Question about Maxtor OneTouch II 300 GB Hard Drive
BURNED CKT Comment by oldfishhook, posted on Nov 02, 2007burned my circuits the same way How do fix it or pull the dat to anaother drive. Can I buy the ckt parts and repalce.
  • 661 Answers
If it is the USB adapter that is part of the enclosure, (not the disk itself) you can transfer the HDD that is inside this enclosure into a generic external HDD enclosure. either that or you can use an external HDD adapter to access the data on a disk (like Magic Bridge), this is and adapter without the enclosure, and is fairly handy if you need to get data from HDD in this way.. or to Clone disks
Posted on Nov 14, 2007
Saui TVM1316 full ckt diagram
Check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Circuit diagrams are in PDF. Cannot include it here by this windwow.
Jul 15, 2014 | Sansui TVM1316 13" TV
Still looking for help on Pioneer SD-582HD5 TV Monitor
hi you guys well this is a comon problem with pioneer most boards have lots of cold solder connections this will also make the symptoms like blown h-out mark all the connections on the powersupply board connections meaning all the wires you seethat connect to the board then remove the board from the tv this will make the repair more easy for you then look very close eventhough you might think that there is no broken connection there might be so go over this very carefully and slow make sure that you dont create any solder bridges after you have done his then you must go to the regulator cuircuit you might have some connections there ok now we are going to find the horizontal output transistor this guy is located neer the flyback transformer this (fly) sort for flybacktransformer is a big black looking transformer with a red wire comming out of it DANGER you are in the high freqency part of your tv pic tubs may store electricity this will make you think twice befor messing with tvs again ok this transistor is mounted to a large heat sink sometimes by it self check with vom meter in diode mode from collector to emitter then emitter to base if from collector to base reads short then it is bad if from collector to emitter it is bad the only short should be from emitter to base replce fuses and try again hope this helps
Nov 15, 2007 | Pioneer SD-582HD5 58" Rear Projection...
  • Feb 7/11 - P0405
  • Jan 11/11 - P0336 - P0326
  • Dec 28/10 - P0217 - P0218 - P0163 - P0230 - P0231 - P0232
  • Dec 9/10 - Trouble Codes: P0170 - P0173 - P0162 - P0154 - P0142
  • Dec 6/10 - More DTC articles: P0157 - P0158 - P0160 - P0200
  • Nov 30/10 - DTC articles posted: P0505 - P0156
  • Nov 18/10 - More new articles: P0143 - P0144 - P0146 - P0147 - P0152
  • Nov 12/10 - P0120 - Throttle Position Sensor/Switch A Circuit Malfunction
  • Nov 11/10 - ECT Circuit Codes: P0116 - P0117
  • Nov 10/10 - P0111 - IAT Circuit Range/Performance Problem
  • Nov 7/10 - P0110 - Intake Air Temperature Circuit Malfunction
  • Nov 6/10 - P0108 - Manifold Absolute Pressure/Barometric Pressure Circuit High Input
  • Oct 21/10 - P0216 Injection Timing Control Circuit Malfunction
  • Sept 11/10 - Knock Sensor DTCs: P0327 P0332
  • Mar 15/10 - P0607 Control Module Performance Code
  • Mar 4/10 - P0606 PCM Processor Fault DTC
  • Feb 10/10 - New ECT Sensor article
  • Feb 9/10 - P0012 & P0022 - Camshaft Position - Timing Over-Retarded
  • Feb 2/10 - P0115 - Engine Coolantmag-glass_10x10.gif Temperature Circuit Malfunction DTC
  • Jan 19/10 - P0105 - MAP/Barometric Pressure Circuit Malfunction
  • Feb 10, 2011 | 2004 Chevrolet TrailBlazer
    Samsung HCM653W Convergence problem
    CK low ohm resistors and pico fuses some are green,some are yellow .they will be around ics some may be under heat sinks that hold STKs.
    Nov 29, 2008 | Samsung HCM653W 65" Rear Projection...
    check the mass air flow sensor if still no spark check the coil packs for power if they dont have power check all fuses and relays if they are all fine look for a short
    Nov 17, 2008 | 1996 Pontiac Grand Am
    Samsung Prostar DCS
    Thanks for the reply. OK, what is the full model number? prostar 816, 1224, etc?
    Nov 09, 2008 | Samsung Phone PDCSLCD12B
    Water damage recover MOTO Q SMARTPHONE Further assistance
    oprn ur mbile circuit and remove battry and put them in sunlight not the battry okkkkkk
    Nov 27, 2007 | LG VX6000
    Plastic arm of water dispenser broken off - need help trying to remove plate to access screws for replacement
    Try looking under bottom edge of control pad that says monogram on it. You should see 2 or 3 holes. Push in with a blunt object in either end hole while pulling panel forward. Then dot the center if has one, then the end one. MAKE SURE YOU HAVE POWER OFF!! Now you can see 4 screws to access rest of dispenser.
    Nov 19, 2007 | GE GSS20IEP Side by Side Refrigerator
    Maxtor OneTouch II 300 GB Hard Drive Logo
    110 people viewed this question
    Top Maxtor Computers & Internet Experts
    Arora Singh
    Arora Singh
    Computer Links
    Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
