Question about Intel D850MV Motherboard
Lenovo 42y6492 driver - Intel D850MV Motherboard
42y6492 front panel connection
This is a motherboard originally for an IBM Lenovo ThinkCentre A55
I found a manual on:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_pdf/41x5664.pdf
page 43 gives a lay-out overview which connectors need to be attached to the front panel: 12 and 17.
12 are 2 USB 4-pin connectors and 17 is on the picture I found a black plastic block with a special connector next to the CMOS battery.
http://cdn3.volusion.com/wafsx.utqdd/v/vspfiles/photos/42Y6492-2.jpg?1387802031
You might consider connecting simple pins from connector 14, if that is easier for your casing.
Aug 05, 2014 | Lenovo Computers & Internet
I need drivers for windows 8 for my laptop lenovo 3000 y410
GOOD LUCK ITS NOT POSSIBLE WE HAVE ALL TRIED TO NO AVAIL. SORRY
Jan 02, 2014 | Lenovo 3000 Y410 Laptop
Lenovo G585 15.6"inch HD LED proplem my lenovo easy camera is unistall program
The same model Lenovo can have different types of network, video and audio drivers and unless you know exactly which one is installed in your Lenovo, you need to download all the drivers and install each driver until you find the right driver. When you download the drivers, write down the device driver and it's file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive. Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows device drivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
Mar 28, 2013 | Lenovo G585 Laptop
I have a lenovo 42y6492, xp. When I run the bigpond broadband cd to install the ionternet it says no usable ethernet port detected. Cn someone help.
Sounds like the LAN card is not enabled, or is missing the drivers. Check both Network Connections under Control Panel to enable by right clicking, and Device Manager for installing drivers.
Dec 05, 2012 | Intel D850MV Motherboard
I have a school lenovo 42y6492 I need to reset the bios settings, can anyone tell me how to
I would start digging here:
Mainboard 42Y6492
Good luck. Lenovo seems to have deserted this product.
Dec 04, 2012 | Intel D850MV Motherboard
Device shows : STK7700D.
http://consumersupport.lenovo.com/lenovo/drivers/list.aspx?CategoryID=134&page=2
Here is the lenovo site for the drivers for you pc. Only download and install the xp driver versions...after which you should be able to update the drivers for the devices that have the yellow color and should not have any problems installing.
You can also check the windows update site...do a custom update and search for drivers...sometimes new driver versions can be downloaded that way.
Hope this helps
Mar 30, 2008 | Computers & Internet
Intel D850MV Motherboard Logo
562 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
