Question about Siemens WFXD8400UC Front Load Washer
Door open error 34 for Siemens q700 - Siemens WFXD8400UC Front Load Washer
Siemens front load washing machine. Cloth stuck between the door and the panel. Can't open the door. F23 appears.
the tub beneath the washer is full and is not draining. the clothes have probably opened up the seal between the door and washer allowing water to leak. tip the machine and empty the sump to clear error.
Jun 09, 2016 | Siemens Washing Machines
What does f26 mean for siemens washing machine
F26 come up This error code indicates that the door needs to be opened and closed.The F26 code may appear the first time you try to use the washer. Open and ...
Jan 03, 2016 | Siemens Washing Machines
My Siemens Extraclasse 1300 Washer/dryer just stopped as though no power. Fuse is ok.
check door inter lock by putting mech on leave 4 five mins go and try to open door imeditlaty if if opens straight away its the inter lock
Feb 22, 2015 | Siemens Washing Machines
SIEMEMS WASHING MACHINE ERROR CODE F:26?
F20-30 is drain or intake
and can be within a given time
so can be something inside the pump or drum skin
or a bad intake valve filter ...
try reading the user manual
look at the makers site i found it easy...
and it has the error code list
your lazy or not looked...
youll find the info you need
try this also from a similar issue
http://www.manualslib.com/manual/770034/Siemens-Wfxd8400uc.html?page=34
look at the ' water does not enter the machine'
cross reference with other machines that c=share the same controllers
here is the answer i found about F26
The error F26 does indicate a fault in the door switch . There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close.
This is most likely a problem with the door switch
interlock
or a loose connection at the switch but not likely
its more likely a burned connection
and has high resistance so you perhaps need to check out the wires plug.. etc make sure the contacts are very good
The door switch is part of the door lock assembly part number 8183270 {not sure this is right}
this info is from a maker that uses the same chassis
not the same parts number
its prob the door switch ....!!!
Aug 17, 2014 | Siemens Washing Machines
Siemens WM14S392GB - error F61. Help to fix please.
Error E61 means that the door is locked but the sensor is showing as still open.
You may have a faulty door sensor.
May 07, 2012 | Washing Machines
Wd71 error 34
get a washboard and a jug
Feb 14, 2008 | Hotpoint Ultima WD72 Front Load...
Siemens WFXD8400UC Front Load Washer Logo
106 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
