Question about Toshiba Televison & Video
I have a Toshiba DVD/VCR, Model D-VR35-S-TB (220-240 V), purchased November 2006. On 21 May 2009, there was a scheduled 6-hour mains power outage for maintenance of a local substation. During the outage, the recorder was on standby. When power was restored, the recorder was dead - no response to the ON/STANDBY button - nothing on the display. The power-cord fuse and the internal mains fuse are intact. There are no problems with other digital equipment in the house (in Croydon UK). Can you please suggest where the problem could be - and can it be fixed? Thanks.
  • male_johnc Jun 19, 2009
    Yes, I appreciate that there could have been a power surge (presumably an increase in voltage). I was hoping that you could identify which bit of the electronics would be most vulnerable and possibly repairable. Is it likely, for example to be the internal power unit? Nothing mechanical is working, including the cooling fan.
    If I have an expert opinion on this, it will help me to ask the power company for compensation.
    Thanks if you can help.
  • male_johnc Jun 25, 2009
    Thanks for that. I've had a good look inside and there's no sign of any damage. Everything looks perfect and pristine. But I probed about with a multimeter and found several points on the circuit boards where the AC reading was about 3 Volts and the DC reading about 1 Volt (relative to the chassis) and in both cases there was about a 10 percent fluctuation on the reading with a frequency of about 3 Hz.
    Is this a useful clue?
    Scholar:
  • 136 Answers
There is a possibility that a sudden surge in voltage can cause a damage to the electrical circuit, If the damage is caused inspite of the device having a mechanism to handle this sudden surge (eg SMPS) then you can surely claim the compensation as the voltage regulator mechanism itself failed to check the increase in voltage.
Posted on Jun 25, 2009
  • Toshiba Master
  • 2,404 Answers
Look for any capacitors that are puffy. Normal Capacitors have a flat silver top on it. Capacitors that go bad normally look puffy (pregnant) and normally would have a silver top that is not flat. You may find a bunch of these depending on how strong the power surge is.
Also you may find scorch marks if the board took a direct hit by lightning, it will be black marks and the chips will look burnt like a bad piece of wood.
Posted on Jun 20, 2009
    Top Expert:
  • Toshiba Master
  • 81,400 Answers
Yes the power surge fried the electronics. See this kind of post on a regular basis.
Posted on Jun 19, 2009
We have a Toshiba Model 37LX96 LCD/DVD Combo Can't turn on, after a recent power outage There is power going to the unit, but it will not turn on using the remote or using the "power"...
Common problem with the main board. Only happens after losing main power, not just turning the TV off.
I found that blowing hot air with a heat gun down the vents above the DVD player (don't melt the plastic housing) will warm the main board up enough to get the TV powered up again.
You'll be good to go until the next power outage then back to the heat gun.
Also the spec sheet indicates max humidity at 80% so keep the TV in a space with lower humidity.
The Toshiba 37LX96 is a quality TV, not a throw away if you can keep it running.
Schmidty
Aug 25, 2011 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
Toshiba D-VR35 when i put in a dvd or video i get sound but no picture,also the menu screen does not display either and dvds take quite a while to load. Thankyou Mrs Jacks
Electronis circuits do not like moisture, which is your problem here. You have to dry the unit by turning it on, until dried up, then all the elctronics functions will work again.
Mar 10, 2011 | Toshiba Televison & Video
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find...
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Feb 09, 2010 | Toshiba DVR670 Player
After power outage remote not working.
Hi, this is a bit basic, try turning of for about 1/2 hour, to enable to discharge, then try again.
( I have used this on industrial installations, with far to complex computers stuff inside, and that mainly works)
Apr 02, 2017 | Sanyo DVW-5000 DVD Player/VCR
Toshiba D-VR36-S-TB DVD/VCR Combi
Sorry,time to buy a new unit or use a professional A/V repair guy to take it a part(but too costly!)
Jan 22, 2008 | Toshiba SD-V392 DVD Player/VCR
Toshiba TV model 28NO3B with Toshiba VCR.
Hi. What is the make & model of your VCR ?
Sep 22, 2007 | Televison & Video
Televison & Video Logo
118 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
