Question about Echo Dolmar 5100 S 510 Ps 460 Cylinder Carburetor Intake
Igniation coils go bad in dolmar 510 chainsaw
I require the complete starting assembly for a Sach DolmAR CHAINSAW, mODEL 116SI
go e-bay and search for-- recoil starters for small engines
or
recoil starter for dolmar chainsaw
Nov 26, 2016 | Garden
Coil for sachs dolmar model 120 chain saw
Ignition Module Coil for Dolmar Maybe for your Country otherwise search by Makita also there are several equvalent parts to get forSachs Dolmar and its cheaper , beware on this to order ignition coils by mention on the serial motor number and the year of build by all orderings if it must be the right combination to get it can be important by marketing technical upgrades / modifications because of changed flywheels in several Dolmar models over past time i know. a suggested coil in a link
Oct 29, 2016 | Garden
How to stop saw from bogging
Two things. First, is the chain dull? Second, if it develops a "throaty" sounds when you're cutting instead of the "crisp" sound you normally get from a chainsaw or weedwhacker or dirtbike... then the carburetor's running rich - it's "four-stroking". Try fiddling with the two mixture adjustment screws; one should be for idle mixture, the other for high-speed mixture. Get the saw idling and turn one of those screws clockwise ONE-QUARTER TURN. If the saw's idle doesn't change, turn that screw one more quarter-turn. if the saw's idle still doesn't change, thats the high-speed mixture screw.
If the saw's idle changes while you're doing that, then you're on the idle-mixture screw - return it to exactly where it was and adjust the OTHER screw clockwise a quarter-turn. Now try cutting - see if you've improved the saw's performance. If it's still four-stroking, try another quarter-turn.
If you go too far, the saw won't want to run at all at higher speeds... so you'd need to back up the screw the other way. Run it at the richest (most counterclockwise) position where it doesn't four-stroke under load.
Jul 25, 2014 | Dolmar Cyl & Piston Cpl Ps-510 - DM...
How do you test a ignition coil on dolmar ps-3410
Replace the coil I have found this is the problem most of the time
but first disconnect the kill switch wire from the coil to make sure the switch is not shorted out
Jan 22, 2014 | Dolmar New Chainsaw PS-3410 TH TLC
Factory carb settings for dolmar ps460 chainsaw
Try squirting a little starting fluid into the carb and try to start. If it will try to run, you have a fuel problem. Try changing the fuel filter first.
Apr 07, 2012 | Garden
Does anyone have the manual for the Makita electric chainsaw model # 5014?
The Makita outlet has 2 different models neither the 5014. Open the saw, Download manual is an option once open.
Dolmar/Makita
http://www.makita.ca/index2.php?event=toollist&categoryid=7
This link has 3 electrics agian none your model.
Dolmar is the actual manufacturer of Makita saws. http://charlotte.preferredpower.com/DOLMAR/Browse.htm
Getting closer 5012 http://www.cpomakita.com/static/manual/www.cpomakita.com-5012b.pdf
HTH
Lou
Jan 23, 2010 | Makita 5012B 12'' Electric Chain Saw
I have a Makita 520i, it won't start and the local repair shop willnot work on it as they say parts are not available. Where can I get it fixed? I live in Colorado
Makita (blue) is the parent company and made by Dolmar (red). Your Makita 520i is a Dolmar 111i. That may open a few avenues for parts.
Dolmar Dealer Locator
http://www.dolmarpowerproducts.com/contact/dealer_locator/
Makita Service Centers
http://www.makita.com/en-us/Modules/Home/Default.aspx
ArboristSite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9
This is a collection of chainsaw enthusiasts, dealers, nuts, etc. I did a search for your saw and got many hits (guess where I learned your saw is a Dolmar 111i, cutinscott I think was born a Dolmar dealer.). It is free to join and they are a pretty good bunch. HTH
Lou
These guys will even help you figure out exactly what is wrong and give advice on how to repair it.
Sep 29, 2009 | Garden
I need a coil for a Sachs Dolmar
This is a an old saw. I suggest you try here:
I did a search for "Sachs Dolmar Super 133" and got over 10 hits.
Please search the existing posts before asking your question, the answer may have been asked and answered. It is free to join if required. They are a collection of chainsaw enthusiasts and very helpful.
This guy is a Dolmar dealer and dealt with them for many years.
http://www.arboristsite.com/member.php?u=3404
Scott has an operational radial dolmar... pretty cool. GL
Lou
I think this answers your question fully. Please rate my answer.
Sep 14, 2009 | Garden
Parts manual for dolmar chainsaw made in 1987. I beleave it is modle ps7900.
I went to the dealer of the chainsaw and asked for the manual.
Sep 18, 2008 | Garden
Open Questions:
Echo Dolmar 5100 S 510 Ps 460 Cylinder Carburetor Intake Logo
76 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
