Question about Tools & Hardware - Others
TORQ RT50CT3D nail guns - Tools & Hardware - Others
  • 384 Answers
SOURCE: My nail gun will shoot one nail then stop. Any
I had the same problem with my Stanley stape gun. Had to replace all the seals and piston. Works find now! Check-out internet ...search for a rebuild kit for your model of gun. Get the complete rebuilding kit ....take about 1/2 hour to rebuild.
Posted on Jun 12, 2009
  • 108 Answers
SOURCE: nail gun- double feed
Nail guns either have a switch or a seperate trigger assembly for two options - automatic, or 'bump' fire, and sequential fire. Sequential firing may be best for you since the nose must be fully depressed and the trigger pulled for each nail.
If you're stuck with bump firing, practice your technique. Double fires often occur when the workpiece bounces back into the nose of the gun; learn to 'bounce' the gun off the material to avoid this second contact.
If you're getting double fires in sequential mode, the problem could be more serious. I keep a can of aerosol silicone lubricant on hand to clean and lubricate the feed mechanism and magazine. Make sure your tool is clean and lubricated before each use, including the 3-5 drops on the air coupling.
Check that your air pressure is not set too high. Overdriving nails reduces their effectiveness and can cause tool malfunction.
This problem could also be caused by worn out O-rings or other parts within the tool. If you're not comfortable servicing the tool yourself, take it in for repair/maintenance work.
Another important thing to remember: With tools like this, you get what you pay for. A cheap nailgun will never function as well as a quality nailgun.
Posted on Oct 14, 2009
  • 885 Answers
SOURCE: hitachi nail gun,piston/nail push rod
You have one or more worn o-rings in the head of the gun. They direct the air to the proper parts of the gun to first drive the nail then to return the driver to the top of the gun for the next nail. Depending on the manufacturer and your model number, some companies make kits to replace the o-rings (always replace all of them). For some companies you have to get a breakdown of the gun and order each o-ring seperately.
Posted on Oct 25, 2010
  • 1388 Answers
SOURCE: nail gun shoots 1st nail fine then second is a
Miss fire usually occurs when piston/driver is bent, piston oring worn, lower bumper cracked or missing pieces or upper bumper is cracked. Easy to check. Remove head and pull piston. If bent try to adjust, but be careful, blade breaks easily. Piston should fit snugly in cylinder, if loose, replace piston oring. If oring/plastic ring ok examine lower bumper for cracks and replace as needed. If lower bumper ok, pull out headvalve and examine upper bumper for cracks. If upper bumper ok, pull cylinder and look for loose check band around cylinder. Check band is black rubber and should be placed around cylinder fitting snuggly covering series of holes. Replace parts as needed and lube with silicone paste sold at Lowes in the plumbing department (or white grease). Good luck
Posted on Jan 11, 2011
H2_Brad
  • 425 Answers
SOURCE: My nail gun won't fire nails and is blowing It
Stop using it and take it in for service. If it is leaking air then an o-ring or seal may have failed (most likely guess) and it needs to be replaced.
Posted on May 17, 2012
Arrow fastener 2 in. brad nail gun has stopped shooting nails
make sure nails are loaded into the gun straight and correctly
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
What degree nails are used in stanley bostitch n60fn nail gun
I've repaired many nail guns and I can tell you the Stanley Bostitch N60FN uses 15 guage nails from 1 1/4" to 2 1/2" long in the FN1500 series of Bostitch nails. Nowhere does SB or any of their aftermarket dealers list what the angle of the nails is. I do know most of the SB nail guns that come through for repairs are because of damage to them from using other than SB series nails.
Oct 01, 2012 | Stanley Bostitch Nail Gun
Problem: Nail jam due to improper degree of nails Question: How do I take apart the nail gun so as to get the jammed nails out?
Try removing stuck nails without taking apart gun. Remove remaining nails from rails. Use long piece of allen wrench or similar hard steel and grind the end to allow for jamed nail (I use a broken driver blade ground slightly thinner to allow for stuck nail). Use heavy brass or copper hammer to push driver up to top of cylinder. If after a couple of heavy blows the driver does not move, remove the head of the gun and pull out the cylinder and place the body of the gun on plywood. This will protect the head from damage. Good luck
Jul 13, 2011 | Stanley Bostitch Nail Gun
Hi what size staples does the Torq RT50CT3D stapler use? I have run out and have lost the manual. Hope you can help David
This gun can take up to five different sizes.
For my light work I use the Arrow T50 size 8mm staples and they do a lot of different jobs.
I get mine from B&Q.
Hope this helps
Feb 21, 2011 | Garden
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
May 31, 2009 | Stanley Bostitch F21PL Nailer
Nail Guns Safety problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Aug 27, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Nail Guns Types
The real different between nail gun's models are the sort of power supply they use. A nail gun can be powered by compressed air, electricity or batteries, or electromagnetism. Some small guns are powered by butane, a fuel that causes a small explosive charge to drive the nail into the wood. The most common type of nail gun is the pneumatic nailer, which works with compressed air.
Aug 27, 2008 | Stanley Pneu Roof Stapler
How to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Aug 27, 2008 | Mountain Air Blow Gun with Rubber Tip
Tools & Hardware - Others Logo
80 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
