Question about Huffy Cycling
Rear wheel clicking - Huffy Cycling
  • Huffy Master
  • 1,241 Answers
Need more info before diagnosis - otherwise it's just guessing, as there are too many possibilities.
  1. Is the clicking in time with pedal/crank rotation, wheel rotation, multiple crank rotations, or random?
  2. Does it occur just while pedaling or while coasting?
  3. If while pedaling is it more common under greater pedal pressure?
There is no way for anyone to determine whether it is a serious problem without knowing what the problem is, but most of the things that cause clicking will only get worse and more expensive with time.
Posted on Apr 04, 2016
    New Friend:
  • 35 Answers
Could be caused by worn wheel bearings if the clicking is not intermittent. If the clicking only occurs when pedaling and sounds rhythmic, this could be caused by the chain and/or sprocket. Some 6 and 7 speed sprockets are renowned for this rhythmic sound under pressure but it doesn't seem to be a serious problem.
I have a 2003 Kia Sorento and have a clicking noise coming from the rear passenger wheel area when driving. Could that be the rear end going out?
This noise could be a Joing going out... If this car is a 4x4 then they have a CV joint on the rear to.... If not it could be a rear bearing.... I also something very minor.... If you have plastic hub caps on the rear please take them off then go for a drive to see if the noise continues... This dose sometimes help.... The aftermarket ones can make a noise as i have seen it happen offten
Nov 29, 2012 | 2003 Kia Sorento
How to adjust rear brakes on toyota coaster
There are usually two ways to go about adjusting the rear brakes, both involve getting the rear wheels off the ground on jack stands. Look for a small oval shaped rubber plug near the top on the brake backing plate where the brake line goes, there is a star adjuster wheel inside, with screwdriver rotate the wheel upward, there will be a clicking noise, ecah click tightens the brake, rotate the wheel while doing this until the wheel has a slight drag while rotating then stop. The other whay is to remove the wheel and the brake drum, then adjust the star adjuster a little at a time until the brake drums just fits over the brake shoes.
Nov 23, 2011 | Toyota Cars & Trucks
Hi, ive just bought a qunniy buzz 3 chassis with no rear wheels and was just wondering if any quinny buzz rear wheels will fit? many thanks
Good Afternoon
As long as the rear wheels you fit are for the Quinny Buzz they will fit. Older style wheels will have a slightly different hub cap to the newer style wheels. Older style wheels may not be an ideal fit in a newer chassis as they may not click in properly though so it would be recommended that the wheels purchased are the ones relevant to the chassis.
Aug 21, 2011 | Quinny Buzz Three Wheel Stroller
Procedure for replacing rear whl brgs on a 2003 escape awd
4-Wheel Drive
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Rear wheel
    • Rear brake shoes
    • Rear halfshaft nut and loosen the halfshaft from the hub
    • Wheel hub and place it in a vise
    • Inner wheel bearing race from the hub
    • Antilock Brake System (ABS) sensor bracket and move the sensor aside, if equipped
    • Parking brake cable from the steering knuckle
    • Brake line from the wheel cylinder and support the knuckle
    • Lower shock absorber nut
    • Lower ball joint by holding the ball joint stud
    • Upper ball joint
    • Coil spring while noting the location of the insulator
    • Steering knuckle cam
    • Steering knuckle
    • Snapring and press out the outer wheel bearing race from the knuckle
      Rear hub and bearing
      Click to Enlarge
To install:
  1. Install or connect the following:
    • New wheel bearing into the steering knuckle
    • Snapring to the knuckle
    • Wheel hub
    • Steering knuckle cam and hand tighten the bolt
    • Coil spring
    • Shock absorber lower nut. Torque the nut to 85 ft. lbs. (115 Nm) for 2002-04 models; 129 ft. lbs. (175 Nm).
    • Upper ball joint. Torque the nut to 76 ft. lbs. (103 Nm).
    • Lower ball joint. Torque the nut to 76 ft. lbs. (103 Nm). Align the steering knuckle cam and torque the bolt to 85 ft. lbs. (115 Nm).
    • Brake line to the wheel cylinder. Torque the brake line bracket bolt to 15 ft. lbs. (20 Nm) and the brake line fastener to 11 ft. lbs. (15 Nm).
    • Parking brake cable to the backing plate. Torque the bolt to 16 ft. lbs. (22 Nm).
    • ABS sensor bracket. Torque the bolt to 80 inch lbs. (9 Nm), if equipped
    • Halfshaft nut. Torque the nut to 214 ft. lbs. (290 Nm).
    • Brake shoes
    • Rear wheel
  2. Fill and bleed the brake system.
  3. Check and adjust the wheel alignment as needed.
2-Wheel Drive
    • Rear wheel
    • Rear brake drum
    • Wheel hub nut
    • Wheel hub
    • Snapring
    • Wheel bearing outer race from the knuckle
      Rear hub removal
      Inner wheel bearing removal-rear hub/bearing
      Rear wheel bearing removal-2wd
      Rear wheel bearing removal-4wd
To install:
  • Wheel bearing in to the knuckle
  • Snapring
  • Wheel hub into the wheel bearing
  • Wheel hub nut. Torque the nut to 214 ft. lbs. (290 Nm).
  • Brake drum
  • Rear wheel
    Rear wheel bearing installation
    hope this helps if so send testimonial comment or even any other questions you have
Jan 16, 2011 | Ford Escape Cars & Trucks
Re-assembling a E200 rear wheel
Click this link http://www.razor.com/support/pdf/manuals/current/e100-series-manual.pdf
Scroll down to chain and tire replacement. It has a full exploded diagram of the rear wheel
Jun 28, 2010 | Razor E100, E125 & E200 Electric Scooter...
Loud clicking noise coming from rear wheel drive section
Hi. Does it make a click about every revolution of the rear wheels? If so it is probably the square key in the axle that drives the wheels. Raise the rear of the machine on blocks, and remove the rear wheels. Wipe a thin smear of grease on the axle and key. then reassemble and test.
I have done this on many machines because of the noise. Just about all brands have this problem.
Good luck. Neil.
May 31, 2010 | Pride Mobility Products Go-Go Elite...
How do I adjust the handbrake on a V Reg bmw 318i ?
remove cover between seats to expose cable adjusters and back them off till slack. jack up rear of car (chock front wheels) remove a rear wheel stud and you can view the star wheel adjuster inside the drum, with a thin screwdriver wind it up till wheel locks then back off about 15 clicks, do same on other wheel, wind up adjusters inside car till wheels lock at about 5 clicks, check for binding when h / brake is fully down, thats it.
Mar 07, 2010 | 1999 BMW 3 Series
What causes continuous clicking with pushing on accelerator in 1983 Honda Accord? Clicking stops with taking foot off accelerator with car coasting. Acceleration is not bad, even with clicking.
I can't remember if those are front wheel drive, or rear wheel, but... if it's front wheel drive, you need CV joints. If it's rear wheel drive, you need U joints.
Jan 24, 2010 | 1983 Honda Accord
Clicking noise from rear wheel
Is your bike chain drive? It sound like you have a link in the chain hanging up. Check it and lube it.
Oct 18, 2009 | 2006 Yamaha V Star 1100 Custom
Cycling Logo
129 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
