Question about HP EliteBook 2530p Notebook
My google chrome not respond my number tank call
When click on call button,it does not respond. Automaticaly end the call.And again ask to click the cal button.
How to get rid of the ask toolbar?
To uninstall Ask toolbar from your computer, you can follow the steps below:
1.To uninstall "Ask Toolbar" program from Windows XP, Windows Vista or Windows 7, click the "Start" button, then click on "Control Panel". If you are using Windows 8, drag your mouse pointer to the right edge of the screen, select "Search" from the list and search for "Control Panel".
2.When the "Control Panel" window opens click on the "Uninstall a program" option under "Programs" category.
(Note: If you are using the "Classic View" of the Control Panel, then you need to double-click on the "Programs and Features" icon instead.)
3.When the "Programs and Features" or the "Uninstall a Program" screen is displayed, scroll through the list of currently installed programs and uninstall "Ask Toolbar, Ask Toolbar Updater, Ask Updater" and any other recently installed or unknown programs.
Once you have successfully uninstalled the above mentioned applications from your system, you also need to reset your browser to remove Ask toolbar and Ask.com from the respective browser. To do this, refer to the steps listed below:
(Important: While resetting your browser(s), go through the on-screen instructions very carefully to understand what all changes will be made in your browser once it is reset.)
To reset Internet Explorer:
1.Open Internet Explorer, click on the "gear icon" in the upper right part of your browser, and then click on "Internet Options".
2.In the "Internet Options" dialog box, click on the "Advanced" tab, then click on the "Reset" button.
3.In the "Reset Internet Explorer settings" section, select the "Delete personal settings" check box, then click on the "Reset" button.
4.When Internet Explorer has completed its task, click on the "Close" button in the confirmation dialogue box. You will now need to close your browser, and then you can open Internet Explorer again.
To reset Mozilla Firefox:
1.In the upper-right corner of the Firefox window, click the Firefox menu button ( ), and then click on the "Help" ( ) button.
2.From the "Help" menu, choose "Troubleshooting Information".
(Note: If you're unable to access the Help menu, type about:support in your address bar to bring up the Troubleshooting information page.)
3.Click the "Reset Firefox" button in the upper-right corner of the "Troubleshooting Information" page.
4.To continue, click on the "Reset Firefox" button in the new confirmation window that opens.
5.Firefox will close itself and will revert to its default settings. When it's done, a window will list the information that was imported. Click on the "Finish".
(Important: Your old Firefox profile will be placed on your desktop in a folder named "Old Firefox Data". If the reset didn't fix your problem you can restore some of the information not saved by copying files to the new profile that was created. If you don't need this folder any longer, you should delete it as it contains sensitive information.)
To reset Google Chrome:
Before resetting Google Chrome, you first need to remove Ask toolbar extensions from it, change your default search engine, and also change the homepage. To do this, refer to the following steps:
To remove Ask toolbar extensions:
1.Click the Chrome menu button on the browser toolbar, select "Tools" and then click on "Extensions".
2.In the "Extensions" tab, remove (by clicking on the Recycle Bin) the Ask Toolbar and any other unknown extensions from Google Chrome.
To change default search engine:
1.Click the Chrome menu button, then select "Settings", and click on "Manage search engines" in the "Search" section.
3.In the "Search Engines" dialog that appears, select "Google" and click the "Make Default" button that appears in the row.
4.Search for "Ask.com" in the Search Engines list, and click the "X" that appears at the end of the row.
To change default Homepage:
1.Click the Chrome menu button, and then select "Settings"
2.Go to "On Startup" section and select "Open the New Tab page"
2.Click on "Show advanced settings" at the end of the page and go to "Reset Browser Settings" at the bottom of the page
3.On the dialogue box that opens, click on "Reset"
Jun 29, 2014 | Computers & Internet
ERR_NO_SUPPORTED_PROXIES error message with "This webpage is not available" notification. Please help. I downloaded Google Chrome and then received the above error message when I tried to open the desktop...
Hello Nigel,
Try to set the proxy in the browser.
Open Google chrome >>To the right of the address bar at the end is a wrench type icon click on it >>Almost at the bottom of the list it says options click it >> click on the tab that says "under the hood" >> next click the button that Change proxy settings >> in the next box that pops up click on "never dial a connection" >> next click on the LAN button >> next ensure that all check boxes are clear, with no check marks in them click OK >> then click OK again that should bring you back to the Google chrome options box >> click close
Then close out chrome now wait about 10 to 15 seconds to allow for chrome to recognize the new settings >> Reopen chrome and you should be able to use it just fine.
I hope this solution will helpful for you.
Keep Smiling & Keep Using Fixya
Oct 13, 2013 | Google Chrome
My facebook page will not come up. What do I do?
Hi, If the page is not coming up, you can try to reset the IE settings to default settings or using another type of browser like Firefox or Google chrome. To reset the setting on Internet Explorer: - click on tools on the upper right - click on internet options - click on advanced tab - click on reset button For Google Chrome: - just delete the following folders - For Windows XPC:\\Documents and Settings\\UserName\\Local Settings\\Application Data\\Google\\Chrome\\Application
For Windows Vista or later
C:\\Users\\UserName\\AppData\\Local\\Google\\Chrome\\Application For Firefox: you can try to use Firefox in Safemode - a box will appear to ask you what you need to do with Firefox. - then you will asked to restart Firefox again.
Now all the browsers are restored to default, you can now try to log on to Facebook again.
Thank you for using Fixya,
Jul 12, 2011 | Dell Computers & Internet
Error 7
To resolve this issue, delete the Application folder, then try installing again. Follow these steps (for Windows):
  1. Go to the Start menu > Run.
  2. Enter one of the following commands in the text field, depending on your operating system.
    • Windows XP: %USERPROFILE%\Local Settings\Application Data\Google\Chrome
    • Windows Vista: %USERPROFILE%\AppData\Local\Google\Chrome
  3. Click OK.
  4. Delete the Application folder. If you're having difficulty deleting this folder, check for active Google Chrome processes on your computer and end them. Here are a few ways to locate and shut down these processes:
    • Press Ctrl+Alt+Delete on your keyboard and click Task Manager. Click the Processes tab and end every process that includes "google" or "chrome" in its name.
    • Download a third-party program called Process Explorer at http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx. Use its Find menu to search for "Chrome/Application," then end all resulting processes.
    Now try deleting the Application folder again.
  5. Once the Application folder is deleted, try installing Google Chrome again.
Jul 07, 2011 | Google Chrome
How do i change to google browser
Navigate to http://www.google.com/chrome and press the big blue button.
The browser may ask you about what to do with the download. If there is a button "Run", click on it and allow any operations performed by the installer. At the first launch of Google Chrome, you will be asked whether Chrome should be the default web browser. Click on Yes, and there you are.
Jun 28, 2011 | Google Chrome
Why wont Google Chrome respond? The shortcut on my desktop says it has changed or moved...so how do I get into Chrome?
well..there might have been a shift of the main google chrome.exe file or the shortcut might be referring to a different location...to get back to your google chrome....
  1. click start.
  2. click on the search button.
  3. type google chrome and set the location to all hard discs.
  4. you will get the links to all the files with chrome as name in your system.
  5. now click on chrome.exe from this list.
there you have it.....you can even right click on it and click send to desktop(create shortcut)
to have your shortcut replaced by the working new one...
Feb 12, 2011 | Google Chrome
Error 130
Open Google Chrome >>
Next click the button that Change proxy settings >>
Next ensure that all check boxes are clear, with no check marks in them click OK >>
click close
Reopen chrome
Problem will be solved
Feb 04, 2011 | Google Chrome
Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server connection failed.
open google chrome
to the right of the address bar is a wrench icon, click on it.
almost at the bottom of the list it says options, click it
click on the tab that says " under the hood "
next click the button that says change proxy settings
in the next box that pops up, click on "never dial a connection"
next ensure that all check boxes are clear, with no checkmarks in them
click ok
then click ok again
that should bring you back to the google chrome options box
click close
close out chrome
wiat about 10 to 15 seconds to allow for chrome to recognize the new settings
reopen chrome and you should be able to use it just fine
Dec 18, 2010 | Google Chrome
HP EliteBook 2530p Notebook Logo
15 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
