Question about Onkyo TX-NR626 7.2 Channel Network A/V Receiver with 4k Video Upscalin
Adding an external amplifiier or db display
How do I add and external equalizer / amplifier db display to the onkyo tx nr626.
  • 113 Answers
SOURCE: ONKYO TX-SV717PRO Amplifiier
disconnect power and try after 20min without speakers.
Posted on Aug 22, 2007
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
dunnbiker
  • 8546 Answers
SOURCE: Graphic equalizer
In general all equalizers, being designed to be in a Tape Monitor loop, have the option to Equalize either the Source or the Tape or nothing. Check for that control and toggle it. My old ADC SS-525X has pushbuttons whose settings (Tape/Source) are not easily determined. I always have to play around with it to know which is selected.
I'm betting your EQ is processing the program that would head out to an attached tape deck.
Posted on May 18, 2009
JOHNSONELECT
  • 113 Answers
SOURCE: connect an amp to a Onkyo tx-904
tou may want to hook this to speaker select switch
Posted on Aug 28, 2009
  • 17 Answers
SOURCE: My TX-SR702 receiver often displays a 'Dialog
Need to know your source and exactly how that source is connected to the receiver. Also need to know what surround sound mode you are using and whether the program material that drops out is compatible with that decoding format. Might be as simple as changing surround modes when this happens, but you should know that many cable boxes and some disc players routinely drop their digital audio signals from time to time and can give you these symptoms. Best remedy is to call Onkyo tech support with all of your information requested above documented in one place. They can help you troubleshoot while you are in front of your receiver.
For Product Support Team Only:
1-800-229-1687
Hours:
M-F 9am-8pm | Sat-Sun 10am-4pm ET
Posted on Jul 24, 2010
How to run the speaker wires from the subwoofer to the onkyo 7.2 tx-nr626
See Onkyo manual here: http://filedepot.onkyousa.com/Files/own_manuals/TX-NR626_English.pdf
Insignia manual:
http://audio.manualsonline.com/manuals/mfg/insignia/nsht51.html?p=1
Best hookup method for sub is to use the LINE LEVEL INPUT on the Insignia, wired with RCA cables to the Subwoofer Pre Out jacks on the Onkyo
Jul 20, 2015 | Insignia NS-HT51 Speaker
Onkyo tx nr626 when volume high like 70-80 it turn off sign check speaker wires
soundslike a shorted speaker or a speaker that is being over-driven
Jan 07, 2015 | Onkyo Tx-sr507 A/V Receiver
Onkyo Tx NR626 receiver cooling fan does not run. Normal or not? Does chassis to need to reach certain point before it comes on?
most cooling fans in receivers only come on when they are needed. Some turn on at higher volume levels, others will not turn on until the unit gets too hot.
Dec 09, 2014 | Onkyo Audio Players & Recorders
I have a new NR626 and I am unable to get the Sub Woofer Pre Out to work with my Bose Lifestyle Series II system with speakers. I tried connection the Bose through RCA to the NR626's Pre Out jacks, bu
usually if you have a sub out (line level) on the receiver..u can plug it directly into a pwrd sub and its plug and play..try putting another source into the woofer to see if its blown..if its not..then play with your menu settings on your nr626..get back to me if you need more help
Jan 08, 2014 | Onkyo TX-NR626
I have a onkyo tx 8555 receiver and i also have a equalizer hooked up to it, i get more output/power from the equalizer is there another way to add on to my receiver to get more power? my old receiver is...
You may think you're getting more power but you're probably only getting more volume. Adding external processors does not increase amplifier power.
Jan 19, 2010 | Audio Players & Recorders
Onkyo tx-SR605 - how do I use as a processor and
IF and only if, your receiver has connections labeled as "pre-out" can it be connected to an external amplifier.
If it does, then you connect from the left and right channels from the receiver, to the left and right channel on the amplifier.
Jan 02, 2010 | Onkyo TX-SR605 Receiver
Amp protection circuit has been activated
1-check your input cables from connected equipments(cd player or dvd p
layer or any other media source).
2-adjust your input signal level(from-10 db to 0 db).
3-amplifier power must be bigger than total power of all loudspeaker with 20%----(if total power of loudspeaker is 8 watt amplifier must be 10 watt.
Nov 28, 2009 | Onkyo TX-SR605 Receiver
Aug 19, 2007 | Onkyo M-282 2-Channel Amplifier
Onkyo TX-NR626 7.2 Channel Network A/V Receiver with 4k Video Upscalin Logo
Top Onkyo Televison & Video Experts
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
