Question about Zenith A32B41W 32" TV
ZENITH codes for dish network remote control
I have a zenith tv model #B19A02D and i just got a Dish Network DVR and the romote control wont work. The only thing the remote does is change the channel. Power button doesnt work and volume doesnt work. Can you help me find the zenith code to program the remote control
jomaru
  • 337 Answers
SOURCE: Cannot access menu
The tv has lost the menu,in order for the menu to come up in the screen it needs horizontal and vertical sync,the syncs come from the secondary of the flyback and from the vertical Ic.Is rare but We have seen it happen,sometimes you also have an Ic called character generator and it could be bad.You will need the assitance of a servicer for this problem because there are voltages to measure and signal to trace.
Posted on Oct 02, 2006
bkvinr
  • 76 Answers
SOURCE: can't access channels 3 and 4
Open main menu and select manual program. In this option check skip on/off option is there. Otherwise select autoprogram the channels are automatically stored, after completing autoprogram TV displays program edit option. In that you can choose your needs.
Posted on Sep 09, 2007
Phantomgreen
  • 128 Answers
SOURCE: connecting a PS2 to a zenith tv
you need to buy an a/v to coax adapter.Here is a link for the adapter.
http://salestores.com/rcacrf90.html
hope this helps.
Posted on Apr 05, 2010
mikeywaf
  • 346 Answers
SOURCE: Zenith C27A24T 27" TV does
Greetings - You need to have you DVD player hooked up to the video inputs - See below. Don't mind the mouse scratch out lines. The Device on the right represents your DVD player.
You then have to choose video as your source on the TV (not channel 3 or 4) using your remote - see below.
You should be good to go.
Enjoy your movies,
Mikeywaf
Posted on May 22, 2011
whammy45
  • 84 Answers
SOURCE: need remote control code for dish network along
Try this...1) turn on your tv set manually.2) on you dish remote..press and hold the "TV" mode button next to the "SAT" button.when all of the other mode buttons light up, let the "TV" button go...it should be flashing.3) Press the blank power button(The top red button in the top center of the remote).4) press the UP or DOWN button at the rate of about 1 per second until the tv turns off.4) When the tv turns off...press the # key on the bottom right of the remote...this stores the code and you should be ready to go...please try this first..It should work.If the scan doesn't work...The only code for Orion is "694".I hope this was helpful....
Posted on Dec 14, 2011
I need to program a zenith tv to work with the 21.0 ir/uhf pro remote control
I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at Kimberly.escobar@dish.com!
Look up codes for TV here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Feb 14, 2014 | DISH Network ES161256 21.0 IR / UHF Pro...
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
I need a code for a v-zon tv3200 remote wont work,,,direct tv doesnt recognize this brand direct tv no help
I would suggest you try and use the codes Direct has given you for Zenith, Goldstar & LG tvs. There a good chance that's who made the tuner in your tv. Hope this helps.
Dec 05, 2010 | DISH Network IR Remote Control
CODIGO ZENITH
garciaj9629
I'm not sure what type of problems you are having with remote. I have provided a link with instructions on programming the remote to the TV. I have also provided a link with the codes for different TVs. Look down the list for your TV brand. Step 6 is for programming the remote to a TV. I hope this helps.
Remote instructions:
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
Oct 08, 2010 | DISH Network IR Remote Control
I need the tv code for a 20" vizio tv using a dish network remote from a dvr 522 receiver
Hi here are the codes for Vizio as supplied by dishnetwork
505, 627, 775, 758, 756, 885, 864
Feb 01, 2010 | Zenith ZEN700 Remote Control
Control code
leoidalgo
I have provided the remote codes for your Zenith TV. I have also provided a link with instructions on how to program the remote to the TV. I hope this helps.
Remote codes: 501, 652, 766, 500
Program remote, step 6:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Jan 06, 2010 | DISH Network 142923 Remote Control
Looking for zenith remote code for TV/VCR combo
Zenith
101, 142, 149, 177
try these out and see if it works
Jan 31, 2009 | Televison & Video
Code for PROVIEW Television
There should be a list on the DISH network website.
Try this:
http://www.carltonbale.com/project/dish-network-universal-remote/
or
http://www.dishnetwork.com/content/faq/remotes/index.shtml
(this last one has links to remote control lists depending on the color of the buttons; around middle of page)
Jul 04, 2008 | Zenith B27A11Z 27" TV
Remote control
this is not a great idea, youcan program your dish remote to your tv though,
Feb 19, 2008 | DISH Network DVR-625 DTV Receiver /...
Remote control code for magnavox dvd/vcr combo
I need codes for my Universal Philips Magnavox remote for a Sanyodvd vcr combo ?
Sep 07, 2007 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
360 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
