Question about Ovens
How old is my paj509r stove - Ovens
I have an old Admiral stove, unknown model #. Black, smooth top- all else is white. Wording on the oven buttons have erased, i have no clue what degree i am setting to and or if baking/broiling. Help!
go on line and type in admiral stoves
there are pages of parts suppliers
on the back of the stove or inside the inspection plate at the back there will be a decal stating the model and serial number of the stove
Apr 23, 2015 | Ovens
Hotpoint stove timer replacement
what color wires are on the new timer?
Apr 07, 2008 | Ovens
Old timer wood stove manual
I need to find a owner manual for an old timers wood burning stove insert or at least how to replace the fire bricks
Jan 07, 2014 | Ovens
How to change cooking element on top of stove. is there a detail drawing and manual stove is 4 year old
Electric stove top? Is the element a coil or soild element? Or is it a glass top?
Feb 07, 2011 | Ovens
My Dimplex coal effect black stove won't work. The problem started quickly. One time it worked, next it didn't. I have changed the fuse so that isn't the problem. Although the stove is about 12...
My Dimplex coal effect black Problem with the Dimplex Compact Electric Flame Stove Heater My Dimplex coal effect black stove won\'t work. The problem started quickly. One time it worked, next it didn\'t. I have changed the fuse so that isn\'t the problem.Although the stove is about 2yaer old, I have only used it about five times as it is in my drawing room that I sit in rather infrequently.I do hope you will be able to advise me the source of the problem.Thank you. salvador -
Oct 31, 2010 | Ovens
I have an Inglis stove around 10-15 yrs old. When
Yes you can but not the elements themselves
Nov 29, 2009 | Ovens
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Ovens Logo
14 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
