Question about Watches
Gegrge watches price
George Diamond Black Dial Mens Watch FMDGE182
escapement
  • 2334 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
Posted on Feb 10, 2009
escapement
  • 2334 Answers
SOURCE: need to resize watch braclet on a mens invicta watch
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 02, 2009
SOURCE: Need instructions for mens Slazenger competitor,
need help to reset time on 13605 digital watch any help would be great
Posted on Jun 23, 2010
mcdevito75
  • 1970 Answers
SOURCE: how do i remove the back on my sekonda mens watch
mcdevito75 here, Generally thr back is simply pryed off useing a sharp knife (steak) or with a case opener, or at times the back is screwed on, little square holes around the back of the watch require a special tool, or there may be 4 screws holding down the back to the case, even if you get the back off you may need Jewelers screwdrivers to remove / replace the battery. BEST BET, look for a small watch repair shop in your area.
Posted on Jul 12, 2010
SOURCE: setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
Go to the home site of the particular brand of watch you own. They should have the instructions for just about every watch configuration they manufacture.
Posted on Sep 28, 2010
Is gegrge a good watch
Dear
The george watches, I like it.
Thanks.
Feb 27, 2015 | Watches
What is it the value (never been worn)
Bulovas are not high end luxury watches nowadays (they actually were, up to the mid-twentieth century). A modern quartz Bulova is just another mid to upper-mid level quartz wristwatch. Unless you know someone willing to spend some bucks just to have a gold and diamond watch, the value, especially with the price of gold now, may be in the metal, especially since it's 18K; the majority of gold watches are 10K or 14K. The diamonds are likely not very high quality, although they will be real. You should have a jeweler look at it. He will be able to give you an idea what the gold and the stones are worth. Unfortunately, as a watch, Bulovas just don't have much intrinsic resale value nowadays, not like a Rolex, Tag Heuer, Breitling, etc. would have.
Aug 06, 2014 | Bulova Watches
Neeed a replacemet strap, band or metal bracelet for Nautica N19558G Black dial Resin Mens watch
You can get it from Authorized Dealer of this Company. If it has nothing to do with it's warranty, any alternative shop will be an economic option.
Mar 29, 2014 | Nautica N19558G Black dial Resin Mens...
Setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
Sep 03, 2008 | Watches
Reymond weil ladies watch automatic
hi guys heres my pic ty not very clear644ef545-133c-4e4c-823f-750b9fd2175a.jpg
Jun 11, 2008 | Watches
Watches Logo
10 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
