Question about Husqvarna Garden
Chainsaw won,t start - Husqvarna Garden
How to remove chainsaw muffler
If this is the Husqvarna 440, there are two allen headed screws sunken down inside the holes in the front of the muffler, its either a 5mm or 6mm long arm allen key required.
Jun 16, 2013 | Husqvarna Chainsaw 440E-18
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
Chainsaw won't stay running
You must have dirt in one or more of the carb jets. Remove the carb and clean it with carb cleaner spray and compressed air (compressed air is a must).
May 10, 2012 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Chainsaw won't start. Has spark, has fuel, chain
It starts but won't stop when switched off by stop button it's a husky55
Apr 04, 2012 | Homelite Garden
Runs but the chain won't move? Poulan
This sounds loke the chainbrake has activated, grab the hand guard and pull it fimly fully back to the top handle until it clicks and the brake is of, now try again.
Aug 28, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The chainsaw starts easily. But the chain won't move at all.
Sounds like the chainbrake has activated, grab the hand guard and pull it firmly back to the top handle, until you hear an audible click as the brake loads, now try again.
Aug 04, 2011 | Poulan 14" Chainsaw
3 month old Husqvarna 235. Refuled. Won't start. Plug is firing. Primer bulb gets full. Still won't start.
These machines have had issues with main bearing cages breaking up, this it turn scores the piston and snags the ring in, if there is a good spark and the plug is getting wet i woud whip the muffler off and take a look at the piston through the exhaust port.
Jun 14, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
13 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
