Question about Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D
Need cold control
Model ylr2-5-24h2
I cant turn up the thermostat on my hotpoint under counter fridge. Its seems a very old model but i am not sure which model it is.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 16, 2011 | Refrigerators
MODEL NUMBER 363.78562894 CYLCES BETWEEN COLD AND NOT COLD SUCH THAT AN ICE CREAM BAR GETS SOFT AND REFREZES OVER AND OVER. A BAD THERMOSTAT OR DEFROST CONTROL BOARD??? WHICH ONE AND HOW MUCH ?
NOTE: This
Leo Ponder
Sep 15, 2011 | Refrigerators
Model # 2389ges, I have air blowing into the freezer but it is not cold.
NOTE: This
Leo Ponder
Sep 07, 2011 | Jenn-Air JCD2389G Side by Side...
We bought a Danby compact fridge, model DCRM90WDB and it's running but not getting cold.
NOTE: This
Leo Ponder
Sep 05, 2011 | Refrigerators
I just bought a new refrigerator GE Model PFSS2MJYCSS a week ago and stop working after a week......... is there any recall on that model....??????
NOTE: This
Leo Ponder
Sep 04, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Hello the compressor on my fridge model 6D5SHAX Whirlpool goes on and off and my refrigerator is not cold at all. I really need your expertise.
NOTE: This
Leo Ponder
Aug 23, 2011 | Whirlpool GD5SHAX Side by Side...
My freezer is not cold enough to freeze items and has defosted everything but still blowing out cold air and making ice cubes as i have the model ffu21 what do u suggest?
NOTE: This
Leo Ponder
Aug 23, 2011 | Hotpoint Refrigerators
Kenmore Fridge model 79558813900 which is a year and a half old randomly went completly out not sure what to check. It is not the fuse or the plug.
If this doesn't work Do this
That is probably the compressor relay
The relay is on the compressor and needs replaced
Leo Ponder
Aug 16, 2011 | Kenmore Refrigerators
Compressor not kicking on model refrigerator
Sounds like the cold control has stuck open. Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
That is probably the compressor relay or cold control (Thermostat
Leo Ponder
Jul 31, 2011 | GE Refrigerators
Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
35 people viewed this question
Top Whynter Water Filters & Coolers Experts
Tom Chichester
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
