Question about Insignia IS-PDVD10 Portable DVD Player
Portable DVD Player says No Disc
The player says it is loading and then comes back and says No Disc. I have cleared any dust particles
  • 170 Answers
SOURCE: Insignia NS-7PDVD portable DVD player - no picture
The unit is failing and is not worth repairing. There is either a short in the wiring that leads to the screen, the inverter board os failing, or the decoder is failing. These are all hardware problems.
There are several tests to find where the problem may be, but the average consumer doesn't have the ability or access to parts to fix these issues.
Posted on Apr 17, 2008
SOURCE: 7" LG Portable DVD Player DP271
Hi
I have tried to unlock the DVD DP271 player using following methods, But it is not unlocking. If any body knows any other code. Please help me to un lock my DVD DP271 player.
Thanks
Sekahr
1. Power up and press setup
2 Scroll down to LOCK
3 Press '0' (zero) seven times
4. A message may now appear with saying that the player is region free.
5. Power down then power up.
or
1. Remove any discs and power up the DVD
2. Press PAUSE
3. Enter 314159
4. The hidden region code menu may now appear.
5. Set code you want- 0 for multiregion, 1 for region 1 and so on
6. Press PAUSE
7. Power down then power up
Posted on May 20, 2008
SOURCE: insignia portable player NS-8PDVDA not working
Here's how I've solved same symptoms with our NS -PDVD8a:
1. Cleaned laser optics with isopropyl alcohol/swap --make sure you let the optics dry/IPA evaporate from the optics before running
2. Using compressed air can--cleaned laser track
3. Gently move laser along track several times - it seems laser is having most trouble at start of disc -- not sure it needs lubrication, but running it along track several times seems to have righted it
Had to do this a couple of times, but it's working now -- expect I will need to do this again -- no idea how long fix will work.
Posted on Feb 14, 2009
  • 814 Answers
SOURCE: Insignia Portable DVD Player does not play DVDs - says no Disc?
Unit needs to be returned for service under warranty. If not under warranty. You Must open the unit by removing all the screws on the bottom of the unit and use a small plastic pry bar to open the case around the space where the volume control is.slide the pry bar all around the case to open it.Becareful not to lose any of the switch cover that may fall off as you open the case. You must replace these covers exactly to operate the unit once reassembled. Check all rubber bumpers for hidden screws before trying to open the case. you must unlock the plastic locking mechanism all around the case. Then take apart the laser and motor assembly and disconnect all the wire straps and ribbon cables. Clean all these connectors with a contact cleaner by apply it to a cotton swab and cleaning. Try cleaning the laser with a cotton swab and Isopropyl alcohol. Put small amount of alcohol on swab and gently clean laser lens, Check transport for dirt and try cleaning the travel rails of the laser to remove dirt and grease and reapply a small amount of lithium grease to a swab . Lube the rails and ratching mechanism. Do all this with the utmost case, do not use to much grease or you will cause more problems..Use light gloves. do all the work with the cotton swabs. Check disc spindle and see if it is loose, if it is use a drop of super glue to to tighten the grip of the spindle to the motor shaft.Reassemble unit and put together in case put all screws back in unit and test unit on a level non vibrating surface. Use a clear disc from CD cases to check and see if laser is turning on and attempting to track normally. If this does not work attempt to polish laser head with soft foam material and non abrasive high gloss mirror or glass polish very carefully try to make the laser clear and shiney. Do not work to fast and do not push to hard on the laser or you will ruin the alignment.Slowly try to clear the lens of all discoloration.If all this fails try to buy a new laser mechanism from e-bay and replace your old one. Hope this helps you with your problem.
Posted on May 10, 2009
  • 12 Answers
SOURCE: insignia dvd player saying no disc after trying to load w/ disc
have you tryed cleaning the lens and dvd?
Posted on Jun 04, 2009
Put dvd in player and just says loading and you can here it spinning but not loading
purchase a DVD/CD Cleaning Disc. This disc has a little brush on it to clean the dust from the laser head. I hope this helps you. Otherwise you will need to send it to a repair shop.
Apr 22, 2011 | Sony DVP-FX810 Portable DVD Player
It Loads but doesnt spin and said "no disc."
Try cleaning the lens with a DVD Disc Cleaner or Methylated Spirit and a Q-tip, rub the lens slowly in a clockwise motion, leave to dry and put in a DVD, if it doesnt work try a CD but make sure they dont have any scratches or dust on them, if a CD works ( or not ) then your lens is knackered.
jon
Aug 12, 2009 | Polaroid Portable DVD Player PDM-0822BD
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Wharfedale DVD- 265 saying invalid disc
Check and see if there is dust or dirt or something on the lens. Dirt, grease and fingerprints will cause a DVD player to have read errors.
If it a new player, or under warranty, get it replaced. It sounds like it is failing.
Hope that helped.
Jan 01, 2009 | Wharfedale Televison & Video
It cant read a dvd "no disc"
Check and make sure the laser eye is clean and clear of dust and smudges. With player OFF, blow across laser eye. Try cleaning with soft dry Qtip. Otherwise you probably have a bad laser drive or bad drive ribbon cable.
Dec 28, 2008 | Durabrand PDV-705 Portable DVD Player
Wrong disc
Laser lens may be dirty, try gently cleaning it with a cotton bud with a tiny drip of vodka on the end, i mean the tiniest bit. The lens is the small round, domed clear plastic thing in the player under the lid...if it is top loading. Are playing retail DVD's or any sort of disc you have created on a PC. A lot of players dont like RW-DVD disc's.
Nov 06, 2008 | NextBase SDV-17 Portable DVD Player
NO DISK when disk is in. Initial DVD Player Model:IDM-9520
Chances are the Laser that reads the disc has gone bad. It's usually cheaper to buy a new one instead of having it repaired.
Aug 29, 2008 | Philips DVD724 DVD Player
Wrong Disc
It is a bad data cable from the dvd head to the main board
Feb 14, 2008 | Coby TF-DVD7005 Portable DVD Player
DVD player issues
Most likely the dvd is dirty, scratched, or chipped. Try cleaning the dvd disk with a soft cloth (chamois works best). Look at the surface of the disk and if it is scratched lightly, dust and dirt particles, fingerprints, etc will cause refractions from the laser light in the dvd player, which is then read as an error by the dvd player. Cleaning it with a soft cloth will sometimes help.
If that does not work, hold the disk up towards a light source and look for light coming through from the other side. If this happens, the disk is unreadable and unrepairable as the data source has been corrupted.
Dec 17, 2007 | Televison & Video
Coby Model Number TF-DVD7005
Paul Sim, coby portable dvd player model TF DVD7005 keeps coming up with an error message that says NO DISC regardless of whatever disc you put in, the player comes up with the message LOADING on the screen and then stops after a little will and comes up with the NO DISC message
Dec 10, 2007 | Coby TF-DVD7005 Portable DVD Player
Insignia IS-PDVD10 Portable DVD Player Logo
14 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
