Question about ASUS W2W-7M006G PC Notebook
Hardware problem it won't work
My LG GC900f's camera suddenly won't work. I last used the camera three days ago and it was great, but when I tried it earlier, it just won't open. Even the apps that need the camera, won&
Don't take it to any normal technician. Go to Authorized service of LG and get it done. It is not any software issue, i think it is hardware problem.
Performance Chip
Aug 21, 2012 | LG GC900F Cell Phone
Hard drive
It means that your HDD is damage, no good. Need to get another one and reformat your computer.
The way to troubleshoot any computer that won't turn on is checking the power supply fan to see if it does anything when pressing the power button. If you see that the fan try to start but stall, then there is a bad hardware install. What I do is take all the hardware out and start the troubleshooting by installing the hardware one at a time. When the computer stop responding after installing one of the hardware, then it means that this hardware is bad. You already troubleshoot the computer by installing the HDD and seeing that the computer won't start.
May 27, 2012 | HP Pavilion g60-440US Notebook
Hardware
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Nov 24, 2011 | Nokia 5530 XpressMusic Smartphone
I know I need to upgrade my flash player and a 11player won't work so how do I find a player number 9 for my cell phone its a android
To upgrade flash player, your mobile should have appropriate hardware to support. If you are trying to upgrade from market,it upgrades. But won't work. So you need to uninstall the upgrade and switch back to the older version of flash. Otherwise upgrade the required hardware for Flash to work.
Thanks,
Mr.Maduraikaran.
Oct 19, 2011 | Jaytronix Android Apps
Dvd won't recognize media
tray to clean ur dvd lanes by dvd lance cleaner cd/dvd
http://www.youtube.com/watch?v=WaiTJYHQCCg
Sep 22, 2011 | Dell Vostro 230 PC Desktop
I dropped it and now it won't work. It starts but there is a knocking noise and won't select movies or do anything.
Remove media player from CPU ("Add and remove Programs" or "Programs and Features" both under control panel), then Google Windows Media Player, free down, if that doesn't work, its most likely a hardware issue. Hope it works!! :)
Jul 10, 2011 | Microsoft Windows Media Player
Can i use my emachine recovery disk on my gateway after i install a new hard drive on my gateway?
No, you can't. (Well, it might be possible, but very unlikely, that it would work.) Recovery discs are made for specific machines. There are a couple of reasons why the discs for one system can't be used for another brand or model.
In addition to installing the operating system (Windows), recovery discs also include drivers for the machine's included hardware (video, sound, media card slots, etc.). The drivers on the recovery disc for an eMachines system won't have what a Gateway system needs, unless they were built using exactly the same motherboard and other parts, which would be quite unusual. If wrong hardware drivers are installed, Windows may not start and give you the famous "blue screen of death". Or Windows will start, then begin finding new hardware and asking you for drivers you won't have (although you could find them at the Gateway website). The discs also include the applications the manufacturer preloaded on the system. Some of these may not work and cause problems because of the hardware differences (a sound control program with the wrong sound hardware, for instance).
The other reason is that a restore disc also includes information that gets placed into Windows so the system comes up already activated and ready to go. Activation is based on information about the hardware configuration of the system, and yours won't be correct. Windows will see the this and you'll need to activate manually. If the Windows version on the eMachines recovery disc isn't exactly the same as the one on the Gateway, the product key on the computer won't work when you try activation.
Rather than try using the wrong recovery disc, see if you can borrow or download the installation disc for the Windows version specified on the product key sticker on the Gateway. Then you can do a clean new Windows installation and activate it using the product key. You can find the drivers your computer needs at Gateway's website as I mentioned before. It's more work than just running the recovery disc, but it will work. This does mean the system won't have any of the preloaded applications originally on the computer when you're finished. But this is not a bad thing.
Much of the preloaded stuff on a new computer is often called "bloatware", which you really don't need. It just slows the computer down, uses up Windows resources, and may be gathering information and sending it to sites behind your back. You can find good free programs to do anything originally installed and install only what you really need and want. Here are a few suggestions to get you started:
CD/DVD burning: CDBurnerXP
Antivirus: AVG, Avast!
Audio processing: Audacity
Image processing: GIMP
Office suite: OpenOffice
Good luck getting the system back up and running. Thanks for using Fixya!
Jun 30, 2011 | Gateway GT5670 Desktop PC
Is it possible to reflash my SGH a867, so i can change the 3g 850mhz 1900mhz set by at&t, to 900mhz too 2100mhz
Reflashing won't do you any good. It's not a software issue that controls the bands, but rather the hardware. Without the hardware in the phone to communicate on those bands it won't work.
Jun 10, 2011 | Samsung Eternity SGHA867 3G NEW
I just bought Intel ATOM D425 MB. I installed winxp. Everything ok. But Network drivers not installed. In device manager it shows as unknown device. I searched the Intel site.They dont also have the LAN...
OF COURSE there are no Windows XP networking drivers for this Intel motherboard. WinXP was released in 2001; this motherboard wasn't even DESIGNED until XP had already been replaced by Windows Vista and Windows 7. Why would Intel ever bother to make drivers for an OLD operating system for NEW hardware?
You bought NEW hardware; you need a NEW operating system to make it work. If you want to use XP, you won't be able to do any networking with this system. If you want to be able to network this system, you'll need to buy a modern operating system for the modern hardware.
I know this isn't the answer you want to hear, but you also won't find Microsoft writing a NEW operating system to work with my OLD AMD 386DX-40 motherboard. Of course, you can always complain to Intel and Microsoft, but that won't change the reality. You have NEW hardware, which is great, but NO ONE is going to design and write NEW drivers for an OLD operating system to work with your new system.
Apr 27, 2011 | Intel D425KT Innovation Series Motherboard...
ASUS W2W-7M006G PC Notebook Logo
13 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
