Question about Dacor Ovens
Off displays It's shows "off " on both sides of the clock and beeps sometimes.
2 Suggested Answers
  • 30 Answers
SOURCE: Kenmore electric built-in oven model 911.47702201
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. Good luck!!!
Posted on Nov 08, 2009
Whirlpool rbd305pds15 -- display works, there are no error codes. But oven randomly beeps, sometimes once then the next time multiple beeps. No luck disconnecting power for 12 hours
the computer board or clock assy. is bad and you can't get this part anymore the stove is to old and it says on the parts site that it's discontinued part WPW10438751
Nov 05, 2017 | Whirlpool Ovens
How to stop WB27K5040 from beeping F1 error code
Unfortunately, the F1 error means that either the touch pad has a short or the "clock" (electronic control unit) has failed. Sometimes the wire between the touch pad and the clock fails. To test for the exact problem, you would need to unplug the range and access the clock from the back of the range. Unplug the touch pad from the clock. Then plug in the range again. If the error does not recur, the touch pad is bad. If the F1 error and beeping repeat, the clock is bad.
GE sold the clock and touch pad as a single unit for the WB27K5040. Since this is an older model range, the replacement is not in stock. There are some places that offer to repair the clock. You'll need to remove the part (or get a service person to do it) and send it in. Your range will be unavailable for some weeks while this is attempted. Otherwise, you should replace the range when the issue becomes too frustrating.
I hope this helps.
Aug 28, 2014 | Ovens
My display panel doesn't show lights. It will beep when I touch the clock, etc., but no lights. The inside oven light will come on. How can this be fixed?
This is a failure in the control board. It can be rebuilt by fixyourboard.com to save money vs. buying a new one. It is often an intermittent problem and sometimes accompanied by a random E6 F2 error when (or if) the display comes back on.
Aug 15, 2010 | Whirlpool RBD275PD Electric Double Oven
When using oven F3 or F5 comes up on the digital display and it beeps. Sometimes it says err on it. Very frustrataing, use my oven a lot.
Replace the temperature sensor first. It may solve both problems. If not,the clock will have to be replaced too.
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
Nov 09, 2009 | Maytag MEW5530D Electric Single Oven
Kenmore electric built-in oven model 911.47702201 just started showing 2 error codes and beeping. F7 is in red and on the left side of the display, E8 is in green and flashing and is on the right side of...
Nov 04, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Control beeps continuously. Display shows F1. Started when oven had not been used for a long time. Pushing oven and timer off buttons resulted in 10 seconds of silence before beeping resumed. Same for...
Usually, This means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 28, 2009 | GE Ovens
GE Profile oven beeps and displays FO
Your electronic oven control(clock) is bad and must be replaced.
Sep 02, 2009 | GE Ovens
Range developed problem while cleaning oven
Your electronic oven control is bad and must be replaced.
The clock.
Mar 15, 2009 | Ovens
Fault Code F1
Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Ovens Logo
18 people viewed this question
Top Dacor Ovens Experts
Vitaliy Gins
Vitaliy Gins
ashburton
Oloyede Monsuru
Are you a Dacor Oven Expert? Answer questions, earn points and help others
