Question about LG Flatron F700P 17" CRT Monitor
17" flatron crt monitor only green led blinking and tick tick sound .No display
  • LG Master
  • 3,320 Answers
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Posted on Apr 21, 2014
  • 62 Answers
SOURCE: My studioworks 500G monitor LED blinking with twise colour(Green and Amber)and no display.
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
Posted on Nov 03, 2008
ginko
  • 19396 Answers
SOURCE: monitor light blinking
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
power led green is blinking
Posted on Jul 27, 2009
budmrtn
  • 11361 Answers
SOURCE: LG Flatron - green power led blinks twice
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 21, 2010
SOURCE: LG Flatron ez t713sh 17" CRT Problem:
I already have the solution to that problem. It is a faulty capacitor that needs replacement. If you want you can copy and paste this link http://loversdelight-ididitmyself.blogspot.com.
Posted on Jun 22, 2010
LG flatron T13SH no display with power LED fast blinking.
no video signal - video card broke down or screen resolution is to high
try boot in safe mode and un install de video card
Feb 20, 2011 | LG Flatron Ez T710BH 17" CRT Monitor
Led bilinking
green LED blinking but no display, when disconect VGA cable from CPU than monitor displays cable disconected. CPU vedio card is ok
Jan 08, 2011 | Samsung 793S 17" CRT Monitor
Problem on LG Flatron ez T713SH crt monitor
i have the same thing, monitor display is dark and tick tick sound audible and thats all it do untill now..
Feb 15, 2010 | Computers & Internet
Have a phillips 107s monitor, green led flashes, making a tick tick sound, no display
Make sure the mains plug is firmly inserted. The most likely cause of the problem is a power supply problem which will be uneconomical to repair in the current day. Cheaper to replace with an LCD.
Sep 28, 2009 | Philips Standard 107S 17" CRT Monitor
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
Switch led is continously blinking in green colour
Sounds like you don't have a stable connection. Try shutting down PC, and disconnect the monitor, and reconnect it, and turn PC back on, then turn the monitor on...
May 14, 2009 | Hitachi CM621F (White) 17 in.CRT...
Jun 30, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
No diplay in Monitor
The blinking LED usually denotes that no signal is reaching the monitor. Do you have another monitor you can attach to the computer to test it? It sounds like it may be a computer problem, not a monitor problem.
Aug 28, 2007 | Samsung SyncMaster 793MB 17" CRT Monitor
LG Flatron F700P 17" CRT Monitor Logo
110 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
