Question about Refrigerators
Fridge freezer tripping rcd
Please help my side by side ge fridge freezer is trooping our power.i have had it for 2 year we moved houses,I left it unplugged for three days in our garage then moved it into the house and plugged it in,as soon as I did that,the rcd tripped,I unplugged everything in the house and plug the fridge in it done it again.it trips the rcd as soon I flick on the swtich.aby advice on what might be wrong as it is very expensive to call someone in to look at it. when we moved it from the garage to the house there was a little bit of water coming out from under it.
  • Refrigerators Master
  • 884 Answers
Ensure it fully dries out before trying it again. Water in the electrics will throw your trip instantly. If it's dry now, and you are having the same problem. check the electrics for a short circuit or earth fault. Usually a compressor earth fault is to blame.
Posted on Apr 26, 2014
4 Suggested Answers
gaeb7
  • 25 Answers
SOURCE: Fridge keeps tripping the circuit breaker
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Posted on Mar 01, 2009
get an inexpensive clamp amp meter (Harbor Freight has them). Turn off power to the plug. Remove plug from wall but do not disconnet wires. turn fridge OFF. plug the unit in the recept. turn on the power. set the meter for the higest reading (amps) & clamp it around the black wire. turn the fridge ON & observe start up current & the "run" current. If the fridge is within limits on the data plate the problem is in the wiring circuit, maybe a loose connection either @ the plug or the breaker. if there are several plugs in the circuit, the problem could be in one of them. In addition, if there is a gfi plug in this circuit, it could be faulty also.
Posted on Mar 02, 2009
  • 400 Answers
SOURCE: Westinghouse 410l fridge trips new RCD's in fusebox
Tripping an earth leakage would indicate a break down of insulation in the windings of the compressor, the possibility of a short circuit in the wiring system or the defrost element down to earth. I recommend you have a certified technician check it out before you have a fire. If the Hoover is in good condition there is no reason not to replace it. Rate me please.
Posted on Mar 11, 2009
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
Check to make sure that in the process of moving a "hot" wire under the refrigerator did not come loose and now is contacting a metal part of unit.
U have a classic short circuit which accounts for the breaker popping immediately. It is not a short in the compressor because that would have popped the self resetting clixon and not the house breaker.
May 01, 2017 | Refrigerators
With the unit unplugged remove the machine compartment and visually inspect for and burnt marks or frayed wiring. if non is seen, remove the wiring connectors from one component at a time and re test by plugging the unit back in. This will help you isolate the issue hopefully.
The machine compartment is on the back and the power cord is attached behind it. It is usually connected with 1/4" screws so a socket or nut driver will help you gain access.
Apr 22, 2014 | Refrigerators
Rcd tripping
Either the start relay in the compressor is grounding electrically or the defrost heater is (most likely start relay). To replace this yourself is difficult as it requires technical knowledge. If you are located in California, bay area I could help you personally
Apr 21, 2014 | GE Profile PSW26P Stainless Steel Side by...
Why does my fridge trip the power on defrost cycle?
have a technician come in and do an insulation test on the unit
the very smallest insulation leak will trip the RCD unit in the breaker
Sep 13, 2017 | Refrigerators
Mar 11, 2009 | Refrigerators
Vegetables in crispe are freezing
Check for blockage of the damper door which regulates airflow from the freezer into the fridge. It might have gotten some ice buildup there while the freezer door was open.
Jan 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
145 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
