Question about Actiontec (GS503AD3-01) Modem
LIGHTS ON MODEM ARE FLASHING RAPIDLY, HAVE CHECKED POWER SUPPLY AND PUSHED RESET BUTTON, NO CHANGE
    Scholar:
  • 94 Answers
You will have to be a bit more clear on which lights on which model of modem is flashing rapidly.
Usually, as long as the internet works, the flashing lights are there to show that the modem is functioning properly and is currently sending packets, transmitting data, etc.
Posted on Jun 19, 2009
I've checked power and fuse on power supply no lights or and function works
Is the set totally dead or do you see a light on the front of the tv that is supposed to change color when the on button is pushed
Dec 14, 2017 | Televison & Video
Tip
How to Reboot or Reset a Cable or DSL Modem Properly
  1. Turn off the computer and all other devices connected to the modem before attempting to perform a reboot or reset of the modem.
  2. Remove the power plug in the back of the modem. Check your modem for a battery pack. The battery must be removed in order to fully power down the modem.
  3. Keep the power off for at least one minute and then return the power plug to the back of the modem and wait for all the lights on the front of the modem to come back on and stop flashing.
  4. If you have a router, plug it back in and wait for the lights to come on first. Next, turn on your computer. After this, your connection should be back and you can reach the Internet.
To completely reset the device back to its factory settings, follow this step:
  1. Look at the back of the modem. There should be a tiny button or hole in the back of the modem that will be labeled reset. Press this button in for a minimum of 10 seconds using a small pin or a paperclip to reset the modem. This will reset the modem to factory defaults. You will need to reset options just as if it was a brand new modem being installed.
on Jul 10, 2010 | Computers & Internet
Belkin wireless nrouter doesn't connect to modem
Press the reset button in while the router is powered on. hold it in until all the lights stop flashing. It will then reset to factory defaults. the reason it's hidden is that it is a pain to keep setting up your network if accidentally pushed.
Apr 04, 2014 | Computers & Internet
Linksys WRT300N router flashing all lights
On the back of the router you will see what looks like a pin hole, turn the router on and use a paperclip to push into the hole(it's a reset button) and keep it pushed in till the router cycles off then on again, it resets the router to default. Hope this helps.
Jul 01, 2017 | Linksys WRT Computers & Internet
I have a netgear range max, it has been working fine. Just last night nothing wireless in my house works. Cable modem works. Power light on netgear box is green. "i" icon is flashing green,...
You need to reset and reconfigure router
please follow the steps to reconfigure router
RESET THE ROUTER:
1. Make sure router is connected to power supply and is on while you perform the task below. At the rear panel of the router, near the antenna, there is a very small round pinhole that contains the reset button.
2. Using a pen/pencil/paper clip, hold the reset button for 60 sec. so that the test light starts flashing.
3. After few seconds when the test light stops flashing. Turn off the router and turn it back on after a couple of minutes.
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Regards,
Prakash
Apr 08, 2011 | NetGear WGT624 Wireless Router
For some reason the light above the WPS button keeps flashing red. I have tried multiple reboots, none of which have worked. when connected to the ethernet modem, the light stays as a solid red color.
You need to reset your Router before setup manually.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Aug 16, 2010 | Belkin Wireless Play Router (F7D4302)
Belkin router wireless is good with green lights on, but modem light is flashing. What seems to be the problem?
HI! I believe your having an issue with the connection. if the modem light is flashing. try to unplug the power of the modem for 1min and plug it back in. if still flashing, press the reset button for 20secs. then release, it will turn of and on. after it initialize, unplug the power from the modem for 20secs then plug in, if its still the same, call your isp provider. modem is dead
Nov 24, 2009 | Belkin F5D9231-4 Router
When power switch is turned on the Power light is rapidly flashing & the 4 Ethernet lights are flashing. The box is Actiontec GT704wg
I do not have a solution to the problem. However, I am having the same problem. This morning the Actiontec GT704WG power and ethernet lights were rapidly flashing. The modem was non-functional. I could not even connect to the modem through the browser to see if I could find a problem.
The problem lasted a couple of hours. Then all of a sudden the modem started working again. I won't be able to tell if the problem recurs until I restart the modem. And if the problem does occur again, I won't be able to connect to the internet.
Oct 08, 2009 | Actiontec GT704WG Wireless Router...
Dishwasher does not start
I have the same problem. I've tried everything;even took apart the control panel and checked for corosion. I ended up changing the control board-$130 down the drain- The only other thing I can figure is the button panel has some sort of short- also ~$130-. good luck. Now I use the sink (wife's not happy) Tech sheet is behind kick plate.
Dec 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
--If the Power light is flashing red thanits definately problem with the Actiontec Router --As you have checked with different power source, the possibility of bad power source is no more --May be due to some voltage fluctuation the modem is gone bad.
Jul 10, 2007 | Actiontec (GS503AD3-01) Modem
Actiontec (GS503AD3-01) Modem Logo
263 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
