Question about Carrier Heating & Cooling
Carrier evaporative air con
I have a carrier evaporative 5 vent fitted 1999 model 29cb4500 to 29cb9500 !.I dont know which one,anyway everything is working fine except I could hear water running down the over flow when the air con isnt on.When I checked the ball ****/float wouldnt shut the water off unless I lifted it.I assume a tap washer inside has perished.How do I get at it and could I change it for a ceramic seal as they should last longer !.
kstfas
  • 75 Answers
SOURCE: low discharge super heat
Hi, Its been a long time since I have worked on one but maybe the chilled water is having problems and not circulating good. Could be airlocked somewhere if its been down for a while. Hope I have helped. kstfas
Posted on Sep 13, 2007
Amigaman
  • 248 Answers
SOURCE: Washer will not drain properly.
The splashing you hear is a liquid thats in the balance ring. This is located at the front edge of the inner tub that you spun by hand. It helps balance the loads. This is normal. The smell is a problem inherent to front loaders. About once a month run hot water wash with a cup of bleach in it, no clothes. Best bet is to leave door open to allow air to dry interior. I removed bulb in mine.
Posted on Oct 06, 2007
  • 86 Answers
SOURCE: through the wall HAIER air con
model no
capacity of a/c
need to solve yr problem
Posted on Mar 17, 2008
machtcl1
  • 61 Answers
SOURCE: Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Posted on Jan 02, 2009
bobotfel
  • 236 Answers
SOURCE: Can't get airconditioner to work
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If wont work then there are some safety device that work or defective. Try counting the blink of your green light so that I can convert the error code.
Posted on Jan 08, 2009
Air con problems on my peueot 406
if there is no air movement check the fuses as the one for the fan might need replacement, if there is air movement but it is not cold then you may have lost gas from your aircom system which will need to be replaced by a specialist.
i hope this was useful
Feb 25, 2013 | 1999 Peugeot 406
My carrier unit is blinking 5 slow blinks and i can't find the fault codes to determine the problem. the model number to this unit is 58wav091-14
Dont know about yours, but the models we carry use fault code 5 to indicate low pressure/charge in the system.
Nov 30, 2010 | Carrier Heating & Cooling
1999 grand jeep cherokee limited air con prob water coming out vent behind driver seat and water drops noted under glove box front passenger side ???? what to do air con recently regased works well but...
You have a leak in your air conditioning compressor Your system works on the reheat principle All air passing through the system is cooled and reheated before it enters the cabin this sould be dehumidified air but it passes through the heater core and sence the air is not dehumidified you are getting condansation as the air flows the heater core that is heated by the engine heat and the water is from condencation because of the leak in the ac compressor The unit is a press fit in the center of it and fials unfortinatly a lot with this disgien of compressor
Nov 26, 2010 | 1999 Jeep Grand Cherokee
Carrier air con. expansion valve 5 problems and 5 solutions
1. Mid to late 90's problems on Carrier coils leaking. 2. Problem with lication of TXV's on air handlers. When welded in they were located to close to the fitting where the suction lines were welded in to unit. The heat would cause them to fail.
Feb 21, 2010 | Carrier 38CKC042 Air Conditioner
Common problem and solution on condenser of carrier air con.
dirty evaporator filter and or coil, dirty out door condensing coil, defective thermostat.
Feb 21, 2010 | Carrier BCA101R Air Conditioner
I have a breather pipe from my air filter carrier
crank case breather pipe thats what it is called any pipe will do aslong as it fits on ok
Jun 07, 2009 | 1999 Suzuki GSX-R 600
99.5 A4 Quattro Air con wont turn off
On some Audi's there is an ECON button which you must press for up to 5 seconds to turn the AC off.
Aug 07, 2008 | 1999 Audi A4
Model number for Carrier furnace with issue for blower 5 minute off delay
I believe that this model number is for an air conditioner evaporator coil. This unit is probably directly attached to your furnace. The Model number for the furnace will be located in the compartment where the flames can be seen. It will be on a sticker or plate that contains lots of other information too like BTU/h, Volts etc...
The number you gave me gives me this info:
Cased air conditioning evaporator coil.
3 Tons
Horizontal application
Jun 27, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
15 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
