Question about Electronics - Others
Microtek 860eb inverter cuircit diagram
Circuits diagram
Microtek Inverter high output problem
Did you check the voltage under load, some power supplies float high when there is no load connected
Mar 01, 2014 | Electronics - Others
I need the Cuircit Diagram of hitachi 42pd380ta
Hello
I've the circuit diagram for Hitachi P2PD 3*** SERIES TVs. Send your email address to me by FixYa comment box. I'll send a copy of it to you by return mail. OK.
Dec 10, 2011 | Hitachi 42PD380TA 42 in. EDTV-Ready Plasma...
I am using microtek 810. Inverter section is ok. In the pcb there are two 40amp fuse which were blown off. suspected heavy current drainage. both fuses are in parallel and in the battery -ve line. i...
If this is a 12 volt battery situation, 24.6 volts is not doing good things for your batteries--it will buckle the inner plates causing immediate battery failure. Were the fuses themselves blown or just the fuse mounts which may have been underrated. You definitely need a schematic for this system--try googling 'microtek 810'. Good luck!
Aug 15, 2010 | Garden
I have a microtek 710s monitor, that powers on but
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Computers & Internet
My microtek flat screen monitor goes black every 5 seconds and must turn it off and back on and it repeats the same thing.
I assume that you have already try it on another PC with the same result.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 03, 2010 | Microtek C593 15" Flat Panel LCD Monitor
MICROTEK INVERTER HELP
Bad batteries, replace all of them together.
Oct 02, 2009 | Electronics - Others
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
D52W20 Circuit Diagram
what cuircit are you searching for power defelection, sub power, convegence power convegence amp, crt boards, signal board
Oct 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Electronics - Others Logo
113 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
