Question about Kitchen Appliances - Others
What does sunshade with firm crust on my security camera mean
    Scholar:
  • 126 Answers
A "crust" is a "hard outer layer that covers something". In means that the sunshade has a rigid shield over the front of the camera.
(I believe the wording is something more recognizable in the UK).
Posted on Apr 25, 2014
Sunvisor removal on 2002 envoy
Here is a parts source. http://www.justparts.com/buy/parts/Query/?q=gmc+envoy+sun+visor
The following are GM directions.
1. REMOVE THE WINDSHEILD GARNISH MOLDING.
2. RELEASE THE FRONT ASSIST HANDLE FROM THE HEADLINER. (TO DO THIS YOU MUST POP OFF THE COVER ON EITHER SIDE AND YOU WILL SEE A RETAINER CLIP ON THE OUTER EDGES OF EITHER SIDE. INSERT A SMALL PICK OR FLAT HEAD
SCREW DRIVER AND PRESS THE CLIP TOWARDS THE INSIDE OF THE HANDLE. THEN PRESS THE END OF THE HANDLE OUTWARD AND PULL IT SHOULD RELEASE.)
3. RELEASE THE UPPER PORTION OF THE CENTER PILLAR TRIM PANEL
. 4. OPEN AND ROTATE THE SUNSHADE PARALLEL TO THE SIDE WINDOW.
5. INSERT A SMALL TOOL INTO THE BEZEL ACCESS HOLE.
6 PUSH UPWARD ON THE TOOL WHILE ROTATING
THE SUNSHADE PARALLELL TO THE WINDSHEILD. THE SUNSHADE PIVOT ARM BEZEL SHOULD APPEAR TO BE RECESSED INTO THE BEZEL.
7. APPLY OUTBOARD PRESSURE TO THE SUNSHADE WHILE THE SUNSHADE IS PARALLEL TO THE WINDSHEILD.
8. PULL THE SUNSHADE DOWNARD WHILE MAINTAINING OUTBOARD PRESSURE TO THE SUNSHADE. YOU WILL NOTICE A SEPARATION BETWEEN THE HEADLINER AND THE SUNSHADE BEZEL.
9. IN ORDER TO REMOVE THESUNSHADE FROM THE HEADLINER, CAREFULLY GRAB THE HEADLINER AT THE WINDSHEILD PILLAR AREA AND APPLY DOWNARD PRESSURE WHILE GENTLY ROCKING THE SUNSHADE UP AND DOWN.
10. REMOVE THE INBOARD RETAINER SCREW.
11. REMOVE THE INBOARD RETAINER FROM THE HEADLINER.
12. IF THE VEHICLE IS EQUIPPED WITH LIGHTED SUNSHADES REMOVE THE ELECTRICAL CONNECTORS FROM THE HEADLINER Take off the two front plastic pieces located at the front of the rails and slide the cross bars off.
You unscrew the two bolts and gently take the visor off the mount. There will be a wire attached that has a plastic male/female connection that can be pulled apart. Do this gently. The wire is the power connection for the vanity light located within the visor.
Jun 14, 2017 | Cars & Trucks
How to remove and replace RIGHT HAND sun visor With lighted mirror on 2004 venture van ?
Remove the screws from the sunshade mounting plate. Pull downwards in order to disengage the sunshade from the roof. Pull down the sunshade in order to access the electrical connectors, if equipped with a vanity mirror. Disconnect the electrical connections from the sunshade, if equipped with a vanity mirror.
Important: Do not rotate the sunshade on shaft. Doing so may cause the sunshade to become mis-aligned and not properly retained.
Remove the sunshade from the roof.
May 25, 2016 | Cars & Trucks
Sun shade is stuck open on 93 accord
make sure the glass is closed, kneel on the drivers seat facing the rear of the car. Grab the sunshade with one hand on each side then pull the passenger side more than the drivers side, basically twisting the shade from side to side as you tug it firmly forward. Worked for mine hope it works for yours.
Apr 19, 2014 | 1993 Honda Accord
Jvc Manuals
When you use this link, you will be on the website of JVC USA. There you can download lots of user manuals. I hope you did not mean to get service of repair manuals. Virtually no firm will give them for free. Not even when you pay for it, it is sure you get it, Because most firms demand some security that only skilled personal can work with their equipment, when it need to be serviced.
Link to JVC manuals
Nov 21, 2013 | Cameras
06 srx sunroof doesnt work
Sorry Bill but you don't the tool's or knowledge to take on this job . Control module's involved.
Which one does your vehicle have ?
Power Sunroof System Components -- CF5
The power sunroof system consists of the following components:
• Front glass control module and motor assembly
• Front sunshade control module and motor assembly
• Sunroof switch
• Front glass panel
• Front sunshade
• Power supply for the front glass control module and motor assembly logic: RAP relay
• Power supply for the power sunroof system: SUNROOF MOD fuse 40 A
Power Sunroof System Components -- C3B
• Sunroof switch
• Front glass panel
• Front sunshade
• Rear sunshade control module and motor assembly
• Rear sunshade switch
• Rear sunshade
• Rear fixed glass panel
Aug 30, 2017 | 2006 Cadillac SRX
How do i attach the raincover to the maclaren major elite buggy
TO FIT THE RAIN APRON
The rain apron can only be used in conjunction with the fitted sunshade.
The rain apron may be fitted with or without the footrest attached.
A Place the rain apron over the attached sunshade with the ventilation vents on each side of the
sunshade.
B Attach the six eyelets (three each side) to the corresponding pins located on the sunshade, rear legs
and front legs.
C Place the rear apron flap between ‘X’ tubes and seat back. Attach the two poppers
Jul 10, 2010 | Maclaren Major Elite Umbrella Stroller
How to remove sun visor on a chevrolet Trailbazer
Hello. here is the instructions for removing the sunshade.
  • Insert a small tool into the bezel access hole (1).
  • Important: Midway through the rotation cycle, the tool will move further into the access hole.
  • Push upward on the tool while rotating the sunshade parallel to the windshield. The sunshade pivot arm bezel should appear to be recessed into the bezel.
    Mar 28, 2010 | 2003 Chevrolet Trailblazer Ext
    Where can I buy a sunshade for a Tasco 6-24x50 AOE scope?
    Burris makes excellent sunshades.They are available from Midway at www,midwayusa.com.Midway has about everything for the hunter and target shooter.Sunshades are relatively inexpensive
    Mar 16, 2009 | Tasco Optics
    The umbrella sun shade won't stay up
    On the front side of the back pack you will notice two sets of snaps, an upper and a lower. Connect the sun shade to the lower set of snaps. Also on th front side of the backpack there is a snap connected to a nylon strap. Secure that strap arround the support rod of the sunshade and to the upper snap on the backpack. connect the two snaps on the back of the sunshade and your done.
    I hope that helps.
    Mar 11, 2009 | Evenflo Trailblazer Framed Baby Carrier
    Pizza is soggy
    Not working properly accordiing to the manufacturer.  Not fixable.
    Jan 27, 2009 | Toastmaster TOV200 Toaster Oven with...
    Kitchen Appliances - Others Logo
    Top Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Irene Tulloch
    Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
