Question about Hitachi 20PK 320GB 7K1000.C SATA 7200RPM 16MB 3.5IN HDS721032CLA362 Hard Drive
No hitachi sata 1 hds721032CLA362 drivers
Cant boot from SATA Driver
CompuGuy44
  • 432 Answers
SOURCE: HITACHI DESKSTAR 7250 320 GB HARD DRIVE
File on disk maybe bad. Try this website: http://www.mes.cbs.dk/~sttt/readme.txt and http://www.geocities.com/SiliconValley/Network/2963/files.html
Posted on Jun 23, 2007
SOURCE: Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
hi i bought a 500gb samsung harddrive thinking to install it into my dimension 5000 but i was missing a data cable. i went to dell to ask about where i could find one and they told me that my dimension 5000 wouldnt support a 500gb harddrive. the max apparently is 400gb... if you have managed to get it to work however. please report back.
Posted on Jan 23, 2008
Maanita
  • 1142 Answers
please reset the bios..on dell logo..press f2..press num lock, caps lock ,scroll lock so that all three are on. press alt e
press alt f
select the option that says
save changes and exit
your hdd should get detected.
please post back if it does not work so that i can check out fir further options
Posted on May 04, 2008
  • 153 Answers
SOURCE: Sata Hard Drive not detected on Bios
I would tend to agree that if the ports are set to autodetect it would suggest that they are looking for drives, but go through every item in your bios just to make sure that there isn't some obscure spot where the port is turned off.
If your bios is not detecting a drive your o/s is not going to find it either, and Linux will likely have the driver it needs when you go to load it. What's more, if it doesn't, you're rather hosed until it does.
If everything looks right after checking and rechecking and sleeping on it and checking again, but your bios still won't find the drive, take the drive back and get it replaced.
Posted on Apr 30, 2009
SOURCE: my hitachi hts541680j9sa00 80gb hard drive is trying to boot up windows Vista but I get a blue screen 0x0000007b,0x81e03ba0,0xc0000034. I have tried vista disk system repair and it shows not OS and a
i hav hitachi hdd it has pass word and i have forget them is there any universal pass word i need them
Posted on Dec 17, 2009
Bios reconizes new hd drive but xp pro does not
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 25, 2012 | Hitachi Ultrastar A7K1000 HUA721010KLA330...
BDR206bk/1 Bluray Burner?
It shouldnt need a driver to boot from it on a modern system, as far as i know... although to be honest never tried an install via a blueray drive.
I assume you have already set the boot sequence so this drive should boot first, from within the BIOS.
You can access the BIOS usually by pressing repeatedly either the F2, F10 or delete key, depending on the system, as soon as you power on the system. within there, often under "advanced settings", look for boot sequence... and make sure this drive is listed first... then save changes and exit...
I know there are some issues depending on which sata port u are using on the mainboard... try changing the cable to another sata port. if the sata port is an ODD port, it is often only enabled when ACHI is also enabled from within the BIOS. so, id try changing the sata port the drive is connected to...
a couple of things to try first...
hope this info helps.
May 19, 2012 | Pioneer BDR205 Bluray Burner
I cant download op cd
If the new hard disk is a SATA hard disl then the problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Feb 18, 2012 | Computers & Internet
I want to disable sata mode on my sony vaio vgn-fs742/w, please help because i cant reinstall xp on the system and the lan and wireless in not working when i install windows 7 on it.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 29, 2011 | Sony VAIO VGN-FS742/W Notebook
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
Can not installing windows xp & cant detecting the sata hard drive how can i installed the sata drivers
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive, this will make XP think it is a IDE/PATA hard disk.Then install XP normally. After Windows XP is installed then install all the device drivers (including the SATAdriver), then shut down and boot up and got into the BIOS and enable the SATAdrive.
Dec 15, 2010 | ASUS P5RD1-VM Motherboard
Run a sata drive as main boot up drive. Xp on ide cant see new sata drive to format or install Windows 7?
XP installation does not have SATA drivers.
You need to have the SATA driver on a floppy disk and during the XP installation press F6 to install the SATA driver.
The other alternative is to change the BIOS configuration and set the disk controller to IDE or SATA native driver, then install XP.
After Windows installation then install the SATA driver.
Download the driver from the motherboard WEB site.
Oct 10, 2009 | ASUS K8S-MX Motherboard
Compaq CQ40-108TU unable to install XP OS
Prepare a Bootable XP Disc installer.
At first go to BIOS Setup to Boot First Priority the CD/DVD Rom Drive.
After that disabled SATA or RAID Configuration. The Bootable XP Disc Installer could not go on when you don't disable the SATA or RAID Connection.
Don't worry that you are thinking it would not detected the SATA HDD by Bootable Disc but it is. Then follow the instruction.
If i am helpful to you please rate me.
Thank you.
Yboyandrei
Aug 24, 2009 | Compaq Presario Notebook
When istalling th O/S the system will ask you to press F2 to install the SATA drivers, if you do not press this and install the SATA drivers for the HDD, the system will not read the drive,
Re-install the O/S and watch (( you get 3 seconds to choose it ))
Press F2 when it asks you
(( are you installing SATA HDD ))
Stick the driver in at this point
(( you should have a disc with drivers on it that came with it ))
Finish the install, the system will then read from the SATA drive,
It's because usually the system is looking for a IDE drive.
Your using SATA, so you need to tell the system, that this is a SATA drive,
You will be good to go then
Regards
Richard.
Apr 30, 2009 | Hitachi 1TB 7200RPM 32MB BUFFER SERIAL ATA...
Installing Hitachi P7K500 Sata Hard Drive
Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Dec 31, 2008 | Sprint Hitachi P300 Cellular Phone
Hitachi 20PK 320GB 7K1000.C SATA 7200RPM 16MB 3.5IN HDS721032CLA362 Hard Drive Logo
49 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
