Z drive fault (700007) and axis z standstill monitoring (error code 025040 )
The machine was working in this case machine stop and on the monitor error 025040 appears
  • 1294 Answers
SOURCE: machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Posted on Sep 03, 2007
blueextc3221
  • 15935 Answers
SOURCE: Monitor diplays E1 and won't stop beeping
Fitness Quest Eclipse 1175e Elliptical Trainers were recalled on December 11, 2007 for a fall hazard. During exercise, the foot pedal crank can break. After receiving 190 reports of the crank breaking, the company is offering a replacement product or credit toward other Fitness Quest products. If the pedal falls off, be sure to save it; you will need the right foot platform to claim the replacement or credit.
Owners should stop using the elliptical trainer immediately. Owners can receive a replacement with another Fitness Quest product or credit.
Eclipse Recall Instructions and Form (PDF)
Questions? Contact Fitness Quest at: (800) 321-9236 between 8:30 a.m. and 8 p.m. ET, Monday through Friday. Or, e-mail productrecall@fitnessquest.com.
The Fitness Quest Eclipse 1175e Elliptical Trainer was sold at major sporting goods chains, such as Sports Authority, Modell's, Dunhams, and JC Penney stores in the United States from September 2006 to October 2007. Sale prices were $290 and $450.
E1 errors are usually lubrication/resistance issues. Has the unit been oiled/greased recently?
Posted on Jan 10, 2009
budmrtn
  • 11361 Answers
SOURCE: monitor displays text & linework as skewed w/in drafting apps
Thank you for the feedback and the result.
Posted on May 06, 2010
nonontech
  • 4737 Answers
SOURCE: No Display output from Motherboard
To troubleshoot the display, you need to disassemble the system, means you have to open up the cabinet and check the components and connections inside the box. I hope you will be able to open up the box so that you will get the view of the inner portion.
First, you need to disconnect or uninstall everything from the motherboard except the Processor with HeatSink Fan and the Power Connector(s). Unplug the Front Panel connectors (the connectors which come out from the front part of the cabinet, connected to the motherboard). You need to be careful with the main Panel, i.e. the power switch, reset switch, hddled, power led. Before you unplug them, note down the connection sequence if you might forget it. Also take note of the power switch pins, you'll need to short it after a while. Unplug the HDD data and power cables, Cd/Dvd Drive's cables, and everything else. Remove the ram, remove the bios battery.
(don't remove/disconnect the system speaker)
Now, connect the power cord and the monitor on the back, power on the monitor (I would recommend you to connect the monitor via VGA), take a screw driver and short the power switch pin on the motherboard (I've mentioned this to you to take note). Look at the cpu fan and on the monitor, at least the system speaker should beep this time with the beep codes indicating that there's no Ram/Memory installed. (If nothing happens, then there's problem with the motherboard, could be the video card or could be the bios or something else) If so, then turn off and install one Ram. Again power up and check the status, if there's nothing wrong with the Ram, Motherboard, Bios or video Card, then you must see the Bios' System info screen (black screen with white texts after the Dell Logo flashes). If it doesn't seem anything happen, then try with the other/another ram. (If it fails, then there's problem on the motherboard, you better get another than repairing it.)
If it boots up with the Bios System info screen, then turn off and connect the front panel and other panels, like usb or audio etc.. Again power On the machine from the Power switch (this time On/Off switch), verify what happens. if it's ok, turn off and reconnect the hdd and the dvd drive and so on.... untill everything is reconnected and reinstalled or you'll stuck somewhere during the steps when the faulty component is installed.
Let me know the outcome, sorry, this is too long.....but I don't want you to get confused.
Please don't forget to mention the motherboard model and make with the system configuration, otherwise, it's not that easy to troubleshoot..
Till then good luck.
Posted on Nov 09, 2010
  • 6277 Answers
SOURCE: Hi friends, I have Panasonic
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
Please, how can I solve the fault code 19, Master COMM. On my Electrolux W4240H washing machine. All the engineer u contacted didn't get it. Please, help.
Error code 19, MASTER COMM.
Communication with superior system has been broken. The cause can be an error in the network connections, damaged cable, defective monitoring system, etc.
Action: • Contact the supplier of the monitoring system for possible causes of the monitoring system not communicating.
Dado
Aug 20, 2015 | Electrolux Washing Machines
What is error code E3 on Wristech wrist blood pressure monitor Model HL 168ZA
The E3 Fault Code means Error in determining measurement data. In which case, measure again. If this continues to happen contact HoMedics Customer Service @ 800-466-3342.
http://blog.suntechmed.com/blog/23-abpm/310-top-5-reasons-your-automated-bp-monitor-gave-an-error-code
Feb 25, 2015 | Health & Beauty
Determine if the 7,010 fault code is being caused by something wrong in the printer. Refer to Service Bulletin 768. Some common causes are:
Ink in the rollblock from an ink overflow (in such a case the printhead may need to be replaced). Ink shard in the printhead tilt gear. Cracked/malfunctioning printhead restraints. Cracked drum maintenance cam. Stripped gears in the process drive assembly. Cracked left or right printhead restraint. Broken process drive mounting posts (repair using 604K55230 Post Repair Kit). Failing x-axis motor or motor drivers (x-axis motor can't maintain printhead's x-axis position) If there is no apparent reason for the 7,010 fault then flash the printer with a new version of the firmware. See Service Bulletin 777.
Apr 08, 2014 | Xerox Phaser 8560DN Printer
MY DESK TOP COMPUTER, FX4710-UB003A STOPPED PLAYING MY GAMES AND A CODE POPED UP 43, I ALSO HAVE LINES ON MY MONITOR, I THINK IT IS MY HARD DRIVE.
Lines on the monitor is a signal that the monitor might be bad or the video card is going bad.
Try another monitor on the computer. If you don't have one borrow one from a neighbor, friend, relative or co-worker. If the other monitor works without showing the lines, then your original monitor is bad. If the other monitors shows lines just like your original monitor then the video card is going bad.
When does this code 43 pop up? Does it give you any error message with the code?
I looked it up and i think it has to do with a usb device.
Check the links below and see if they help you.
http://pcsupport.about.com/od/errorc/a/code-43-error.htm
http://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/code-43-error-on-windows-7/be1bdcca-7864-47c8-b9e0-cbc65488ba22
May 04, 2012 | Gateway FX4710-UB003A Core 2 Quad Q9300...
Error code 07,010.43:33605
Reset all the connectors of your printer, this might be a power, or censor problem. For a detailed troubleshooting click here.
Oct 19, 2011 | Xerox Phaser 8500/DN Printer
Catulyst monitor and evap system monitor and oxygen sensor not ready also P0501 code
Diagnostic Test Code (DTC) P0501 "Vehicle Speed Sensor Range/Performance"
DESCRIPTION
The Wheel Speed Sensor (WSS) generates a waveform with a frequency according to the speed of the vehicle. The signal generated by the WSS informs the ECM not only if the vehicle speed is low or high but also is stopped the vehicle or not. The ECM uses this signal to control the fuel injection, ignition timing, transmission/transaxle shift scheduling and torque converter clutch scheduling. Also the WSS signal is used to detect rough road driving condition.
Whenever Your OBD readiness monitors cannot complete it is because there is a problem that is affecting fuel mixture, ignition timing, or any other fault that can affect the level of tailpipe emissions. Once these faults are repaired, then the codes must be ereased so that the monitors can run and "re-test" the system to check for the same, or any other faults. The goal is for all the monitors to run and change to "complete" without any fault codes present.
In your case, the wheel speed sensor fault needs to be diagnosed and repaired so that the monitors will complete. Also note that one incomplete monitor can prevent other monitors from running. In your case, the catalyst monitor cannot run because the O2 sensor monitor is not complete. The catalyst monitor can only run AFTER the O2 sensors have received a "clean bill of health" from the O2 sensor monitor. The wheel speed sensor problem is keeping the O2 sensors from being tested.....So the wheel speed sensor problem is pretty much causing the whole thing.
Here's the kicker...If the vehicle has been driven in this condition for a period of time, there may be damage to the catalytic converters. The computer does not know this yet because the catalyst monitor cannot run. So it is possible that you can fix the wheel speed sensor thing, the O2 sensor monitors will complete, then when the catalyst monitor runs it could set a "catalyst efficiency" code. Then you will have to replace your catalytic converter to fix that. I'm not saying that this WILL happen on your vehicle, I am just saying that it CAN happen so you will not be confused IF it DOES happen. I see this all the time, and I have had customers accuse me of doing something to their car so I could sell them a high-dollar catalytic converter. This is simply not the case...I had no way of knowing that the converter had a problem because when I first received the car, the catalyst monitor was incomplete and there was not catalyst code present at the time.
So the only way to do this is to correct ALL fault codes one at a time until all monitors are complete and no fault codes are present.
Sep 17, 2011 | 2004 Hyundai Elantra
What does the code E3 mean?
Apr 08, 2011 | Walgreens By HoMedics Automatic Wrist...
Hi my computer is playing up when i turn it on it says PXE-E61: MEDIA TEST FALURE. CHECK CABLE, but all cables are good. also when i scanned it using the dianostic tool it says error code: BIOHD-8 AND...
Disconnect the Floppy, CD/DVD and any other Drive you have connected and boot the machine. If the machine boots shut it down and connect the disconnected devices 1 at a time until you have it isolated. If the Computer doesn't boot and you still get the same fault then your hard drive has faulted try a different drive.
Jul 12, 2010 | HP dx2250 Monitor Personal computer AMD...
Xerox Workcentre c2424 Error Code "37,030.48"
Hi Ian_a_nicol:
error code # 37,030.48 means X-axis motor disconnect. The X-axis motor (second phase) is not drawing the expected power from the power supply. you can do the following to determin if the X-axis motor is bad.
1. Run the X-axis Drive test and if it passes
replace the electronics module, if not see #2.
2. Check the X-axis motor wiring for damage
or replace X-axis motor.
3. Call Xerox to have them come out and run the test and determin if it is the electronics module or the X-axis motor, but is one or the other.
pdouglasss
Oct 24, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
