Question about Dishwashers
Free whirlpool repair manual
F07 shows on the dial. What is wrong?
    Habit-Forming:
  • 119 Answers
Hello, Without a model number, I can be of limited help. But the F07 fault on a whirlpool dishwasher is indicating a problem with the water intake flow meter. Check the connections at the meter, if good replace the flow meter.
Unplug the appliance.
Take it out of it's installed location
Remove the left side panel .
In the large plastic tank on the left side of the machine is the flow meter. It will have a 2 wire plug on it.
Pull the plug off and push it on again a couple times.
Make sure the connection is dry and tight.
Try the dishwasher.
If you receive the F07 fault again, replace the flow meter.
Posted on Apr 21, 2014
Error code f07
http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html
Aug 03, 2014 | Whirlpool Washing Machines
Fault code f07
The type of dryer would help a lot.... If it is a Maytag you can try resetting the code...
To reset the error code you need to turn the dial to the 6 oclock position.
Press the start button 3 times
Turn the dial 1 position clockwise
Press start button again 3 times
Then turn to off and this should clear the error code.if you still get the F07 error code then the control board may be the problem
If it is a Hot point You have a lower element failure..
Dec 31, 2013 | Dryers
What does code f07 mean?
'F07' for CDA (Whirlpool) washers decodes as ' triac short circuit detection (motor control module)'.
Sorry but this looks like a case for repair/engineer call ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 02, 2011 | CDA Washing Machines
I have a Whirlpool WFS1273AW with error code F07
"F07" Motor Control Unit Error
The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU). Check the MCU and the drive motor.
Mar 30, 2010 | Whirlpool Washing Machines
Whirlpool awm 8143 doesn't stop at the end of the spin cycle. Instead it clicks for a while when the timer displays 1 minute then displays F07 then goes back to wash cycle. While googling I found something...
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2010 | Whirlpool AWM8123 Front Load Washer
Broken washer mode dial on Whirlpool Duet HT Washer WFW9400SW.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Jan 02, 2010 | Whirlpool GHW9400 Front Load Washer
F07 error message
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F07 occurs at end of first rinse cycle
Mar 26, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Dishwashers Logo
127 people viewed this question
Top Dishwashers Experts
