Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Rcd tripping Please help my side by side ge fridge freezer is trooping our power.i have had it for 2 year we moved houses,I left it unplugged for three days in our garage then moved it into the house and plugged it in,as soon as I did that,the rcd tripped,I unplugged everything in the house and plug the fridge in it done it again.it trips the rcd as soon I flick on the swtich.aby advice on what might be wrong as it is very expensive to call someone in to look at it. when we moved it from the garage to the house there was a little bit of water coming out from under it.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
Either the start relay in the compressor is grounding electrically or the defrost heater is (most likely start relay). To replace this yourself is difficult as it requires technical knowledge. If you are located in California, bay area I could help you personally
Posted on Jun 27, 2014
  • 25 Answers
SOURCE: Freezer and fridge areas both 50 degrees
Assuming you have a frost-free refigerator:
Is your motor-compressor running?
If so, check if you have ice in the freezer section; if so, maybe your defrost thermostat or heating element is kaput.
If the motor-compressor is not running, check in the back of the refrgerator if the defrost time is stuck open, bu turning clockwire the small test screw, with a 1/2inch screwdriver.
Posted on Dec 10, 2007
jumptrout51
  • 3361 Answers
SOURCE: Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
Posted on May 13, 2009
aasc
  • 1606 Answers
SOURCE: ge side by side refrigerator trips GFI
Try an extension cord to get it off the GFI outlet .
Posted on Aug 20, 2009
  • 53 Answers
SOURCE: Our house was surged with lightening yesterday,
Sounds like the compressor is pulling too many amps and tripping the overload. Compressor could be shorted.
Posted on Jun 18, 2010
Macmarkus
  • 2605 Answers
SOURCE: I have a GE side by side and it just stopped
Welcome to FixYa,
Unfortunately based on your post ( has no power and nothing is running. I check the house fuse panel and no breakers are tripped. Also I pulled the fridge out and tested the wall outlet and there\'s power )
the issue is likely the control board (PCB) at the back of your fridge.
If you slide the fridge out and look at the back you'll see a square panel approx. 4"x5" held by four screws ( sometimes three ) remove it and you'll see this control...
It should be available ( part # WR55X10942 ) at "repairclinic.com" or "searspartsdirect.com" to name a couple for about $150 or so and come with a guide to install it, though it should be harness for harness & wire for wire.
Thanks for choosing FixYa and good luck. Let me know how you make out or if you need further assistance and I'll help in any manner I can.
Regards,
Macmarkus :)
Posted on Jan 01, 2011
Find out why my freezer is shorting
Is your FREEZER is plugged into a wall socket which is protected by an EARTH LEAKAGE UNIT or RCD [Residual Current Device] ???
Most manufacturers advise NOT to have this type of appliance connected through an RCD as the start load required when the COMPRESSOR "kicks in" is quite large [especially in larger fridge/freezer units] AND will quite often TRIP your RCD. These appliances are better connected to a separate electrical circuit if at all possible and not protected by an RCD.
Sep 20, 2014 | Refrigerators
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
Check to make sure that in the process of moving a "hot" wire under the refrigerator did not come loose and now is contacting a metal part of unit.
U have a classic short circuit which accounts for the breaker popping immediately. It is not a short in the compressor because that would have popped the self resetting clixon and not the house breaker.
May 01, 2017 | Refrigerators
With the unit unplugged remove the machine compartment and visually inspect for and burnt marks or frayed wiring. if non is seen, remove the wiring connectors from one component at a time and re test by plugging the unit back in. This will help you isolate the issue hopefully.
The machine compartment is on the back and the power cord is attached behind it. It is usually connected with 1/4" screws so a socket or nut driver will help you gain access.
Apr 22, 2014 | Refrigerators
Fridge freezer tripping rcd
Ensure it fully dries out before trying it again. Water in the electrics will throw your trip instantly. If it's dry now, and you are having the same problem. check the electrics for a short circuit or earth fault. Usually a compressor earth fault is to blame.
Apr 21, 2014 | Refrigerators
Xerox Phaser 8550 tripping RCD on warm up
IF the warranty is still in effect, call for service.
IF no warranty, then check the heaters for the solid inks.
Probably a bad element, or a shorted element.
Unless you are skilled with electrical meters, V-O-M type,
this could be dangerous.
DO NOT ATTEMPT to troubleshoot this with power on.
IF you can use a meter, with the power OFF,
check for continuity and resistance with multi-meter set to Ohms.
BE CAREFUL!
Electricity can KILL!
Jul 27, 2012 | Xerox Phaser® 8500, 8550, 8560, 8560MFP...
GE side by side refrigerator model GSS22JEPD freezer ices up.
remove the freezer shelves and remove rear inside panel in freezer,under the evaporator located here theres a heating element,it has probably opened up and can no longer heat,this is a very common problem with g.e. SxS refrigerators,replace it by unplugging unit,then remove 2 screws holding heater bracket and unplug heater and replace g.e.heater part # is WR51X10101
Jun 16, 2012 | GE Refrigerators
Vegetables in crispe are freezing
Check for blockage of the damper door which regulates airflow from the freezer into the fridge. It might have gotten some ice buildup there while the freezer door was open.
Jan 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Mar 21, 2008 | Refrigerators
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
89 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
