Question about Reebok Clothing Accessories
803816798100 its original or not
Copystar cs1510 showing error e70 please help
The E70 its a troubleshooting original placement and memory errors:
1. Remove originals and replace them in the original table when the "E70" or "E71" errors display.
2. Remove originals placed on the original tray and allow the copy job from the plate to complete when the "E72" error displays.
3. Remove originals remaining in the original table when the "E90" error displays, indicating that the memory is full. Press the button with a "%" sign on it, labeled recall, to print the copies of the originals that have already been scanned. When printing completes, place the remaining originals back into the original tray and press "Start" to continue copying.
Hope helps.
Apr 18, 2011 | Copystar CS-1510 Copier
Need to know the gap for 1995 chev.tahoe spark plug
I prefer bosch plugs :
2000 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium. 2000 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium. 2001 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium. 2001 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium. 2002 Chevrolet Tahoe 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium. 2002 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium. 2002 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium. 2003 Chevrolet Tahoe 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium. 2003 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium. 2003 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium. 2004 Chevrolet Tahoe 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium. 2004 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium. 2004 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium. 2005 Chevrolet Tahoe LS 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium. 2005 Chevrolet Tahoe LS 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium. 2005 Chevrolet Tahoe LS 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium. 2005 Chevrolet Tahoe LT 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium. 2005 Chevrolet Tahoe LT 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium. 2005 Chevrolet Tahoe Z71 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium. 2005 Chevrolet Tahoe Z71 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium. 2006 Chevrolet Tahoe 5.3L 5328CC 325CID V8 FLEX FI Z L59 - GAP=0.040"; Original equipment is iridium. 2006 Chevrolet Tahoe 5.3L 325CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium. 2006 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium. 2006 Chevrolet Tahoe LS 5.3L 5328CC 325CID V8 FLEX FI Z L59 - GAP=0.040"; Original equipment is iridium. 2006 Chevrolet Tahoe LS 5.3L 325CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium. 2006 Chevrolet Tahoe LS 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium. 2006 Chevrolet Tahoe LT 5.3L 5328CC 325CID V8 FLEX FI Z L59 - GAP=0.040"; Original equipment is iridium. 2006 Chevrolet Tahoe LT 5.3L 325CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium. 2006 Chevrolet Tahoe Z71 5.3L 5328CC 325CID V8 FLEX FI Z L59 - GAP=0.040"; Original equipment is iridium. 2006 Chevrolet Tahoe Z71 5.3L 325CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium. 2007 Chevrolet Tahoe LS 4.8L 294CID V8 GAS FI C - GAP=0.040"; Original equipment is iridium. 2007 Chevrolet Tahoe LS 5.3L 5328CC 325CID V8 GAS FI J LY5 - GAP=0.040"; Original equipment is iridium. 2007 Chevrolet Tahoe LT 5.3L 5328CC 325CID V8 GAS FI J LY5 - GAP=0.040"; Original equipment is iridium. 2007 Chevrolet Tahoe LTZ 5.3L 5328CC 325CID V8 GAS FI J LY5 - GAP=0.040"; Original equipment is iridium
Feb 19, 2011 | Chevrolet Tahoe Cars & Trucks
How to convert this copier from inch to metric system??
SELECTING THE ORIGINAL SIZE
If you loaded a non-standard size* original or the original size was not correctly detected, set the original size manually.
Perform the following steps after placing the document in the document feeder tray or on the document glass.
1 Press the [SPECIAL FUNCTION] key.
The special function
screen will appear.
2 Select "ORIG. SIZE ENTER" from the
menu with the [ ] or [ ] key.
3 Press the [OK] key.
The original size selection
screen will appear.
4 Select the original size with the [ ] or
[ ] key.
The selected original size
is highlighted.
• To select an AB original size, press the [ ] key and
go to step 6.
• If you selected "SIZE INPUT", follow steps 4 through 6
of the procedure in "USING THE BYPASS TRAY TO
COPY A SPECIAL SIZE ORIGINAL" (page 51) to set
the horizontal and vertical dimensions of the original.
5 Press the [OK] key.
You will return to the base
screen and the selected original
size will appear in the original
size display.
Selecting an AB original size
6 Select the original size with the [ ] or
[ ] key.
To return to selection of inch original sizes, press the
[ ] key to return to step 4.
7 Press the [OK] key.
size display.
* Standard sizes:
The following sizes can be detected correctly: 11" x 17", 8-1/2" x 14", 8-1/2" x 11", 8-1/2" x 11"R, 5-1/2" x 8-1/2"
(A3, B4, A4, A4R, A5). If a non-standard size original is placed (including special sizes), the closest standard
size may be displayed, or the original size may not appear.
Note
DUPLEX
SPECIAL FUNCTION
ACC.
DUPLEX SCAN
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GH
PQR
DUPLEX
SPECIAL FUNCTION
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GHI
BACK OK
ORIG. SIZE ENTER
11x17
8 x14
81 x11
INCH
ORIG. SIZE ENTER
11x17
8 x14
8 x11
INCH
To cancel an original size selection, press
the [CA] key.
OK
ORIG. SIZE ENTER
A3
B4
A4
AB
OK
Note
Oct 02, 2008 | Sharp AR-207 Copier
Clothing Accessories Logo
630 people viewed this question
Top Reebok Clothing Accessories Experts
Da Doc
toot tall
toot tall
Level 1 Expert
Tafi Nami
Tafi Nami
Are you a Reebok Clothing Accessory Expert? Answer questions, earn points and help others
