Question about JibJab.com JibJab
When I set my pics, the working icon just keeps going and doesn't finish to put to the position
How do I go from selfie mode to regular pic mode?
How do I take images by Selfie mode using rear camera of ...
www.samsung.com/hk_en/support/skp/.../1063430
Samsung ElectronicsOct 16, 2014 - Tap the MODE icon to change to the Rear-cam Selfie ... When you are positioned, the camera will beep and take a picture after 2secs. 4. 5.
Samsung Galaxy Note 5 Camera Guide: Working with ...
thedroidguy.com/.../samsung-galaxy-note-5-camera-guide-working-with...
Sep 18, 2015 - There are many predefined photo shooting modes you can use on your Galaxy ... Once finished, double-tap the Back key to go back to the camera .... In case you need help, here's how to take a wide selfie on your Note 5:.
5 photo tips: Burst mode, secretive selfies, and more ...
Jan 01, 2016 | Tablets & eReaders
Rcr8622 how do i set time
slide the little 'key' (it looks like an old fashioned key) icon (WAKE1/WAKE2) button on top of the unit to 'clock' position. Press REV or FWD to set the clock time. The time increments or decrements will follow by a faster rate when you press and hold the buttons. The ":" between the hour and minute time flashes when you are setting the time. AM or PM icon will also display beside the time. Slide the switch (that same 'key')/WAKE1/WAKE2/ on top of the unit back to the lock position when finished.
Dec 26, 2013 | RCA Radio Alarm Clock
Motor works and spins but as soon as the drill touches the wall drill stops but motor keeps going.
Check the speed switch on top - sometimes it doesn't fully seat in the 1 or 2 position. Switch it to the opposite setting, run it, then switch back, until it seats properly. Also check the clutch control ring for the same issue.
Jul 21, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
My wife wanted to put pics on mine. now it dosen't work. all i see now is the settings icon and the multimedia icon. what can i do
Make sure that you have the memory card out of the socket. If that doesn't do it, then try resetting it.
Dec 04, 2009 | Amcor 3900 GPS Receiver
My ps3 wont finish game update
this happened to me a while back it was so frustrating. but what i did was go to system settings and click on restore game settings and dont worry it wont mess ur ps3 up. what you need to do after that is if u have a psp registered for your ps3 you have to do that again and if you have any bluetooth devices you will have to register them again and fix all your settings back. also it will not clear gamesaves or pics or song or pics so dont worry. i hope it works fo you to. Good Luck
Jul 28, 2009 | Sony Playstation 3 (PS3) Console
My tomtom 530 is on finish how do i put it on english
Turn on your TomTom and on the map screen tap anywhere, next tap the wrench at the bottom next to the forward arrow, tap the forward arrow until you see a icon of flags, tap the flag icon and set your language
Jul 07, 2009 | Tomtom GO 720 GPS Receiver
How do i put pics on my phillips go gear mp3?
plug in your mp3 player, and then click copy on the pic you want, and then go to my computer and click Paste on your mp3 icon. thats it.
Kwondomaniak
May 29, 2009 | Philips GoGear HDD6330 MP3 Player
RPM too high
your valve tiiming is way off. you didnt work counterclockwise installing the belt keeping it under tension. and pay close attention to cam positions the half moons face up pic here
20a6ca6.jpg now for the correct position of crank pulley
here is the full way to do it just make sure you start at crankshaft working counterclockwise keeping tension on belt as much as possible and when finished always turn engine 2 revolutions with a wrench on crankshaft bolt and double check the alignment before putting back together. but here is the link
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152801ecf2a
Feb 23, 2009 | 2003 Ford Focus
No pic on the monitor
Canon has an option to keep the pic from showing up on the monitor-go to 'clear settings' and put everything back to default.
Nov 29, 2008 | Canon EOS-1Ds Mark III Digital Camera
JibJab.com JibJab Logo
87 people viewed this question
Top JibJab.com Facebook Apps Experts
David Payne
David Payne
shuyumeng
shuyumeng
sdfOYXT
sdfOYXT
Are you a JibJab.com Facebook App Expert? Answer questions, earn points and help others
