Question about HP Computers & Internet
HP Color Laser Jet 3600n printer error message #62: No System
Printer will only give the message #62: No System.
Next message: To continue turn off then on.
Same message #62 repeats every time. No success.
SOURCE: Emulex NetJet Print Server Problem
The standard port settings used when setting up a Printer Port is Port 9100 (TCP) when normally communicating with the Jet direct / LaserJet 4 plus printer.
However when using the Emulex Card it s default is Port 2501 (UDP). So within XP change the Port setting to 2501 and it then will communicate correctly.
Posted on Aug 18, 2008
sys_admin
  • 829 Answers
SOURCE: Install jet direct in hp 4200
Hi , I need to know why do you require Jet direct . if its for admin then you can use jetadmin.
Posted on Apr 02, 2009
  • 123 Answers
SOURCE: My HP color laser jet 3600n printer is printing
Check your settings......there is a setting for negative in the advanced settings. See if that is the problem. Let me know
Thx
Posted on Aug 01, 2009
SOURCE: Our HP Color Laser Jet Printer keeps saying 50.2
I had a similar problem. make sure the fuser is the same voltage as the printer. 110v printer needs a 110v fuser. easy way to tell. White barcode sticker it is a 110v. Red or Pink then it is a 220v.
Posted on Aug 27, 2009
  • 134 Answers
SOURCE: I have a Hp color laser jet printer it is giving
Here is what HP says... Error message55.1 Error DescriptionDC controller error. The device has experienced an internal hardware error. Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.You could have a bad power outlet. try another one.
Posted on Apr 15, 2010
Hp color laser 3600n 51.20 error
51.XY ERROR
X=2 laser,Y= 0 Black
1. Press to continue.
2. If the message persists, turn the printer off and then on.
3. Reseat DC controller connectors J1010, J1012, and J1021.
Reseat laser/scanner unit connectors J101, J102, J5001A, and J5001B.
4. Replace the flat cable.
5. Replace the laser/scanner unit as necessary.
6. Replace the DC controller PCB as necessary.
Jul 26, 2011 | Office Equipment & Supplies
Hp color laser jet 2605dn gives me a message printing document but does not continue print it then tels me to turn of printer and turn it back on
According to your problem, The instruction is correct.First remove all pending print job from print queue by double click on printer in printers and faxes wizard. Then reboot the printer and system both. After turn on give a print job. If it doesn't help you then check the page setup in printer properties.
Apr 28, 2011 | HP LaserJet 2605dn Printer
Hp clj 3600 error code 51.23 find the solution
51.XY ERROR
alternates with To continue turn off then on
A printer error has occurred.
X Description:
2 laser
Y Description:
0 Black
1 Cyan
2 Yellow
3 Magenta
Your error then comes from the magenta laser.
The recommendations from the service manual are:
  1. If the message persists, turn the printer off and then on.
  2. Reseat DC controller connectors J1022, J1026, and J1027.
  3. Reseat laser/scanner unit connectors J101A, J101B, J5001A, J5001B, and J5020.
  4. Replace the laser/scanner unit as necessary.
  5. Replace the DC controller PCB as necessary.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 08, 2011 | HP LaserJet 3600n Printer
I installed new cartridges (4 colors (B, Y, M & C) and closed the top cover, it calibrating continuously for a week and more. So, please help me to solve this issue. My printer model is HP Laser Jet...
Hi I'm sorry to say its normally a faulty cartridge.
You now the black belt in the front of the machine well the machine when it calibrates prints a pattern on the belt and it uses this pattern to calibrate its self but if the pattern is not on the belt it can not finish the calibration.
solution replace the toners one at a time until you get it going
yours Ian
HP Laser Jet 3600 it has a 51.23 error I
Try replacing interconnecting cables - flat ones
Jan 31, 2010 | HP LaserJet 3600n Printer
Thx
Jul 31, 2009 | Office Equipment & Supplies
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
Computers & Internet Logo
435 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
