Question about Technics Audio Players & Recorders
Lens for sl-pc20 lens cleaninjg - Technics Audio Players & Recorders
How to take off headlight lens off a 2000 saturn
Go to Autozone,they will get you some lens cleaner,don't need to remove to clean.
Oct 26, 2012 | 2000 Saturn SL
Disc will not play appears to be skipping
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Be sure discs are free of dust and scratches.
Apr 27, 2010 | Technics SL-PD6 5-Disc CD Changer
My technics sl-p770 doesn?t recognize the loaded CD.A cd is alway spin but not any track in audio cd.
Try cleaning the lens with a cd/dvd lens cleaner disc. Another thing of note....some cd players simply will not recognize homemade cds, or dics that are not audio discs, or if they were made on a computer.
Apr 15, 2010 | Technics SL-PS770D CD Player
When Making A CD To Play On My technics SL-PD8 It
If thhis happens quite often , and does not depend on the media, then it is usually a dirty lens problem. The lens is dirty or scratched and sometimes cannot read CD TOC (table of content).
If this happens only on reocrded CDs , try changing the media used. For example if you used +R, try with -R.
If this happens on all media, then try cleaning the lens with a lens cleaner CD or blowing some canned air on the lens.
See: CD and DVD Lens Cleaner...
May 02, 2009 | Technics SL-PD8 5-Disc CD Changer
CD's come out distorted on the TECHNICS SL PG 580A
TRY NEW RCA JACKS AND TRY BLOWING IT OUT,,GET YOU A LASER LENS CLEANER
Feb 26, 2009 | Technics SL-PG480A CD Player
When i insert a cd , display says 'NO CD' Model SL-HD350
it will need a manual cleaning of the laser lens
Dec 10, 2008 | Technics SL-PG480A CD Player
Canon PC20 exposure lamp replacement
Back cover,left cover,and top cover.In that order.(Left cover opens with 2 clips.)Remove the glass.And then you can replace the Lamp.
Oct 31, 2008 | Office Equipment & Supplies
Technics SL-PG400A
Did you clean all the lenses? There are three on this unit; the emitter lens, the grating lens, and the objective or focus lens; probably the one you cleaned. These steps must be done by a tech and clean room standards must apply. The next best thing to do is just replace the laser assembly, as the above is labor-intensive...accordianman
Jun 15, 2008 | Technics SL-PG480A CD Player
Driver win xp
Hi, you can download the drivers from here... http://kb6myr.com/Pablo/Pablo_PAB-PC20_Driver.htm All the best John
Nov 23, 2006 | KB Gear Pablo Internet Edition (KG-PB20)...
Fixing aperture blade mechanism
if your not a trained qualified tech,never try to open your lens,you may spoil it all, since you need refocusing.
Oct 02, 2006 | Tokina f/PENTAX- 28/2.8 SL Lens...
32 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
