Win 7 - right click the icon - run as Administrator
iMac very slow, apps not responding, wheel turning ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Sep 28, 2012 - iMac very slow, apps not responding, wheel turning ... (Expect it to take longer to start this way because it runs a directory check first.). Mac runs super slow and apps not responding
Apr 23, 2015
running very slow and apps not responding
Sep 20, 2013
Macbook running slow and all applications stop responding - Apple ...
Jul 29, 2012
Running slow, Not responding
Oct 10, 2011
More results from discussions.apple.com
Jan 06, 2016 | Tablets & eReaders
How do I fix table that all function keys are not responding correctly.
This can happen after you restart the tablet or after downloading something. The OS get messed up. Turn off the tablet completely, not just put to sleep. Leave it off for several minutes so the RAM will clear completely (normally takes less than a minute). If that does not work, leave the tablet on (It can go to sleep and that's fine.) until the battery drains to zero. Then charge fully and you should be good to go. Worked for me.
May 01, 2015 | Tablets & eReaders
Broke my screen, still turns on and shows picture but touchscreen no longer responds. Is there a repair for this type of discrepancy?
Screen repair is a common fix. Check the yellow pages for a repair person or service. Depending on the damage the repair may not be worth the phone.
Feb 09, 2015 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
My I pad lost the colours and turned white and blak how can I fix it
  • Hi, have you activated the Reverse colours function? Go to Settings / General / Accessibility / Invert Colours
  • did you drop it by any chance? My boy dropped his and we got the dreaded black screen one time - then we gave it the hard smack treatment on the backside to release the jammed accelerometer - this worked perfectly the 1st time it happened, the 2nd time he dropped it we reverted to strange black and white colours, the smacking continued, and the colours came back.
Jan 25, 2015 | Apple iPad 2 tablet 16GB 3G
How do you reset a kindle fire
Your first step is to press and hold the power button for about 5 seconds and then tap the "Shut Down" icon when it appears on the screen. If this does not work (or the device doesn't respond), you must perform a hard reset.
To perform a hard reset, press and hold the power button for 20 seconds and then release it. This should turn off your device. After it has completely shut down, hit the power button again and you should be good to go.
As a side note, please ensure that your device is charged when you perform these functions. I can't tell you how many people have thought their device was broken when it was just a power issue that was keeping them from turning on their device.
Hope that helps!
Jan 30, 2012 | Amazon Kindle Fire
Toshiba Portege 3500 keyboard not responding
Well, yes you do have another option.
Just press and hold the CTRL key and press the K key that should help you with your concern. If call the Toshiba hotline 1800-457-7777 to send your NB to the DEPOT.
Aug 21, 2009 | Toshiba Portege 3500 Tablet PC
Ainol Novo 10 Hero 10 Inch Tablet Pc IPS Dual Core 1.5GHz 16GB Bluetoo Logo
19 people viewed this question
Top Ainol Tablets & eReaders Experts
Are you an Ainol Tablet and eReader Expert? Answer questions, earn points and help others
