The CMOS battery is located on the motherboard, just behind the speaker/headphone jacks.
You will have to remove the cover (and be careful in the process) to access this area.
With the red arrow, I've indicated on the photo the location of the CMOS battery.
I would highly recommend that you document your procedures and take lots of digital photographs to help you rebuild the device after you replace the battery.
Since you will not find a manual to do this process, you will have to create your own.
Good luck
God Bless
-Carlos:
SOURCE: Compaq V2000 laptop does not power up with AC adapter or battery
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
The controller gets locked up sometimes, you need to clear it out and let it reboot like that....
SOURCE: location cmos battery fujitsu siemens amilo pro V2000
remove main cover on reverse - there will be a small (2cm) flat battery 'probably under some electrical tape' - good luck
SOURCE: CMOS battery on Compaq Presario v2000
Desktop PCs use a battery to keep time when the they are off, much like a watch. Like a watch, the battery needs to be replaced when it runs low on power. Replace the battery using the steps below.
SOURCE: HP Compaq nx9020 laptop cmos battery location on mainboard
On the motherboard,does the battery,that looks like a large capacitor.Have a serial number on it that can be matched to Compaqs operations/repair manual(s).?
SOURCE: I need instructions on replacing cmos battery?
Please click here to open the service manual
1.Prepare the computer for disassembly (refer to Section 6.3, “Preparing the Computer for Disassembly,” for more information).
2.Remove the cmos battery (refer to
Section 6.24, “System Board,” for more information on removing and replacing the RTC battery).
CompQ
