Question about Canon ES50 8mm Camcorder
Canon ES50 8mm Camcorder will not close with tape only without
The camera is tryed and true but now does not close down into the camera when a tape is inserted. Thinks about it and then pops the loader open. without the tape, inretracts back into the camera just fine. In every other way it is still functionable. Hate to lose and old friend.
    New Friend:
This is a very old post but I was wondering if u ever found a solution? I have the same camera n the same problem
Posted on Jan 12, 2015
I dont know
Posted on Jun 25, 2009
Cassette Door open and close but tape won't go down into deck
The loader motor turns a belt to draw the tape out of the cassette. Probably needs replacing.
Jan 13, 2015 | Sony HDR-FX1000 Mini DV Camcorder
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
Canon ZR300 Mini DV Digital Camcorder THE MINI DV TAPE IT DOES NOT GO INSIDE THE CAMERA, SOUND LIKE IS GOING BUT IS EJECTED WITH A AUDIO WARNING AND IN THE VIEWFINDER SAY REMOVE THE TAPE AND A X APPEARS,...
I know this is going to sound strange. I had the same issue with my ZR300. When you insert a tape and close the mechinism you hear the tape whirl then it pops open and chimes. I found a solution online and thought it was to good to be true. It said to hold the camcorder in your left hand with the right side up (the opposite side of the fold out viewer). You then hit the camcorder , not real hard like slapping something. Open the door and insert the tape and WHAM! It loaded fine. Eight people had tried it according to the review and all eight people had success. I was skeptical but it works! Don't hit it so hard you break it. I did mine twice before it worked but it works everytime now. Trust me just try it and it will work.
Nov 03, 2010 | Canon ZR300 Mini DV Digital Camcorder
I have a Sony Video8 Handycam CCD-FX340 NTSC. It will not accept a tape. I can hit the eject button and the tape mechanism will come up and pop open. If I close it without a tape, it will go back down....
This problem can be caused by condensation. Leave camera and tapes in a warm dry place for a day and try again. If that doesn't help, there may be a tape threading fault. This can be something as simple as a broken drive belt, but still will require professional attention.
Oct 28, 2010 | Sony Video Cameras
Canon es900 8mm camcorder won't allow tape insertion
Canon ES series camcorder was designed with 1000 hour capacitors on the processor boards. When the time comes these capaictors loose value and create problems for the main computer to communicate with other mechanical system in the camcorder. We were able to service well 7 years ago but the life of these component has aged too much to make it good anymore. I wish I have a better news for you but the success repair on 'ES model is very slim and if repaired, the labor charge may run many times over of the value of this camcorder. You can probably obtain a newer used camcorder at decent price and get all you tapes into DVD quick. Good luck -James
Mar 27, 2009 | Canon ES900 Camcorder
Canon zr 300 won't take tape inside
FONZIE FIX! It worked for me.
close the tape load door and with your fist, wack it. worked first time for me. the instructions were to wack it harder each time until it closes with the tape. Look up FONZIE FIX.
Dec 01, 2008 | Canon ZR300 Mini DV Digital Camcorder
Canon zr300 ejects tapes
http://www.fixya.com/support/t985270-cassette_loading_problem_in_canon_zr200
I "smacked" my ZR300 as instructed on this site and it worked. Good luck!
littlequeen
Nov 02, 2008 | Canon ZR80 Mini DV Digital Camcorder
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
Canon zr20
Try toggling the opening hatch, tricking the machine into thinking it's being opened and closed...
May 24, 2008 | Canon ZR20 Mini DV Digital Camcorder
Canon ES50 8mm Camcorder Logo
393 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
