Samsung top loader WA13V5 fully automatic washing
Samsung top loader WA13V5 fully automatic washing machine not draining water
  • 46 Answers
SOURCE: Overflowing washing machine
check the pressure switch . its circluar in shape with 6/8 wires attached, and a small nipple with a 10mm pipe attached. as the water rises in the drum air is pushed up thru this pipe which when working ok , eventually pushes against a switch .hence its name. so, if there is damage to this pipe( maybe rubbing against the drum) the passage of air escapes before reaching the switch. if the pipe is ok then check the switch by blowing up the pipe (with the power off ) and u should hear a small click inside the switch. if not replace
Posted on Feb 07, 2008
futureloginn
  • 734 Answers
SOURCE: Daewoo Top loader washing machine water wont drain...
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
  • 490 Answers
SOURCE: washing machine not spinning or draining water
its your drain pump if you can hear it humming but no water is draining it is blocked or jammed by a foriegn object (most probably a 20 cent coin or bobby pin/s), if you can hear it working as normal but still no water it may have a blockage sumwhere along the drain pipe either that or the impellor has snapped off the shaft and is ratteling around and not actually turning, and with the spin that is directly related to yor drain pump issue as the washer will not even attempt to spin if water remains in the tub, incredibly easy to do hit me back if you want detailed instructions
Posted on Oct 14, 2011
Samsung wa13v5
The seals in the bottom of the drum where it connects to the gear box is going bad. Changing them out is something that you can do but it is not easy. You pull off the top cap on the agitator and then take off the nut and lift the agitator out, then you can see the seals.
Jan 19, 2014 | Washing Machines
Samsung WA13V5 Fully Automatic Washing Machine. Code error:E4. We bought this machine on 15 August 2012 with Gaurantee of Two Years and a extended Warrantee of 2 years at Game store ILLanga Mall Nelspruit....
when you say water goes out at the same time as going in? have you put the bent in the back of the drain pipe or is the pump pumping it back out ?
Jul 01, 2017 | Washing Machines
Samsung wa13g7q1 top loader
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
Nov 18, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
5E. Water Drain Error.
5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
can be rectified by turning the POWER SW OFF AND THEN BACK on.
Hope this helps you
Feb 01, 2012 | Samsung Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Washing Machines Logo
368 people viewed this question
Top Washing Machines Experts
